      04-05-2010, 12:27 PM   #1
DWG
Drives: 2006 Z4M
Hang-up lowering top
I have a slight hang-up in left hand (driver side) top release latch. If you wiggle or push - pull the top is easily comes loose. Is the brackert adjustable? Is this just a trip to the dealer? Top locks fine when closing. Thoughts? Dave G.
      04-05-2010, 07:09 PM   #2
Shipkiller
Shipkiller's Avatar
Drives: Me
I had the same problem on the Roadster.
Lubricated the roller. That fixed the issue.
      04-14-2010, 02:52 PM   #3
DWG
Drives: 2006 Z4M
Did some looking when a screw fell on MSOHW. All but one of the small screws that hold on the plastic under cover on hte bottom side of the front of the top are gone. Suspect that is what is hanging up the top. Thanks for the suggestion will do that to. Except for battery replacement, this is first trip to dealer in 17K miles.
