01-21-2012, 11:03 AM | #23 |
Rep 66
I was wondering if someone who has replaced an exhaust hub or who is very familiar with the procedure could answer a few questions. I was looking at the procedure, and wondering about the tools required. It seems BMW says you need the jig to hold the cams, a black electrical box the plugs into the Vanos solenoids, and another special Vanos tool. Does anyone know if the electrical box is required to r and r the S54 Vanos? Do you need any of the special tools to replace the Vanos or just the exhaust sprocket? Thanks
01-21-2012, 03:20 PM | #24 |
Rep 91
Drives: 2007 Z4MC
You do not need the electric box(just remove the caps from the Vanos unit-at front 3 bolts each and that will release the vanos pressure). I did use the bmw cam lock tool-tried it first without it with no success. there is a great thread on M3 Forumn on the repair -Video is great .
Let me know if details required and I'll dig them up. |
01-21-2012, 03:37 PM | #25 | |
Rep 632
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
01-21-2012, 07:15 PM | #26 |
300 Maraging hub
Rep 11
vanos hub
you dont need the bmw timing tool if you know how to use a square.
There is some videos on youtube of how to take it apart. I tried it the first time by marking the cams with no success. but now I have no problems timing the cams. Before you take the hubs completely lose from the cams make sure your on top dead center. when you go to reinstall stick a 1/4 extension in the crank hole to lock it at tdc make sure its at tdc there is a couple holes but only one tdc there is a hole in the camshafts find a screwdriver or something that fits inside the hole firmly now use a square off the head and turn the cam till the screwdriver is a perfect 90% do this for both camshafts put hub back on loosely turn the hub clockwise till it stops take the splined center shaft push inside and turn the hub ccw intill the splines mesh if you have to move the hub back more than about 5 minutes on a clock take splined shaft out turn it to next tooth and try again. once it slides in on the intake side push it in till the splines are just barely visible then lock down the hub for the other exhaust hub judge it from the intake should be about the same depth. now pat yourself on the back you just timed a S54 without special bmw tool bla bla the cam timing is controlled by the computer so if you get it close the computer will be happy.The computer sets the cam timing everytime you start the car unless you get to far out then you will get ses light but i never had one by doing it this way. thanks you guys |
01-23-2012, 08:42 PM | #27 | |
Rep 632
01-23-2012, 10:27 PM | #28 |
Rep 1,097
Frankly this would scare the shit out of me to time an S54, that being said this info is amazing.
01-24-2012, 08:39 PM | #29 |
300 Maraging hub
Rep 11
timing
I have timed it twice this way and three times using the mark it before you take it apart way which did not work for me. I am very confident in the screw driver and square. I am going to be doing it pretty soon again for the third time to get pictures of my hub. Also I said square it off the head but you really square it off the tops of the cams since they sit higher than the gasket flange of the head.
02-06-2012, 08:54 PM | #31 |
Rep 11,667
IMO, it's only cars that they forgot the locktite
02-07-2012, 08:04 AM | #32 |
Rep 400
If you look at RealOEM the fillister head screw (part number 07119919965) ended in 04/2006 and was replaced by fillister head screw (07129905536). That is the one with locktite, I believe. That is also the only part number listed under my build date of 12/2006. So if your build date is before 04/2006 then you might have the old screws in your car.
02-07-2012, 09:16 AM | #33 | |
Rep 421
http://www.penskeparts.com/DiagramsR...iagram=11_3004 |
02-07-2012, 09:18 AM | #34 |
Rep 4,057
Pardon me if this is a stupid question. But does this mean that a 2007 or 2008 Z4M should be immune to the dreaded VANOS failure issue?
Huz-Z
02-07-2012, 11:39 AM | #36 |
Rep 784
Drives: 2011.5 E90 M3
My build date is 03 2006. I have my first inspection coming up in 500 miles so I'll let everyone know what I find.
02-07-2012, 11:57 AM | #37 |
Rep 4,057
I came close to doing that last spring actually. I don't have plans to switch right now, but I could be interested if the right car came along at the right price. I think I would find a low mileage Imola Red roadster hard to resist!
Huz-Z
02-07-2012, 12:45 PM | #38 | |
Rep 421
Both screws are 8.8. Spend $30 for BMW centernet and look the bulletins and also group 06 in the bulletins. It could be come from another company. |
02-07-2012, 01:10 PM | #39 |
Rep 66
So, let me make sure I got this correct. To time an S54, the only tool most people need is the cam alignment jig that sits on the top of the head. The purpose of the black electrical box is to remove oil psi from the vanos prior to removal, which can be done by removing the end caps. The jig sets both cams at 90 degrees using a hole in each cam and a rod through the jig. Some people have done it without the jig using a square to ensure the cams are in the correct position. Even if the cams are a little off, the DME can work with it and correct it. This setting of the cams is the only critical step to affect timing. Reinstalling the splined gears that go inside the hub is either done correctly or not, if not you will know it, no special tools required there. Correct?
*** Also, one is able to see/check both exhaust Vanos oil pump tabs by removing just the valve cover and turning the engine; no additional tear down is required... Correct? Thanks! |
02-07-2012, 04:41 PM | #40 | |
Rep 400
Yes, you can look at the vanos tabs by removing the valve cover and turning the engine. I have some pics of mine here: http://www.zpost.com/forums/showthread.php?t=643901 |
02-22-2012, 11:00 PM | #42 | |
300 Maraging hub
Rep 11
s54 timing http://www.mediafire.com/?bmd3j2ievwji0aw here is a video on setting the splined shafts http://www.youtube.com/watch?v=QVFT1JGqJrA Last edited by turbotoy2791; 02-23-2012 at 08:47 PM.. |
