Reply
      02-03-2012, 08:52 PM   #1
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
My 8 day valve adjustment
That's the pitfall of doing a valve adjustment without the shim kit. I decided to spare some cash and order some shims individually. I ordered (2) 2.20, (2) 2.24, (4) 2.28, (4) 2.32, (4) 2.36 and (4) 2.40 shims. I also got the valve cover gasket kit and shim tool from ECS tuning.
Here are some pics:
Picture of the before
Also changed the vanos filter... it was pretty clean
Here's a pic of the coil packs and Oxygen sensor wires and some advice
There she is in all her glory
The tools that I used
Some mandatory pics of my vanos pump tabs....still intact
After 8 very long days and some clean up
I had to order some more shims. I needed another 2.28 and (2) 2.44 shims. It turns out that no dealership in the DFW stocks these. They all had to order them, so I just used the internet. One of the dealerships wanted $7.95 a shim! That's what took so long. I ended up changing a total of 15 shims.
Next on the Inspection 1 list brake system flush and CDV delete.
bignosejim is offline   United_States
      02-03-2012, 08:56 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: 07 M Coupe
Originally Posted by bignosejim View Post
...... I ended up changing a total of 15 shims.
15??
holy schit!!!! never heard of so many needing replacement.
Alpinweiss '07 M Coupe •Eisenmann Sport-Ceramic Black•Diablo-X•Fabspeed Headers•VRS Hyper-Narrow rear wing•Autosolutions SSK•APR splitter•Tekarbon headlights•StrongStrut STB•KW Clubsport•Poly FCAB/RTAB•Volk Racing G2•Direzza ZII•Stoptech BBK c/w Cool Carbon pads
inTgr8r is offline   Canada
      02-03-2012, 09:24 PM   #3
DanMcoupe
DanMcoupe's Avatar
Drives: 2006 Red Mcoupe/2012 AW 535
How's many miles on the engine?
and How's the engine running before and after?
DanMcoupe is offline   Reply With Quote
      02-03-2012, 09:36 PM   #4
bignosejim
bignosejim's Avatar
24,009 miles. The engine ran strong before the valve adjustment and is running strong...
That is after I connected the oxygen sensor cables correctly. Before that it was idling fine but hesitated a lot. I only made it around the block before pulling into my garage. I checked each coil quickly and no problems, then switched the O2 sensor wires. I thought that they would only go on one way. Turns out you can get them mixed up.
      02-03-2012, 10:10 PM   #5
ZStig
Drives: VT2-500 M Roadster
wanna do mine next?
ZStig is offline   Reply With Quote
      02-03-2012, 10:23 PM   #6
mhughett
Drives: 2007 Z4 M Coupe
15??
My inspection I valve adjustment resulted in 16 valves requiring different size shims. It wasn't bad before but it seems a little quieter now.
Retired--2007 Z4 M Coupe (Imola Red/Black, Premium Pkg, Heated Seats, XM, Bimmian stubby antenna, CDV delete, Apex EC-7--Anthracite, Goodyear F1 Asymetric 2.
mhughett is offline   Reply With Quote
      02-03-2012, 10:59 PM   #7
330indy
CCA member
330indy's Avatar
Drives: 330i zsp; '06 M R
OP: great pics
and thanks for lessons learned
Magnetic oil pan, tranny & diff plugs, Redline fluids, Zeck CDV, Dinan tri-brace, ProDryS, 3M film, Alum stubby, PBR Ceramic Pads, Nitrogen! j/k !!
330indy is offline   United_States
      02-03-2012, 11:06 PM   #8
Finnegan
Finnegan's Avatar
Drives: Sapphire Black/Black Z4Mc
Cool! Timely and informative thread!
BTW, how were the lime chicken kabobs (photo 5)? Mmmm....kabobs.
2007 Sapphire Black Z4M / Apex EC7s / Eisenmann Exhaust / Euro Headers/Cat / Aero Sideskirts / DIY Stubby / Ultimate Pedals / AS SSK / RB Rotors / Other Stuff #1047
Finnegan is online now   United_States
      02-04-2012, 09:07 AM   #9
bignosejim
bignosejim's Avatar
Originally Posted by Roffle Waffle View Post
wanna do mine next?
It's really an easy procedure to do. I just followed the TIS and took pictures so that I would know how everything went back together. Just measure the gap and the shim and use the next size as appropriate. It really helps peace of mind seeing my vanos tabs intact and being able to test for movement of the intake camshaft sprocket (sign of loose sprocket bolts) and replacing the vanos pressure limiting valve filter.
