02-02-2013, 06:42 PM | #23 |
Save the Manuals
1718
Rep 2,940
I have looked into TWS in-depth with one of its design engineers and he himself states it is closer to a 0w-40.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT Last edited by G80indy; 11-06-2013 at 10:02 AM.. |
02-02-2013, 07:26 PM | #24 | |
Car Geek
3730
Rep 3,633
Please provide all the info you have from your in-depth discussions with the S54 design engineer, as this will be valuable information for the BMW community, especially any amount of quantative data you can lay your hands on. I may change to another oil myself, but I'm waiting for others to experiment for a couple of years before I make my decision. Last edited by aerobod; 02-02-2013 at 07:44 PM.. |
02-02-2013, 07:59 PM | #25 |
Save the Manuals
1718
Rep 2,940
over at BITOG
from PM with me over at BITOG, a while ago now!
(courtesy of Mr. Doug Hillary) "Hi, as requested and as sent off to others: STARTS Hi, I first used Castrol's R 15w-50 (castor based) great smell - in 1978 In 1980 I commenced a Senior Technical position with a major International Company whereby I could try new technologies and the like We (Castrol & I), first decided to test the product in late 1980 a wide range of engines; Diesel 4cyl IL Isuzu, Kubota, Benz 3cyl IL Kubota Petrol 6cyl IL Nissan 4cyl IL Mitsubishi 2cyl Horizontal (air coooled) Castrol reformulated the "R" to a non castor lubricant early in the test programme The tests involved stationary and mobile engines in ambient temps ranging from -6C to 50C Regular UOAs were done to monitor the lubricant's condition and some engine tear downs were undetaken. The tests lasted until 1985 and covered hundres of thousand of hours of use A number of minor formulation tweaks took place which I was a part of of course Later (in 1986) an employee of mine (an Automotive Engineer) from IH - Mercedes Benz was employed with my help by Castrol as a Lubricant Engineer. This rekindled the testing regime again in 1989 but this time it was with HDEOs. He remains with Castrol today as a Senior Lubricant Engineer and we are still excellent friends of course I continued to use Castrol R 10w-60 (from 1980) until 1999 in a variety of engine families and random UOAs were carried out The lubricant 10w-60 is very durable and during the tests in the early 1980s were were able to get up to 4000hrs service before OC. We averaged about 2500hrs. We averaged 80km/h (50 mph) here in this test regime" Regards Doug Hillary ENDS _________________________ Regards Doug 06/18/08 12:00 AM Re: Castrol 10w-60 Doug Hillary Hi, I cannot provide more data than you probably already have But this might help you 1 - ALPINA worked on its formulation with Castrol/BMW 2 - It suits DI engines due to its viscosity namely HTHS @ 5.4cP 3 - It has an excellent Pour Point (-42C) which is much better than some lighter viscosity lubricants 4 - It was progressively developed from 1997 as a low chlorine/minimised phosphorous lubricant Its part ester/part PAO base has been constructed over a period of 30 years on an excellent development path In its early life is was used by Sauber-Mercedes winning at LeMans and in Formula 1 engines (Ford-Cosworth). It was used at one point by Porsche in some race engines. It was also used here in the V8Supercars ZF six speed gearboxes with great success It is a bit like a heavy weight version of M1 0W-40 or Delvac 1 5W-40 in its formulation END _________________________ TWS is good stuff, no doubt. Just prefer the Redline... There are more posts.... It's basically this: As of 11-'13, after acquiring the S65 in the e92 M3, I may be changing my tune in favor of the slightly thinner TWS.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT Last edited by G80indy; 11-06-2013 at 10:05 AM.. |
02-02-2013, 08:26 PM | #26 |
Rep 400
Man I love this thread, for every 5 minutes I spend reading other posts I'm searching the internet for another 30 minutes to try to verify info and learn more in depth about oil properties.
What I gather from all this is that maybe BMW wants a slightly thinner oil to improve flow through bearings. This will result in a thinner film of protection for the bearings but at a slightly higher flow. There is not a dramatic difference in 100C viscosity between the two Castrol oils (about 1.1%). If I decide to switch, I think I would go with redline. It won't change viscosity at higher temps as much as TWS because Redline has a higher VI. It has a higher HTHS number meaning it will offer a slightly thicker film to protect bearings better. |
02-03-2013, 02:06 PM | #27 |
Save the Manuals
1718
Rep 2,940
(courtesy of Shipkiller)
http://www.shipkiller.com/Z4M_Specific_Oil_Page.html the specs for these oils are in a spreadsheet/ NICE WORK! http://www.redlineoil.com/product.aspx?pid=130&pcid=21 API Service Class SM/SL/SG/CF SAE Viscosity Grade (Motor Oil) 10W60 Vis @ 100°C, cSt 25.5 Vis @ 40°C, cSt 173 Viscosity Index 182 CCS Viscosity, Poise, @*C 65@-25 Pour Point, °C -45 Pour Point, °F -49 Flash Point, °C 257 Flash Point, °F 495 NOACK Evaporation Loss,1hr @ 482°F (250°C), % 6 HTHS Vis, cP @150°C, ASTM D4741 6.7
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
11-06-2013, 10:06 AM | #28 |
Save the Manuals
1718
Rep 2,940
Edge Professional TWS 10w-60
Density @ 15 ̊ C, Relative g/ml 0.853 Viscosity, Kinematic 100 C mm²/s 22.7 Viscosity, CCS -25 ̊ C (10W) mPa.s (cP) 4879 Viscosity, Kinematic 40 ̊ C mm²/s 160 Viscosity Index 173 Pour Point °C -39 Flash Point PMCC °C >200 Ash, Sulphated % wt 1.29 not sure what the HTHS is.... anyone?
2023 G80 6MT, CCBs
11-06-2013, 10:28 AM | #29 |
Mechanical Engineer
96
Rep 1,025
bavarian specialties in Philadelphia/King of Prussia runs the LubroMoly 10-60 in all their race cars. just another data point.
I would be temped to try RedLine before LubroMoly. Larger company, less chance of quality variations due to better developed manufacturing processes. |
12-19-2013, 10:27 PM | #30 |
Rep 2,882
Here's one more data point, in case anyone is interested
http://www.m3post.com/forums/showthread.php?t=926080 |
12-20-2013, 07:52 AM | #31 |
Rep 452
Thanks for posting this, XMetal. And thanks to Indy, for taking the time, effort and expense!
11-15-2014, 09:36 AM | #32 |
Save the Manuals
1718
Rep 2,940
Now that Shell is in bed with BMW, and may provide BMW a dedicated GTL 10w-60 oil, (all speculation), there will likely be gnashing of teeth that boutique TWS is no longer the exclusive fluid for M cars.
I find it interesting the TWS formula changed, with pour point less extreme. Wasn't it -51F ? Perhaps less ester base? Also that Redline has changed over the last couple years from 6.7 to 5.8 HTHS. That is interesting--- less extreme for a 10w-60. It's relevant, since we do not know how exceptional for M engines that Shell product will turn out to be, at least in view of the peanut gallery (forums)
2023 G80 6MT, CCBs
