05-17-2011, 04:11 PM | #23 |
instagram 997turbotom
286
Rep 7,377
I hope VAC motorsports will figure it out, meanwhile someone came from AAA to pick up the car from the dealer, and refuses do so because I'm not there. Wasn't a problem getting it to the dealer without me yesterday, so I told AAA to have another company pick it up. Testing my patience...
05-17-2011, 10:59 PM | #24 |
Rep 457
They're doing you a favor keeping it from VAC motorsports. They are the WORST.
Good luck bud, hope you're one of the few lucky ones that actually has a good experience with them. Mine was nothing short of HORRIBLE.
05-17-2011, 11:06 PM | #25 |
286
Rep 7,377
VAC quoted me $600 less than the dealer, and I've had mostly good experiences with them. What did they mess up with you?
05-18-2011, 11:42 AM | #26 |
Rep 457
Other than dropping my car on a rinky dink oem jack on uneven gravel filled road - damaging my rear quarter panel and side skirt, completely blowing out my cv boots/joints on my axles because they put my car back on the ground without the rear springs in place (e30 GC coilovers, if they're the e30 guru's they claim to be they should have known better), putting 60 miles on my car with absolutely ZERO reason to drive it ANYWHERE for the work they were doing, and denying to warranty poor motor work that they did - well, I guess nothing.
Seriously, good luck dude. Wish you the best. I'll never set foot in that place again. And I've already spent 5+ G's there. Makes me sick..
05-18-2011, 12:14 PM | #27 | |
Rep 844
05-18-2011, 02:05 PM | #28 |
286
Rep 7,377
I've been a happy customer on and off for about 5 years now. I'd rather have them do the work than the dealer.
05-18-2011, 02:07 PM | #29 | |
286
Rep 7,377
05-18-2011, 02:15 PM | #30 |
286
Rep 7,377
they're also recommending an ECU update, has anyone heard of such a thing? (not an aftermarket performance update)
05-18-2011, 02:36 PM | #31 |
Rep 844
What does the update consist of? I swear I remember reading someone else said there was an ECU update for Z4M's. I'm curious if it addresses the issue where the revs drop down to 400-500 when sitting idle. It's as if the car is about to die but quickly comes back to life. Last time it happened was over a week ago though so it doesn't occur very often.
05-18-2011, 03:07 PM | #33 |
707
Yes, I've heard of the ECU update. Got it. Indie shop installed it 'cause I didn't have time to run to the dealer 1 day before a track day. Car died/dies at idle (and did so as they were taking it off the shop floor). In my case something to do with the accelerator module/coding part in the ECU programming IIRC. Also IIRC this doesn't apply past a certain build date (I see you have an 06) so it's plausible you need it.
Don't have my car folder/papers here at work to look up software version or so on. Think the flash cost me 90 bucks--way cheaper than a missed track day and lodging costs. |
05-18-2011, 03:18 PM | #35 |
707
Hi, looked at the dx of throttle this or that on your earlier post.
That rings a bell with what the software update addressed in my case. You may be in luck, it may be a simple flash to fix it. (Hope hope hope!) My car just died and threw a hell of a lot of codes. (It was kind enough to do it after having the alignment done and at the indie shop, so no harm no foul.) |
05-18-2011, 10:58 PM | #36 | |
Rep 457
but, taking my literal blood and sweat filled non-m e30 that I was $25k deep into for JOY RIDES home has NOTHING to do with any amount of "high volume business." I'm done talking about them.. but do update this thread and let us know how you made out. Sounds like that dme update may be promising.
05-18-2011, 11:35 PM | #37 |
286
Rep 7,377
the dme update worked. more or less. No codes, no limp mode for 30 miles yet. I was told it'll take 50 miles for the computer to adjust. As of right now, the throttle doesn't feel as linear as before at light load. Almost as if it hesitates a little bit, and then overcompensates a bit. Only under light throttle. I'm hoping it'll even out after a few more miles and cold starts
05-18-2011, 11:44 PM | #38 | |
Rep 457
05-18-2011, 11:48 PM | #39 |
707
Encouraging! Mine was a bit "off" to but then I put 200 miles and a track day on it. 1k miles later and all is well. I think the reflash clears all adaption values and the DME needs to acquire data and adjust.
05-19-2011, 12:18 AM | #40 |
Rep 1,663
Good news!
I wonder what the last DME version is and if it's worth it to upgrade preventatively.
05-19-2011, 10:19 AM | #41 |
286
Rep 7,377
back to the shop. hahaha. dme upgrade was only a patch. time to replace the throttle actuator unit, or whatever its called
05-19-2011, 03:03 PM | #43 |
286
Rep 7,377
Good thing I went on intuition, and signed up for AAA right before my 1st of 3 tows. Still paid $100 to sign up + $4/mile, but less than $450 or so I'd have shelled out otherwise
