08-02-2023, 06:54 PM | #1 |
Rep 27
Valve Cover bolt stripped...
Long story short, while cleaning the engine I noticed some oil seeping around 2 bolts of my valve cover. Thinking they were loose I tried tightening one and over did it, now the bolt is spinning freely . Definitely killed the mood for the day and major lesson learned...
Just wanted to know if anyone had experience fixing this sort of problem? |
08-03-2023, 04:51 AM | #2 |
Rep 783
I've run into a few times on used cars I've picked up over the years, if you want a simple quick fix then a Helicoil will do the job, if you want to fix it permanently then Timesert is the way to go. https://www.timesert.com/
2008 E86 M coupe
08-03-2023, 07:47 AM | #3 |
Rep 12,569
Echo the above, I’ve used helicoil before and they work fine. Just to be clear, I get the thread are stripped but did the head snap off or are you at least able to pull the bolt out?
MVRS4.50 |
08-03-2023, 08:55 AM | #4 | |
Rep 27
08-03-2023, 09:02 AM | #5 |
Rep 27
The bolt is still intact, I am able to bring it up, but not fully out. Do you remember the size or specs of the helicoil you used?
08-03-2023, 11:50 AM | #6 | |
Rep 12,569
Quick search on zpost: https://www.zpost.com/forums/showthread.php?t=1908085 |
MVRS4.50 |
08-03-2023, 12:13 PM | #7 | |
Rep 27
Really appreciate the help! |
grannyknot953.00 |
08-04-2023, 10:03 AM | #9 |
Rep 27
Spinning freely. It stripped the hole because I see some of the aluminum shavings came off the bolt. Ima try your recommendation of the pliers over the weekend. Seems like if I can get that out, it should be easy to apply the helicoil/time sert without removing the whole cover.
02-04-2024, 09:01 AM | #10 |
Rep 21
Drives: 2006 Z4 3.0i 6spd manual
I broke 2 while changing the valve cover gasket. I used a craftsman drill/extractor. The bolt is aluminum with not much torque, came out pretty easy I purchased a complete bolt set from the dealer, around $70.
MVRS4.50 |
