      05-20-2018, 09:38 PM   #1
kav
Drives: Z4M
I noticed some wet spots under the car when it was up on the lift after a track day. The pattern seemed weird but after some online reading I was convinced it was the CPV so I ordered a new one and was ready to replace it. When I put the car up on the lift and the lower shield removed the CPV looks rusted and does not appear to be leaking.
I snapped some pictures to see if you guys have any ideas. It may just be the oil pan gasket but it would not fully explain weird pattern seen. Also, it does appear wherever it is coming from there isn't enough to drop on the shield or on the ground.
Sorry the pictures got out of order when I posted them.
      05-21-2018, 08:46 AM   #2
kav
Drives: Z4M
Any ideas?
      05-21-2018, 10:03 AM   #3
steffenme1
steffenme1's Avatar
103
Drives: 2007 Z4 MCoupe
Hard to tell from the pics but if it's not the CPV there isn't a whole lot else in that area minus the pan itself or the giant plug thingy mentioned here:
http://www.zpost.com/forums/showthread.php?t=1490299
I'd replace the CPV (they all leak eventually it seems) clean everything really well and inspect again in thousand miles or so.
Good luck,
      05-21-2018, 12:05 PM   #4
kav
Drives: Z4M
Good luck,
Great advice. Thank you.
      05-21-2018, 12:49 PM   #5
GuidoK
#buildnotbought
GuidoK's Avatar
10866
Drives: Z4 3.0i ESS TS2+
Judging from the stains on the bottom reinforcement plate the leak is on the other side.
Maybe the OFHG?
Could also be the VCG (although leakage usually starts on the other side), or an oil pressure sensor ring.
Hard to tell really based on these pictures. Start cleaning your engine, drive for a while and look for small drops.
      05-21-2018, 03:05 PM   #6
kav
Drives: Z4M
Maybe the OFHG?
I'll spray it all down with break cleaner and monitor. I appreciate the advice.
The CPV is so rusty I'm not looking forward to that.
      05-21-2018, 03:50 PM   #7
GuidoK
#buildnotbought
GuidoK's Avatar
10866
I wouldnt touch that cpv if it isnt leaking.
It might be quite some while before it starts to leak, or it may never leak.
And if it starts to leak its a really easy fix imho. (and like you said, now its rusty, then it probably wont anymore and the threads will be well lubed with that oil sucked in there under heat from engine and exahaust)
And who says that if you change it now it wont start to leak or starts to leak later.
There is no set time or mileage on a leaky cpv so this cpv might hold just as long from now than of you change it now and the new one will hold.
If it starts to leak it wont be a massive leak and easily fixed during the next oil change you do on that engine I think.
      05-21-2018, 06:46 PM   #8
kav
Drives: Z4M
Makes sense.
      05-21-2018, 08:07 PM   #9
kav
Drives: Z4M
I used some brake cleaner to clean off the under carriage of the car.
Two things I noted. The power steering expansion hose towards the front of the engine looks rushed and could be leaking. I never had mine repaired with the TSB. Could that cause all this?
There is a small oil trail on the passenger side of the engine that is making its way all the way down to the wet spots I saw earlier. I wonder if it is actually from higher up. Really hard to tell since it all looks a little wet.
      05-22-2018, 11:12 AM   #10
StickMon
StickMon's Avatar
Drives: 2006 MR
Originally Posted by kav View Post
... There is a small oil trail on the passenger side of the engine that is making its way all the way down to the wet spots I saw earlier. I wonder if it is actually from higher up. Really hard to tell since it all looks a little wet.
Vanos?
      05-22-2018, 01:58 PM   #11
kav
Drives: Z4M
Vanos?
Well that sounds more scary.
      05-22-2018, 04:06 PM   #12
StickMon
StickMon's Avatar
Drives: 2006 MR
If it's the O-ring plate, that's super easy to replace.
If it's the gasket to the head, that's a faff.
      05-22-2018, 07:09 PM   #13
kav
Drives: Z4M
Do these pictures help?
It is definitely cling form the passenger side. I need to look at what all these structures are.
      05-22-2018, 07:56 PM   #14
kav
Drives: Z4M
I know the pictures are terrible but I think it is the vanos oil accumulator. I'm going to call it quits on tracing this one and take it in to my Indy shop.
      05-24-2018, 12:52 PM   #15
StickMon
StickMon's Avatar
Drives: 2006 MR
Be interested to know what they find.
That's how my leak started.
First was just a "high grime neighborhood" around the front of the block up under the Vanos down to the harmonic damper.
Then started to see drips off the chain tensioner and wetness on the AC compressor.
Replaced the tensioner crush washer, but no joy.
Now it's just a royal mess all over the front suspension and on the driveway.
Been waiting for something major to break before taking it in for comprehensive service.
      05-24-2018, 04:18 PM   #16
kav
Drives: Z4M
Well that sounds scary.
