      05-28-2009, 06:27 PM   #45
Chuck I
Chuck I's Avatar
Drives: '03 Z4 + '07 ///M Roadster
z4dawg
z4dawg... remove your ashtray (where you have your Aux connector). It will be tough, but try to feel on the left side (drivers side) and see if you have any cables coming up and going back along side the transmision.** I found mine where I have your picture marked (under the carpet).. Chuck I
      05-28-2009, 06:30 PM   #46
z4dawg
Drives: Bright Red '06 3.0i Z4
Ok, do you mean flush against (but on the inside of course) where my right leg would rub against the center divider while I drive?
Additionally, what is the VM module?
I'm about to have dinner but I'll give it a go later tonight.
      05-28-2009, 06:31 PM   #47
Chuck I
Chuck I's Avatar
Originally Posted by Ron Stygar View Post
Ron, something interesting.... I put a volt meter on pin 5 of the connector... the one going to the VM module... I read 3.38 volts... that's strange. I"m wondering if there isn't a jumper (like shows up in the wiring diagram) that connects it to the DME control unit... That voltage has to be coming from someplace...
Do you know what the Vm unit does?
Thanks, Chuck I
      05-28-2009, 06:46 PM   #48
Ron Stygar
Drives: 2006 Z4 M Coupe
Originally Posted by Chuck I View Post
Oh Boy.... No VM module... Not looking good... I'm going to try and see if I can find the cables x60191 and x60193. Chuck I
We don't know if the print posted is for your car.
There is another print that shows it without the VM module.
Goes directly to the DME.
DME connector X60004 pin 1. SW/RT/GE wire.
Think I got it now. Will do some pics. New print. DME connectors and how the tranny works.
With the pics you can see if the sport switch wire goes to X60004 pin 1.
      05-28-2009, 07:00 PM   #49
Chuck I
Chuck I's Avatar
Yes, right up where your leg rubs... I had to take a hook and pull the carpet up and reach back in there... It was a real pain in the butt... Chuck I
      05-28-2009, 07:12 PM   #50
Ron Stygar
Sport mode print 2
See if the DME connectors match with your car compared to the pic.
      05-28-2009, 07:12 PM   #51
jra
Drives: 2005 z4
Chuck I I bet you can't wait to get that button in
      05-28-2009, 07:16 PM   #52
Ron Stygar
Thanks, Chuck I
Maybe the IVM is for the auto tranny cars.
      05-28-2009, 07:40 PM   #53
bten
LSU Tiger Fan
Drives: 2008 Z4 3.0si
I have drawn a couple of boxes and a line inside the small one. According to what Chuck I stated and his photos, the connector should be just to the left of the line under the carpet. If you can pull the carpet there, the connector may be under it. It is where I am going to look when I take off the cover that holds the shift boot in.
      05-28-2009, 07:45 PM   #54
Chuck I
Chuck I's Avatar
[QUOTE=Ron Stygar;5216473]See if the DME connectors match with your car compared to the pic.
QUOTE]
BINGO!!!!!!!! I removed the battery and then the cable from the DME.. The wire on pin 1 is the same as pin 5 on the sport button connector. I even used an ohm meter to make sure I had continuity... Thanks so much Ron! -- Chuck I
      05-28-2009, 07:48 PM   #55
Chuck I
Chuck I's Avatar
I can't wait...
Yup.. things are looking up... I knew I should have just gone to the dealer and bought the sport button..... but stupid me, I had to order it... Oh well.. it's been fun... Chuck I
      05-28-2009, 08:36 PM   #56
Ron Stygar
Forgot the X60004 connector pic.
      05-28-2009, 08:43 PM   #57
Ron Stygar
Probably easier to look at the DME X60004 pin 1 connector to see if the wire is there.
      05-28-2009, 09:02 PM   #58
Chuck I
Chuck I's Avatar
Thanks Ron... it's just as you pointed out...the plug pins are numbered and the wire colors are clearly visible. Now I just have to wait for my button.. I may have lucked out on this project... Chuck I
      05-28-2009, 09:39 PM   #59
Ron Stygar
About time someone tried to do it . Hope it works for you.
Most won't take the risk or spend money without a guarantee.
      05-29-2009, 01:23 PM   #60
Chuck I
Chuck I's Avatar
JRA.. Don't give up...
Hey... I was just looking... There are a couple of ways to check to see if you have the cable for the sport button... 1) Check to see if you have the IVM module (see Ron's #42 post). If you do, then open it up and check pin 20 of connector X60191. If it has a Blk/Red/yellow wire on it, then that cable is buried in there some place.... 2)If you don't have the IVM module, open the cover over your DME and check connector X60004 pin 1 for a Blk/Red/Yellow wire (see Ron's #50 post). Again, if that wire is there, the cable is buried in there someplace... Hope this helps... Chuck I
      05-29-2009, 01:53 PM   #61
jra
Drives: 2005 z4
Chuck I,
thanks, I'm going to need a little help here. I dont have the IVM module. So I'm looking for a single wire in the X60004 location that is black,red,yellow?
      05-29-2009, 02:50 PM   #62
Chuck I
Chuck I's Avatar
Chuck I,
Yes, that's correct. Take the cover off (4 or 5 allen screws), then you will see the x60004 plug... it's the second plug from the left... you have to remove the plug to the left of it to get it out. Turn it over and you will be able to see which pin is number 1... see Ron's drawing of the plug... The wire is black and red with a little yellow on it.... I'm getting ready to take a 4 hour trip so I won't be back on line until late tonight. I'll check back to see how you're doing... Chuck I
      05-29-2009, 05:48 PM   #63
jra
Drives: 2005 z4
Chuck I,
I've got nothing in the #1 slot. I guess it is one more push towards buying another Z4. I'm curious to see if any other members have this pre wired. Again, thanks for all of your help. It is members like you and Ron Stygar that make forums like this such a great place.
      05-29-2009, 09:28 PM   #64
Chuck I
Chuck I's Avatar
JRA, Well, sorry it's not there. To me, since my car is so early (12/2002) they may just had one main wiring harness at the time. It's really a lot of fun when you can make some of these things work.. and I always learn something.. So many folks have helped me over the years, so I certainly don't mind helping when I can.. Thanks for the kind comments.. Chuck I
      05-30-2009, 01:44 AM   #65
blade80
Drives: 2013 535i M sport
To me it looks like it should work for both. BUT, I won't know if it works at all until I plug it in. My hope is that the software is there... From the way the switch is built it looks like the light will function but I'll have to wait to see if the DME and the EPS will respond. I know that on my M, the Sport button make a difference so I'm hoping I'll be able to tell the difference here. There's another issue, your connector may not be there. As you can read above, JRA's car didn't have it... My car is a very early unit built in 12/2002. I lucked out. My suggestion would be that before anyone buys the switch that they check to see if the connector is there. You can get the switch for less than $80, probably cheaper if you shop around... Chuck I
thanks for the info. hope this works.
      05-30-2009, 02:37 PM   #66
Chuck I
Chuck I's Avatar
Darn button
Well, my sport button is on a UPS truck parked in Ohio... The tracking number says i won't get it until Tuesday!!!!!!! So here I sit... well, time to take the M out.. more on this tuesday night... Chuck I
