05-13-2011, 09:45 AM | #1 |
instagram 997turbotom
279
Rep 7,376
Limp mode?
I got:
orange brake light ELM Check engine Traction control car jerks around, rpms fluctuate, and stalls after 10 feet What does this sound like? Stock drivetrain
05-13-2011, 10:04 AM | #2 |
Rep 120
I had the EXACT same symptoms.
Open the hood, and cycle the key from the off to the "on" position (just before the car starts) after waiting 5 to 10 seconds and you should see the Throttle valves run a diagnostic sweep each time. If they do not then one of your two throttle position sensors is screwed. There is one on the very front of the throttle assembly (easy to change), and there is another beside the throttle motor under the intake manifold ( a bitch to change, requires removal of the intake manifold). The other thing it COULD be is the actual throttle motor, but a technician has to hook up to the car and manually activate that part to check it. The throttle position sensors are FAR more common though. good luck! |
05-13-2011, 10:06 AM | #3 |
279
Rep 7,376
Thanks man! From playing mechanic on google, it looks like other e46 people are replacing throttle position sensors.
Part # 13637840383 right? I'll have to wait till tomorrow to get the codes read
05-13-2011, 10:20 AM | #4 |
279
Rep 7,376
Forgot to mention that 20 seconds before this happened, my radio lost volume and the function to switch radio stations. Maybe its just the battery...
05-13-2011, 10:41 AM | #6 |
Rep 698
Hmmm...Mine if i'm going full throttle traction control will kick on so hard it's like it's slamming on the brakes on the front right then it'll do it on the rear right then the orange brake light will be on, car still will run fine. But this is happening at like the top of third gear so you can imagine the car braking on its own at close to 100 is pretty scary. Anyone else's car do this?
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
05-13-2011, 10:51 AM | #7 | |
Rep 120
05-13-2011, 10:54 AM | #8 |
Rep 659
Garage List 2022 M5CS [0.00]
It could just be a electrical glitch. I know that sounds strange, but it does happen. I lost all audio on my radio once. I cycled the key and its fine now, and has never had a problem since then.
If you were closer I'd offer to help you read it with the GT1 I have...
05-13-2011, 12:44 PM | #12 |
Rep 2,431
mine did that twice to me, disconnecting the battery for a minute helped it get out of limp mode. I attributed it to a low battery
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
05-14-2011, 05:12 PM | #16 |
279
Rep 7,376
local shop got the codes, but wants me to take it to the dealer since they don't know what they mean. getting codes:
P1637-throttle valve position control, control deviation P1417-???
05-14-2011, 06:31 PM | #17 | |
Rep 698
05-17-2011, 03:03 PM | #20 |
279
Rep 7,376
its not looking good...
throttle actuator assembly + throttle sensor quoted $1620 +, assuming my DME was not fried.. fuck calling a BMW race shop...
05-17-2011, 03:48 PM | #22 |
Rep 120
Seems pretty unlikely it would be the throttle position sensor AND the actuator assembly. The shop should have been able to eliminate one or the other as a possibility without changing them both wholesale.
