      05-25-2011, 12:53 PM   #1
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
Valentine 1 Won't Power from Cigarette Lighter
So, I went to plug in my Valentine 1 using the cigarett lighter for the first time into my new to me car (I had loaned it to a friend).
It wouldn't power up, nothing. I tested in an another car, works fine. I got back into the Z4, pushed in the cigarette lighter...POP yeah, it's hot, I guess the outlet is working. Plug the Valentine back in ..wiggle the connector all over the place, twist/turn you name it...nothing.
What gives? Has anyone else run into this? My next step is to take a multimeter to the cigarette lighter outlet just to see what's what.
I plan on hardwiring it, but that's on the to-do list for now.
Thanks!
      05-25-2011, 01:25 PM   #2
marinb
marinb's Avatar
Drives: 2017 911 GTS
The cig lighter in the Z4 sucks! Lots of things I've tried don't work in it. Very few things do. I ended up hardwiring my radar detector, didn't take long.
      05-25-2011, 02:13 PM   #3
elerner61
elerner61's Avatar
157
Great! A simple thing that I'm sure the teutonic engineers have made better in some manner (iLighter?)
Guess I'll be hardwiring much sooner than later.
Thx.
      05-25-2011, 02:58 PM   #4
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I was gonna suggest checking the fuse, but you said the cig adapter works. Strange, my power adaptor worked fine with the stock cig connection
      05-25-2011, 04:43 PM   #5
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
My GPS has trouble sometimes getting power from the cig lighter.
Just take the time and hardwire it now, took me 10 mins
      05-25-2011, 11:05 PM   #6
Trev
Drives: Z4MC
+1 to hardwire it.
Or use the adapter from the V1 kit. It snaps onto the plug adapter & takes up the slack built into these new larger sockets.
      05-27-2011, 01:39 PM   #7
ShakyDog
ShakyDog's Avatar
Drives: 2007 Z4 3.0i Alpine White/Red
I had to spin my arround until it worked and then hope it did not pop out, I quickly hard wired it only used the plug twice.
Steve
      05-27-2011, 03:39 PM   #8
tjank123
Geh Hau Ab
Drives: '11 X5-35d, '08 ZM Coupe
I hard wired mine to the fuse box to an empty slot with a fuse splitter.
      05-29-2011, 09:19 PM   #9
ZedFourM
Drives: Z4MC - Interlagos
Stupid thing, but are you sure the fuse in the cig lighter adapter hasn't backed out a little? That got me once.
      06-06-2011, 10:42 AM   #10
elerner61
elerner61's Avatar
157
Hardwire install is done (purple and white kinda hard to dig out of there!). Had to pin a new RJ-11 cable though, I had used the one that came with the V1 for another install. Interestingly enough, the RJ-11 connectors from Radio Shack don't fit 100% in the V1. No power when the new cable is positioned certain ways and I can see the connector moving around slightly in the jack on the V1.
I really wish Valentine would get on the GPS memory/location bandwagon. Every damn CVS I pass I say to the V1 "I know, I know"
      06-06-2011, 10:58 AM   #11
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
My cig lighter is temperamental. I have to move the plug till it finds a position it likes. Sometimes will lose the connection after a bump though. Good move on the hardwire. I'm thinking about getting a V1 as well.
