      08-24-2013, 12:28 AM   #23
Vanne
Vanne's Avatar
United Arab Emirates
1624
Drives: 2007 Z4MC
Is it sorted now or still doing it??
      09-01-2013, 04:15 AM   #24
E86Z
Drives: 3.0si
i'm sure i have this exact problem but I'm no longer under warranty.. how long would it take an indy shop to resolve such an issue?
      09-01-2013, 09:19 AM   #25
WhoU4
WhoU4's Avatar
Drives: '05 Z4 3.0i
I had this done in 2010 and it's been nice and quiet since.
I'm guessing at least two hours since I believe they drop the heat shield, exhaust, and drive shaft to complete the work on the input shaft.
Dave
OEM Strut Brace / UUC SSK / Zeck CDV / Clutch Stop / ZHP Shift Knob / Stubby Ant / Top Covers / Dinan K&N / M Seats / SP / PP
      01-18-2014, 06:28 PM   #26
Yvette
Drives: M
can any indie can do this work? I hate this clunk... feels like a cheap car and sounds like its breaking something
      01-18-2014, 06:34 PM   #27
Yvette
Drives: M
Originally Posted by WhoU4 View Post
Well mentioned the Clunk issue again while in at the dealer for a coolant flush, and they were able to reproduce the noise. Last year I was told it was normal, this year the dealership said they would need the car for more time to diagnose. Anyway I took her in yesterday and received a call that they found a TB (SIB) that should address the issue and that they ordered some parts.
Picked up the car today and it's as quiet as could be.
The clunk, or "creaking", was coming from the input flange of the differential. Following the SIB they removed flange, applied grease (CASTROL OPTITEMP HT) per SIB. Parts replaced, Input Shaft Seal and Securing Plate.
http://www.realoem.com/bmw/showparts...42&hg=33&fg=05
Will see how she holds up.
what numbers in the illustration you replaced?
grease only in the flange area?
      01-19-2014, 09:59 AM   #28
abashoe
Drives: 2008 335xi
Is this the same as the "M" clunk? Or is this something different?
      01-19-2014, 03:48 PM   #29
AmmarYasirA
Ammar
AmmarYasirA's Avatar
Drives: a lot
...I hear a clunk when I push the clutch in ?
2018 F150 Platinum - Black/Black - Leveled on 34's - DD
      01-19-2014, 08:37 PM   #30
WhoU4
WhoU4's Avatar
Drives: '05 Z4 3.0i
e90sexion,
Yes this is something you could have an indie shop perform, or if you have access to a lift even a DIY. Mine was under warranty at the time so I took it to the dealer.
They removed the flange and greased as per the SIB with BMW's Optitemp HT1LF grease, and replaced the rear differential input shaft seal (Number 9 on the parts list).
Hope this helps.
Dave
abashoe and AmmarYasirA,
I'm not sure if it is, when I first posted some thought it might be similar. I could hear the clunk letting off the clutch while taking off in lower gears and at times slowly approaching a stop sign or stop light when the clutch was depressed. Not sure if this is even an issue with the M-differential.
Dave
      01-19-2014, 08:39 PM   #31
Kgolf31
Kgolf31's Avatar
461
Drives: 2007 Z4MC, 2012 128i
Our clunk with the M cars are related to the Dual Mass Flywheel.
      01-19-2014, 09:23 PM   #32
just2talented
just2talented's Avatar
Drives: Alpine ///M roadster
WHS
clunk is normal, we have a "heavy duty clutch" as BMW calls it. You just have to double clutch a bit at low speeds. Ive had it since day one, we all have if you don't give it a little gas. Totally normal, worry more about the 2nd gear grind, my synchro is now shot and im looking at ALOT for a rebuild.
