      04-04-2011, 08:38 PM   #23
Shipkiller
Shipkiller's Avatar
Drives: Me
Originally Posted by Kgolf31 View Post
Preventing your torso from going forward is the worst part? Explain?
O-cha may have a better explanation that I do because he has a little more track time than me.
Keeping your upper body planted in the seat does several things.
You expend a lot of energy just trying to keep yourself in the seat. This drains you faster and you loose your mental edge faster. The mental keeps the physical going. If you start to lose your mental edge on the track, you are done.... This is one of the reasons real race car drivers are such athletes. After a 45min to an hour on the track, I am puddy and need that time between events to recover.
You also are holding yourself in place with your arms/hands attached to the wheel so you also lose some of your 'touch'. You grip the wheel harder so steering inputs gets rougher and you are not controlling the car as well. You also start steering with your arms and not using your back muscles in conjunction with your arms. You also have a tendency to throw you elbows out a little magnifying the effect. Hands, wrists, arms, shoulders, back muscles all work together in harmony.
When you loose touch with the seat, you also losing touch with the car. Now you can't feel as well just what it is doing. Muted inputs.
      04-04-2011, 08:54 PM   #24
Kgolf31
Kgolf31's Avatar
461
Drives: 2007 Z4MC, 2012 128i
Yea, that makes sense...I completely re-read that part wrong.
I read it as "Preventing your torso from going forward (As in using the seat-belt to prevent your body from going forward) is the worst part."
Not as in using your arms to prevent your body from going forward.
Thanks though for the clarification anyways
      04-04-2011, 09:17 PM   #25
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by jragan View Post
You can also achieve the same result (if you have power seats) by moving your seat back away from your normal track-seating position by 6 inches or so, jerking the shoulder strap to lock it and then move your seat forward to your track-seating position. If you do this correctly, the seat-belt will stay locked. The trick is that you should move back far enough that when you return forward the shoulder strap should be a touch over uncomfortably tight (things will loosen a tiny touch as you start driving).
^WHS x1000
I can also do it with my manual seat.
      04-15-2011, 10:29 AM   #26
runnerx
runnerx's Avatar
Drives: 06 M roadster; 06 330i 6spd
I never slide around in my stock seat maybe I haven't driven hard enough. I will try harder next time to see if I slide...
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual
2006 BMW 330i 6spd manual - gone
https://lh5.googleusercontent.com/--bIgrh8ES_s/TxSUCvOmDUI/AAAAAAAAPh0/OOjwrRZtta0/s912/z4mcomparo.jpg
      04-15-2011, 11:25 AM   #27
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
You may think you don't (I didn't)
Once you experience being strapped in, it's amazing how much better it is.
      04-15-2011, 12:57 PM   #28
runnerx
runnerx's Avatar
I will try out jragan's method May 28th Thunderhill. Anyone coming?
2009 BMW X5 4.8i
      04-15-2011, 01:48 PM   #29
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Solo filled up before we sorted out our schedule so "no". I really wanted to do that one. We're going to have to shoot for Monday June 6th at T Hill assuming I can get the day off.
I would not be surprised to see you shave off a few seconds by being secured in the seat. It's a lot easier to be precise when you're not using the wheel and your feet/legs to hold you in place! I was surprised how much effort I was expending on staying put by using arms, legs, back, and feet.
      04-15-2011, 02:39 PM   #30
runnerx
runnerx's Avatar
argh.. that explains why I have stiff arms and legs after tracking...
I will miss 6/6 event but I will be there on 6/24. Hope to see you all there again.
2009 BMW X5 4.8i
      04-16-2011, 12:35 AM   #31
Skelekitty
Skelekitty's Avatar
42
Drives: '07 Imola Red Z4 MCoupe
2007 M Coupe  [10.00]
6/24???? Gee, that would be an awesome way for me to celebrate the big Four-Five (happening the day before!).
~Krissi~ '07 Imola Red Z4 MCoupe
Eisenmann Sport Exhaust | RE X-Pipe | RE Transmission Mounts
      04-16-2011, 12:47 AM   #32
Finnegan
Finnegan's Avatar
Hmmm. I think that's what they call a "hint" guys.
      04-16-2011, 11:41 AM   #33
Shipkiller
Shipkiller's Avatar
Drives: Me
See, you can be trained......
      04-16-2011, 02:08 PM   #34
Finnegan
Finnegan's Avatar
Ain't that the truth!
      04-16-2011, 02:19 PM   #35
jdl1pt
Drives: Z4M coupe 2007 IL Blue
Sounds like a "hint" to me. FYI, Ron and I are thinking of going that day. Oh and not to . I got the cg lock and it works well. Nice addition for 38 bucks.
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit|
      04-16-2011, 07:40 PM   #36
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Tested one of these out this weekend and it works great, I took a good friend out, and he was laughing at me because he was sliding all over the place and said I really could use seats and harnesses, I told him I'm not having any problems now that I got the CG Lock.... but not on the passenger side
2004 Porsche GT3 |White
HRE R40 Monoblocks | KW Clubsport Suspension | RSS Lower Control Arms and Suspension Links | GT3RS Wing and Front Bumper | Cup Car Lip | Euro GT3 Seat | GMG Half Cage | Europipe Exhaust | EPL Tuning
