09-01-2013, 09:19 AM | #25 | |
Rep 352
I had this done in 2010 and it's been nice and quiet since.
Dave
OEM Strut Brace / UUC SSK / Zeck CDV / Clutch Stop / ZHP Shift Knob / Stubby Ant / Top Covers / Dinan K&N / M Seats / SP / PP |
01-18-2014, 06:34 PM | #27 | |
Rep 7,408
grease only in the flange area? |
01-19-2014, 03:48 PM | #29 |
Ammar
73
Rep 406
...I hear a clunk when I push the clutch in ?
2018 F150 Platinum - Black/Black - Leveled on 34's - DD |
01-19-2014, 08:37 PM | #30 | ||
Rep 352
Yes this is something you could have an indie shop perform, or if you have access to a lift even a DIY. Mine was under warranty at the time so I took it to the dealer. They removed the flange and greased as per the SIB with BMW's Optitemp HT1LF grease, and replaced the rear differential input shaft seal (Number 9 on the parts list). Hope this helps. Dave Quote:
I'm not sure if it is, when I first posted some thought it might be similar. I could hear the clunk letting off the clutch while taking off in lower gears and at times slowly approaching a stop sign or stop light when the clutch was depressed. Not sure if this is even an issue with the M-differential. Dave
01-19-2014, 09:23 PM | #32 | |
Rep 185
clunk is normal, we have a "heavy duty clutch" as BMW calls it. You just have to double clutch a bit at low speeds. Ive had it since day one, we all have if you don't give it a little gas. Totally normal, worry more about the 2nd gear grind, my synchro is now shot and im looking at ALOT for a rebuild. |