Originally Posted by 330indy View Post
OP: great pics
That's the main reason I wanted to start this thread. So others can learn from my mistakes. There should be plenty of more opportunities in the future!
Ha Ha! I think they are still in the freezer/workbench in the garage.
      02-04-2012, 09:23 AM   #10
inTgr8r
inTgr8r's Avatar
Drives: 07 M Coupe
one other note.....
Don't forget to plug all the oil returns on the head, as well as the sparkplug wells.
      02-04-2012, 09:32 AM   #11
bignosejim
bignosejim's Avatar
one other note.....
I did. That was a pic right after the valve cover came off. Anything that looked like a hole got covered! Only dropped one shim, and it was pretty easy to find.
      02-04-2012, 10:49 AM   #12
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
one other note.....
I ended up using my paper towels after, stuffed into the spark plug socket with a little brake cleaner to clean the plug seats, carbon tends to build up there.
08 E90M3 6MT Alpinweiss/Carbon
thekurgan is offline   United_States
      02-04-2012, 10:49 AM   #13
inTgr8r
inTgr8r's Avatar
Drives: 07 M Coupe
dropped one when I did mine as well, it was a bugger to find.
I was glad that I had things plugged.
      06-20-2012, 09:17 AM   #14
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 08 Z4M Roadster
I just had mine done at 38k. We replaced 5 shims. I purchased a whole box of shims. What I was wondering was should I have also changed out the spark plugs? I did not think about that before we started the project, but since the cover is easily enough taken off I can still order them and install.
Regards
And your pictures are no long showing.
2008 - Z4MR BMWCCA / ZSCCA Member
STIHLBOLTS is offline   United_States
      06-20-2012, 01:03 PM   #15
davesz4mc
Drives: 2007 z4mc
I have the shim kit and a shop in San Antonio if anyone else in the area needs sit done. Roffle I will do it for you if you drive down lol
davesz4mc is offline   Reply With Quote
      06-20-2012, 05:31 PM   #16
bignosejim
bignosejim's Avatar
Regards
I believe spark plugs are due to be changed at 60,000 miles according to my service checklist (that I got from a jmillet post).
Fixed the pics also.
      06-21-2012, 09:47 AM   #17
STIHLBOLTS
STIHLBOLTS's Avatar
I will order them in plenty of time. I don't know if he still has any kits left, but Ron Styger had them for around $250 dollars a couple of months back.
Regards
      06-21-2012, 10:29 AM   #18
Ron Stygar
Drives: 2006 Z4 M Coupe
Box shims
Box shims gone. Went from $456.73 to $468.38 retail
I have 36 shims left.
1.72 - 6
1.76 - 6
1.80 - 6
1.84 - 6
1.88 - 5
1.96 - 6
2.12 - 1
36 Separate shims $123.48 retail ($3.43) each retail.
$3.48 ($125.28) retail ($3.48) each at 06/21/12.
Will sell 36 separate shims $74.88 ($2.08 each) plus shipping.
http://www.penskeparts.com/DiagramsR...iagram=11_3006
Ron Stygar is offline   Reply With Quote
      06-22-2012, 08:34 AM   #19
Pheonix
2007 BMW/Z4MC  [0.00]
Getting a comlete shims kit was the best decision i made and the magnetic tool is a "Must Have". I also did it the easy way by measured/adjusted everything to the higher ends of the specs. I changed out 3 shims on the intake and 3 shims on the exhaust.
I will put up the shims kit up for sale shortly as well
Pheonix is offline   Reply With Quote
      06-22-2012, 09:03 AM   #20
STIHLBOLTS
STIHLBOLTS's Avatar
^Are you selling the car? At 20k/15K intervals you will be checking and changing shims again. I personally don't plan on selling my car, but if I did I would sell the shims to the new owner or make it part of the deal since I already bought them.
Regards
      06-22-2012, 10:17 AM   #21
Pheonix
Regards
Not anytime soon. Since i live in the Northeast and don't/can't the car year round, it wil be awhile til my next service interval (even at 15k miles). I figure i could refill the Kit and sell it so someone could use them right away (instead of it sitting in my toolbox).
      06-22-2012, 10:22 AM   #22
STIHLBOLTS
STIHLBOLTS's Avatar
Gottcha.
Yea, shorter driving season that's understandable.
Regards
Reply
Forum Jump
