      01-04-2012, 01:32 PM   #1
rsutoratosu
Drives: Z4 3.0i
Trickle Charger for winter..
Is there a battery pack trickle charger for the car that I can get ?
I still haven't store my car because the underground garage does not have a wall charger outlet ANYWHERE ! I have private spot and can take up 2 spots.
The open garage (roof covering only) has outlet but I rather not use because its very busy and doesn't have good security.
So is there like a battery pack trickle charger type that I can charge in the wall, bring it down to the car and let it trickle the battery ?
Thanks..
-Roranji
      01-04-2012, 03:56 PM   #2
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Others have suggested buying a regular 12v rechargeable battery pack - putting it in the trunk and using one of the available float type chargers from the likes of Battery Tender.
2006 Z4MC - #LL93158
      01-04-2012, 04:28 PM   #3
marinb
marinb's Avatar
Drives: 2017 911 GTS
Why not just pull the battery out of the car? Then you could take it into your house and keep it on the trickle charger there.
Does anyone know of any issues with doing that?
      01-04-2012, 05:56 PM   #4
CFoote
2022 M5CS  [0.00]
2001 BMW 740i  [0.00]
2006 BMW M Roadster  [0.00]
2012 BMW X6 3.5i  [0.00]
2006 BMW 325xi  [0.00]
2017 BMW 540xi  [0.00]
2000 BMW M5  [0.00]
2001 BMW X5 4.4i  [0.00]
No issues with doing that except you might lose your presets in your car, along with any Bluetooth pairing -- I could be wrong, that stuff could be stored permanently. Otherwise, no issues at all.
Chris
      01-05-2012, 08:49 AM   #5
Hawkeye
Hawkeye's Avatar
No_Country
2070
I run a battery tender to the trunk but I just close the cord of the charger in the trunk door. It hasn't hurt it for the past 4 years... and they are only like $20 at wally world anyway. Works like a charm when storing over the winter.
I would steer clear of a trickle charger because it can overload your battery, with a tender it makes sure that the power is neither too high nor too low.
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      01-05-2012, 01:41 PM   #6
marinb
marinb's Avatar
I actually use a CTEK smart charger, it has a lot of nice features that other chargers do not have.
http://smartercharger.com/
      01-05-2012, 02:41 PM   #7
rsutoratosu
Drives: Z4 3.0i
my question is... if I take the battery out can anyone confirm that the car will not go into transport mode..
I had this happen to me 3 times last year because I didn't drive it and didn't have a tender on it. Taking it back to dealer and explaining what transport mode is was a huge pain.. waiting hours just to get a guy to reset it
-Roranji
      01-05-2012, 09:48 PM   #8
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
I have my tender running through the driver window, to the battery in the trunk.
I use batterytender, same that BMW uses
      01-06-2012, 09:46 AM   #9
rsutoratosu
Drives: Z4 3.0i
I have a tender already, like I said in my original post.
My underground garage does not have AC outlets anywhere. Its my preferred place to store the car.
My above ground garage which I hate has AC outlets.
i can't tender the battery if there is no AC available
-Roranji
      01-06-2012, 11:58 AM   #10
Ovaltine
floor sweeper
Drives: 2007 Z4 Coupe
"Transit/transport mode" is from a low battery - this is different than "no" battery. As others have said, simply remove the battery and take it inside where you can leave it on a charger. My battery sits on the corner of my workbench with a Battery Tender Jr. connected all winter. No issues.
      01-06-2012, 01:58 PM   #11
Gripster
Gripster's Avatar
Drives: E93 M3
2013 BMW M3  [0.00]
I haven't used it yet, but I did the "BMW Advanced Battery Charging System". My car is a second car and is not driven daily.
http://www.trademotion.com/partlocat...catalogid=4462
I can't tell you if it's any good, but I am a sucker for stuff with a Roundel on it.
2013 M3 (E93) - ZPP/ZCW/DCT
http://www.bimmerfest.com/forums/image.php?u=26275&type=sigpic&dateline=1208140506
      01-06-2012, 02:03 PM   #12
dmullinsjr
Drives: E30 M3
I use a Battery Tender Jr. on my Z4MC and on my E30 M3. They work great! No issues and the batteries are always fresh and ready.
      01-06-2012, 02:04 PM   #13
marinb
marinb's Avatar
That BMW Charger is a just a rebranded Battery Tender. BMW has also started rebranding the CTEK chargers... following Porsche's example.
      01-06-2012, 03:05 PM   #14
Lance_Goodthrust
Drives: 2016 435i Gran Coupe
Can a CTEK or batterytender be connected to the under-hood connectors?
      01-06-2012, 03:52 PM   #15
Kgolf31
Kgolf31's Avatar
460
I can only comment to Battery Tender.
It's a postive - negative connection hook-up, so you should be able to do it. It will throw an error and tell you it can't charge if this isn't the case.
      01-06-2012, 05:44 PM   #16
screamindv
Drives: Z4
I have a Battery Tender with an adaptor that goes to the cigarette lighter. Works well. I run the wire through the bottom of the door.
      01-06-2012, 06:28 PM   #17
marinb
marinb's Avatar
Yes, I connect my CTEK under the hood.
      01-07-2012, 12:43 PM   #18
tman53
Drives: 2006 Interlagos M Coupe
My trickle charger works fine under the hood.
      01-07-2012, 01:02 PM   #19
NeoGeo
Drives: E92 M3
I think the majority of the people that have posted a reply do not understand the question. He knows he needs a tender, but he has no AC source to connect the tender to.
The only thing I can recommend is to use a standard powerpack to supply the tender.
You'll have to recharge the powerpack periodically, but you can work out a schedule for that.
http://www.canadiantire.ca/AST/brows....jsp?locale=en
      01-07-2012, 01:44 PM   #20
Shipkiller
Shipkiller's Avatar
Drives: Me
Two options.
Option one as previously stated, take the battery out...
Option two. This is kinda of heavy handed. Put a second battery in the car, either in the trunk or in the engine compartment, and use a set of jumper cables to put the second battery in parallel with the primary battery.
The two batteries, once connected will equalize among themselves and add almost double (or more) the capacity (depending on the second battery size). Once a month, take the second battery out, charge it and put it back in.
Jumper cables is my first thought, but the cables you use do not have to be very heavy. They only have to carry a small amount of current.
      01-07-2012, 02:07 PM   #21
screamindv
Drives: Z4
If you have access to the sun, you can try these.
http://www.batterystuff.com/solar-chargers/
      01-07-2012, 05:18 PM   #22
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Get it done...
