09-25-2010, 01:27 PM | #1 |
Rep 2,882
Drives: Anything
Another Battery Question
When did BMW start fitting AGM batteries in the M? RealOEM.com list an AGM for the M roadster and coupe, but I was surprised to see that my '08 M Coupe had a vent tube connected to the battery, which was obviously not an AGM. Anyone have any insights? Does anyone here have the OEM AGM battery in their Z4M? Just curious.
BTW...the OEM AGM battery list for > $400 |
09-25-2010, 01:45 PM | #3 |
///M-fanatic
193
Rep 3,885
My Z4MC has a build month of December 2006, so is a 2007 model. Let me go check the battery real quick...
edit: errr...I could only find on the label "S: 61 21 7 553 952" When cross-referencing this # on RealOEM, this is what came up: http://realoem.com/bmw/partxref.do?part=61+21+7+553+952 WTF, it says that this part # battery is for E46 non-M's...?!?! And this is the only Z4M battery link I could find: http://realoem.com/bmw/showparts.do?...12&hg=61&fg=30 How can I tell if it has an Absorbing Glass Mat in it or not : ? Last edited by mfanatic325; 09-25-2010 at 02:23 PM.. |
09-25-2010, 06:56 PM | #6 |
Rep 1,855
I have the black one too. A battery is a battery, though.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
09-25-2010, 07:01 PM | #7 |
Rep 1,855
I have the black one too. A battery is a battery to me, though.
09-25-2010, 07:22 PM | #9 | |
Rep 421
Has a vent. 61 21 7 553 952 AGM retails for $204. 951 AGM comes with the car. One number less. That's how they know. http://www.bimmerfest.com/forums/showthread.php?t=50935 |
09-25-2010, 08:41 PM | #10 | |
Rep 2,882
Drives: Anything
09-25-2010, 09:14 PM | #11 |
///M-fanatic
193
Rep 3,885
Okay so mine adds up technically, because I have the full service record for the car (since I'm the 2nd owner). And it states that the battery was replaced early 2009. So I should have another year left or so, approximately, before it'll need to be replaced =P
09-25-2010, 09:28 PM | #12 |
Rep 421
09-25-2010, 09:44 PM | #13 |
Rep 2,882
Drives: Anything
Realoem.com shows the AGM battery for $400 => http://www.realoem.com/bmw/showparts...12&hg=61&fg=30
09-25-2010, 11:40 PM | #14 | |
Rep 421
Maybe they do now. I purchased 61 21 7 553 952 AGM. Retails for $204 now. I purchased it back then less than a $100. No shipping since it's picked up local. North Haven in CT gives 25% off from retail. You can order it from any dealer and pick it up local. It shows that with the link I posted earlier. Not sure what they are using now. Can also go to www.eastpenn-deka.com for less. |
09-26-2010, 01:04 PM | #15 |
Rep 2,882
Drives: Anything
Thanks Ron!
I found one of your post over on bimmerfest => http://www.bimmerfest.com/forums/sho...t=50935&page=2. That post showed that you didn't need the vent tube. In the post above, you mentioned that you have re-installed the vent tube. Did the AGM battery that you got had a vent hole? Does AGM battery require venting like lead-acid? Do you know why some AGM have vents and others do not? |
09-26-2010, 01:50 PM | #16 | |
Rep 421
The two I have, have vents. The Deka one does too. Like I said, I think that it vents on a fail. Call Exide or eastpenn-Deka and see what they say. |
09-26-2010, 02:06 PM | #17 |
Rep 421
AGM batteries are becoming the preferred battery for marine use. They excel because they will typically give you several years of maintenance free service. Unfortunately, most AGM batteries vent at 1-2 PSI causing them to corrode surrounding electronics similar to the Gel batteries. Almost all AGM’s today use recycled lead shortening their service life. They are typically more sensitive to charging than a flooded battery; however they are less sensitive than a gel. There are many AGM’s on the market so don’t just go out and buy an AGM battery and think you have the best. You may have been better off saving that additional money you just spent and bought that 100 year old technology found in a new flooded battery.
