11-28-2012, 05:38 AM | #1 |
Rep 23
HELP! - CSL 19inch Z4M - F:ET44 R:ET27
Guys
I have a set of of CSL wheels for my 2007 Z4M Coupe. The specs are as follows: FRONT- 19X8.5 ET 44 - TYRES: 265/30/19 REAR - 19X9.5 ET 27 - TYRES: 235/35/19 Will this work with no spacers? |
11-28-2012, 05:46 AM | #2 |
Rep 5,329
Yep no problem but the front won't look too hot, it will appear rather sunken...
A 10mm front spacer would give near ideal conservative z4m offsets.
11-28-2012, 06:56 AM | #4 |
#dubspec
6337
Rep 5,201
Why don't you want to use a spacer?
11-28-2012, 07:49 AM | #5 |
Not a New Member
94
Rep 925
i'm sure you know this and your OP has a typo...
the 235 tread should be on the 8.5", and the 265 tread should be on the 9.5".
11-28-2012, 09:43 AM | #6 |
Rep 23
11-28-2012, 09:47 AM | #7 |
Rep 23
Hi Dub
I dont want a spacer because of the vibrations and safety aspect. I drive above 260km/h often so I would not be too comfortable at those speeds with a spacer. Freeways are gr8 in SA and cops can be bribed If I use 245 at the front, will it rub? |
11-28-2012, 10:04 AM | #8 |
Not a New Member
94
Rep 925
OP = Original Post = 1st post in the thread
welsome to zpost!
11-28-2012, 10:25 AM | #9 |
Rep 280
The "good" spacers are piloted, so they are concentric. I don't think strength is much of an issue, put the 10mm up front. It's the same setup I have. Zero vibration. Got them from ECS tuning.
11-28-2012, 11:02 AM | #10 |
Rep 5,329
use a proper hubcentric spacer with longer studs or bolts is essentially the same as a lower offset wheel from the factory.... the spacers that are of concern are the bolt on type that then use their own studs..... like what the GTR owners use!!
11-28-2012, 11:13 AM | #11 |
Rep 11,667
^ whs
some (Porsche) cars come with OE spacers
11-29-2012, 12:42 AM | #13 |
Rep 23
Hi Geauxkart
Do you have the link of the spacer that you used? part number? |
11-29-2012, 12:43 AM | #14 |
Rep 23
11-29-2012, 04:06 AM | #15 |
My favorite sign.
169
Rep 4,333
You could try 245/35 front, 265/35 rear like I have on my VS8s...while not a perfect height match, I think the extra rubber up front is worth it.
11-29-2012, 05:44 AM | #16 |
Rep 280
http://www.ecstuning.com/BMW-Z4-M_Co...acers/ES11297/
And make sure to order the longer bolts they recommend. |
12-01-2012, 05:34 AM | #18 |
Rep 5,329
where did you pick these replicas from??
12-01-2012, 09:33 PM | #19 |
#dubspec
6337
Rep 5,201
second, i hope you knew these are not authentic...
12-02-2012, 06:50 AM | #21 |
#dubspec
6337
Rep 5,201
there should also be a BMW imprinted in between the spokes. may also be a bbs marking on the inside. the spokes are also skinier than original csl wheels. if you weigh them, you will also see a difference
12-02-2012, 07:09 AM | #22 |
Rep 5,329
note the bmw stamp opposite the ///M badge ;-)
