07-08-2010, 06:44 PM | #1 |
Rep 1,143
Rear sway bar issue - what to look for
I'm starting to notice the "pop" from the right rear that I suspect to be the common rear sway bar issue that others have experienced. It's extremely intermittent and I started noticing it maybe a week ago. I am unable to reproduce it reliably, but it does happen enough that I can almost certainly say it's from the car, and not what I'm driving over. Also, it only seem to happen at low speeds.
I'm about to take off the wheel to check, but I'm not exactly sure what I should be looking for. Anyone have a picture or could point me in the right direction? I searched and didn't really find much. |
07-08-2010, 08:05 PM | #2 |
Rep 11,669
You will see better from the back of the car.
The sway bar mounts can be see up behind the exhaust cans. They are a U clamp with two bolts. RealOEM
07-09-2010, 11:38 PM | #3 |
Rep 1,143
Well, took off the back wheels and took a look. Nothing seemed loose. The u-clamp mounts were fine.
On the right side, there seemed to be a slight gap at the top end of the stabilizer beam (#6 here) that connects the sway bar to the upper wishbone (#12 here), but when I tried to torque the nut it didn't seem loose. Granted I didn't have an open-end wrench so I fudged it with an adjustable, so I wasn't able to get a solid grip with much leverage. I believe another member here posted a similar pic, also of the right rear: http://www.zpost.com/forums/showthre...=rear+sway+bar (post #9). Thoughts? Could it be an issue with the shocks? The pop/clunk seems to be happening more often now -- seemingly only at low speeds and only when going over some bumps (but not all), and seemingly more so during turns. |
07-24-2010, 04:56 PM | #5 | |
Rep 1,143
I thought that might have resolved it, but nope. Still get an occasional clunk from back there, and seems to be isolated to the passenger side. Happens ever time I drive, but it's pretty hard to reproduce. Could it be something to do with the rear shocks/springs? And what would I check for? I don't really get the feeling that there's anything amiss with the suspension. Took it up to 120 mph on a sweeping right on-ramp and felt totally stable (granted, most of the stress was on the left side of the car). Might bring it in to the dealer, but I'm not confident that they'll be able to identify the problem since it does happen so intermittently. |
07-24-2010, 05:28 PM | #6 |
Bad Lieutenant
233
Rep 3,517
For some new vehicles, there was an audible pop from the diff unit, but that went away after break-in. Do you get this crawling up a driveway or curb?
07-24-2010, 06:16 PM | #7 |
Rep 1,143
Car has about 17K miles, and I've owned it since 15.5K. Just started happening a few weeks ago. I do tend to get it with grade/elevation changes, though not always at the same place twice. I'm pretty sure sound is coming from rear right.
I do have the OEM strut brace installed, if that matters at all, but did not start happening right after. I can't think of anything (bad potholes, bottoming out, etc.) that might have precipitated it. |
07-25-2010, 01:58 AM | #8 |
Imola Lover
26
Rep 749
The sway bar issue is usually accompanied by a groaning with the popping. I'm wondering if perhaps you have e-brake issue... Have you changed to aftermarket rear brake pads?--And if so, could it just be pad knock-back due to not exact fitment?
07-25-2010, 02:01 AM | #9 |
Όλα ρόδες
760
Rep 561
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
07-25-2010, 09:57 AM | #10 |
Rep 10
Are the braces torqued correctly?
I had a situation where sometimes would get a pop, sometimes a creak, sometimes both when driving over an elevation change, more dramatic when going over a curb one wheel at a time (body flexing a little more). |
07-25-2010, 10:09 AM | #11 | ||
Rep 1,143
Do you mean the front firewall braces or the rear sway bar? I didn't really have enough clearance or the right tools to get a torque wrench back there. Haven't checked the front braces but I would suspect the sound would be coming from the front in that case... |
07-25-2010, 10:45 AM | #12 | |
Rep 725
07-25-2010, 01:41 PM | #13 |
Rep 10
I'm talking about the braces that run from the rear differential to in front of each rear wheel. My car had the sound coming from the back trunk area like you describe that went away after torquing these down. I assume the M's have these braces as well?
07-27-2010, 09:07 PM | #14 | |
Custom User Title
149
Rep 661
Yes they do. Good idea, can't hurt to torque them to spec. |
07-27-2010, 09:09 PM | #15 |
Custom User Title
149
Rep 661
Also - the bushings may just be dry inside. You can try lubricating them with some high quality grease[ 3M makes a pure silicon grease] or teflon grease. I would not recommend a spray as they don't last very long.
07-28-2010, 07:46 AM | #16 |
Rep 1,143
Thanks for the suggestions, folks. I left the car at the dealer yesterday and hope that they'll be able to recreate the problem today. It happened twice during an initial ride with the SA, but then the next day I took a ride with the tech who would be looking at the car and couldn't get it to happen. I did pull the parking brake while coasting to a stop from low speed a few times as someone suggested in another post, so I wonder if that might have fixed it. They suggested I just leave the car overnight and have them take a ride in the morning. Seems like that's when it's most noticeable for me.
jragan - forgot to mention, all brakes are stock. rclem05 - if the bushings were dry, wouldn't the sound be a more constant rubbing? |
08-07-2010, 11:31 AM | #17 |
Rep 1,143
Anyone off hand know what the torque spec for these bolts are? They don't *look* loose, but it's hard to tell.
The dealership could not reproduce the issue on a few drives, but did a complimentary inspection and found everything to be sound. Interestingly enough, that day the sound seemed to be entirely absent, but now it's back with some regularity. Still impossible to reproduce reliably. Often happens during bumps/turns but not always. I'm going to take a look at the top of the strut housing inside the trunk later on. |
08-07-2010, 11:39 AM | #18 | |
Bad Lieutenant
233
Rep 3,517
http://www.nord-lock.com/default.asp?url=1.16.37 So they don't come loose as easily.
08-07-2010, 06:49 PM | #19 | |
Rep 10
