09-27-2010, 11:52 AM | #1 |
Rep 1,143
Ugh, drove with the gas cap open
Stupid confession:
I arrived at the track this weekend about 30 miles from where I filled up and noticed, much to my great chagrin, that my gas cap was off. The only possible explanation was that I simply forgot to cap off the tank after filling up (a first). I'm still pretty perplexed as to how I didn't notice this even in my mirror aside from the fact that it was very early in the morning and still dark. Anyway, most of the drive was highway but about a 1/4 mile was over a gravel road where the cars in front of mine kicked up some pretty mighty clouds of dust. My car arrived with a light film of dust over it but the gas tank opening didn't look visibly dirty. However, I'm wondering if I should be considering changing out the fuel filter. Car is at about 18600 miles or so after the weekend. Oddly enough, I didn't see that a fuel filter replacement was ever listed on either the Inspection I or Inspection II checklists -- is this supposed to be a "lifetime" part? I haven't noticed anything negative in terms of performance. The engine felt strong and responsive both days and my fuel economy on the 3.5 hr drive back home seemed as good or better than it ever has been, so I'm wondering if I'm getting all worked up over nothing. |
09-27-2010, 12:25 PM | #2 |
///M-fanatic
193
Rep 3,885
lol don't worry about it dude. I've never done this before, but I'm pretty darn sure there's nothing wrong with your car. You probably didn't notice the gas cap thing because the fuel door was probably slightly shut due to air turbulence when you were driving after the fill-up. In which case, you're even more safe, since the filler door probably by-passed over 90% of all the debris. Thennn you've got the actual little metal sliding plate where the fuel nozzle goes. That will act as your second "door" to block out debris. And fuel should be evaporating ever so slightly out of the uncapped portion of your filler. I would say all of that adds up to blocking almost 100% of all debris. So I wouldn't worry about this incident at all
09-27-2010, 02:01 PM | #3 |
Raw Conscript
Rep 37
I failed to tighten mine properly and the computer threw a CEL light in less than a mile. I immediately stopped but after tightening it, it still took several cycles before it disappeared. Anyway, even if some dust entered your tank, the particles are very small and if not trapped by the filter, I don't think they would cause trouble.
09-27-2010, 02:37 PM | #4 | |
SSGT USMC - '78 - '86
13
Rep 487
Drives: Z4 3.0si
Not in my Z.. but in wife's 325ci we had the light on dash come on shortly after filling. took cap off/on twice and drive a little bit before it cleared. I am surprised you did not get a warning light on dash. Either way, you should be fine.
Thanks,
Bill 2007 3.0si Roadster Black/Red, sport, Piano Black F14 Forgestar's |
09-27-2010, 03:03 PM | #5 | |
Rep 2,128
09-27-2010, 03:44 PM | #6 |
Certified Adrenaline Junkie
43
Rep 1,325
Car is ruined, might as well sell it to me on the cheap
I think you should be fine. Little grit in the tank won't hurt much. God made dirt, dirt don't hurt. If it is large enough, it would get caught by the filter. Smaller stuff won't cause a problem. |
09-27-2010, 04:52 PM | #7 |
Rep 2,782
What's odd is we actually have a "check gas cap" light. The only time I've actually seen it illuminate was when I drove off from the gas station, saw my fuel door open, stopped and closed it... THEN the "check gas cap" light turned on. I turned off the car and restarted it - no light. Maybe it can only sense a change in the gas cap's state and not its position?
09-27-2010, 06:17 PM | #8 |
Rep 1,351
Drives: in Anger.
Well It might be harder than you think. Please correct me if I am wrong but isnt there a filter on the pump inlet that is inside the fuel tank. This is very common with most modern cars....
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs 1217/1815 !!! BOILER UP !!! |
09-27-2010, 10:18 PM | #9 |
Rep 1,143
Yeah, weird thing is that my CEL never came on. I thought that it would if the cap was loose or not on at all. The last time I saw a CEL was on my '04 RX-8, and it was when I hadn't tightened the cap the full 3 clicks, so I'm surprised that it didn't come on in this case.
I guess my only concern was that if any crap got in the tank it would prematurely clog the fuel filter, but it sounds like I shouldn't be stressin'. Thanks everyone. |
