10-19-2008, 12:32 AM | #1 |
Rep 4,726
Track heads, z4 M brake rotors.
Who has had their Ms out on track for some hard driving. Preferably people with experience who use the brakes to a good bit of their full potential.
The coupes first time out on track my rotors were horribly warped within a few hot laps. I had hoped it happened when I went into the pits during a hot lap to check the tires but ended up sticking in there for a few minutes. Or the pads I used. Anyone else have issues, or no issues? I don't care so much if they crack, I expected that to happen from time to time, but warped rotors really ruin your weekend.
10-19-2008, 01:09 PM | #2 |
Rep 666
No warping, no cracks
I've got at least fifty heat cycles on my OE rotors and have experienced no warping or cracking. I've used both Performance Friction PF-01 and Raybestos ST-43 brake pads with good results.
Sometimes shuddering resulting from pad material buildup on the rotors is mistaken to be an indication of rotor warping. This can happen when street quality pads are overheated during heavy braking track use and the pad material is unevenly deposited onto the rotor surface. Suggest you first clean up the rotors using Gumout carb cleaner and rough them up using a sanding block and #100 emery paper. If that doesn't work check them with a run-out gage. If they are in fact warped your 4 year/50,000 mile BMW Maintenance Program should cover replacement. Be sure you have the OE pads installed when you visit the dealer and I would refrain from mentioning the circumstances under which the warping might have occurred
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red Last edited by jmillet; 10-19-2008 at 10:00 PM.. |
10-19-2008, 04:13 PM | #3 |
Rep 222
First weekend on track in my 3.0 rdst, the oem ft pads self-destructed and left a major deposit of pad material on the disc. The discs themselves were ok.
I currently use Brembo slotted sport rotors in ft with race pads and motul 600 fluid. No warping problems. Normal life of the ft rotors is 6-10 weekends before they crack. |
10-19-2008, 08:11 PM | #4 | |
Rep 4,726
Yea I was planning on Carbotech or performance friction for my next track day. I thought it might have been deposits but it started very quickly and it continued even with the stock pads and has continued for a week or two. They should have worn in by now especially with the different material. the vibration is very much in parallel with the rotor temps though, IDK. We'll see what happens I guess.
10-20-2008, 12:00 AM | #5 |
Rep 164
I had brake vibration when I first picked the Z4M. This was a new car right off the showroom. I took it back the deal said the car had sat so long that there was rust and crap the they had to clean all the rotors.
I have many track days on the car with carbon tech back. Hard enough brakes to make the rotors glow bright red in some braking zones. The warping and the brakes now have almost 10K miles. |
10-20-2008, 12:19 AM | #6 |
Imola Lover
26
Rep 749
Just throwing an idea out there... Could it be possibly that the stock setup isn't so great at handling heat shock? So for those of who have tracked without problems on the stock setup (with or without more agressive pads), perhaps we've been better about getting things up to "proper" operating temperatures before hitting them hard?
10-20-2008, 12:27 AM | #7 |
M Slut
18
Rep 564
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
I have another thought--maybe the stock brakes just suck. There are too many complaints and from personal experience, I can say they just don't cut the mustard after a few hard applications.
You have to be 100% behind someone before you can stab them in the back.
David Brent |
10-20-2008, 03:29 AM | #8 | |
Rep 164
Well, the way a track session usually works is a warm up lap before going full green. Rotors don't warp from hard abuse. They usually warp from improper cool down after session. |
10-20-2008, 05:29 AM | #9 |
PCA, BMWCCA
102
Rep 2,058
Well, they don't suck at being brakes for what they are designed, and that's for road use. No doubt Mov'it, AP Racing, Alcon, Brembo (real Brembos, not the 135i crap), etc. will outperform them under extreme conditions. Then again, some race brakes can be outperformed by OEM brakes in street conditions if they can't reach their ideal temperature range.
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU |
10-21-2008, 12:04 AM | #10 |
M Slut
18
Rep 564
Agreed!
David Brent |
10-22-2008, 06:29 PM | #11 |
Rep 100
I think with a better set of rotors and pads they will be great ...unless its a track only car I dont see the need for a big brake kit ...here are the rotors I'll be getting to replace the OEM's soon
http://store.bimmerworld.com/shared/...t=products.asp
10-22-2008, 09:21 PM | #12 | ||
Rep 1,373
"If you have had another manufacturers brake pads on those same rotors; then you will ABSOLUTELY have to replace or resurface (turn) those rotors before installing the Carbotech brake pads. If the rotors and drums are in relatively good condition, meaning they are smooth, flat, with no visible cracks, deep scoring, distorted, and with no other visible damage; and you have ONLY had Carbotech brake pads on them, then they do not have to be resurfaced or replaced."
07 Z4 M Coupe AW/IR |
10-23-2008, 08:18 AM | #13 |
My favorite sign.
169
Rep 4,333
If money isn't an issue get some stoptech carbon rotors.
10-23-2008, 08:49 AM | #14 |
PCA, BMWCCA
102
Rep 2,058
Apparently you're not familiar with Mov'it. None better...and they're expensive as hell...especially the ceramic rotor systems.
http://www.movit.de/
10-24-2008, 12:07 PM | #15 | |
Rep 164
I'm now back on the stock pads cause the car is due for service. I also need to wear the stock pads down so it doesn't look weird when the rotors need to replaced at 15K miles when the pads look new. Free maintenance rocks. |
10-24-2008, 12:16 PM | #16 | |
Rep 666
Jim Millet
10-24-2008, 04:01 PM | #17 | |
Rep 4,726
Do you normally drive on a track that's easy on brakes or do you go with the 8s because you use them on the street?
10-26-2008, 06:15 PM | #18 |
Imola Lover
26
Rep 749
My experience from this weekend. Ran a two-day HPDE with the local P-car club...
Track: Setup: * Agressive Alignment (max negative camber in the front with pins pulled, zero toe) * Enkei NT03-M Lightweight Wheels (18x8.5 front / 18x10 rear) * Nitto NT-01 R-Comp Tires (235/40-18 front / 275/35-18 rear) * Ferrodo DS2500 brake pads front / Axxis ULT rear (I keep this combo in for street and track use) * Super Blue brake fluid * Everything else stock Outcome: Advanced two run groups to solo and was working the car hard. Only things passing me were the GT2s and 3s. Ten to fifteen laps at a time with lots of brake usage including hard stops from 100-130 to 30-50 every lap. Experienced no fade. Brakes worked beautifully. At the end of the day, the wheels were almost black with dust and the rotors were a nice bluish grey color (and also worn...there's definitely more dovetail along the edge of the rotor than there was before). So I really don't think it's quite fair or valid to say that "the brakes suck and are only good for highway driving".
Last edited by jragan; 10-26-2008 at 06:19 PM.. Reason: added tire sizes and pad note |
11-07-2008, 05:31 PM | #19 |
Rep 4,726
Well i switched pads to carbotech, the fronts were replaced, and now I'm back at sebring (at the harder on brakes short course) So I guess I'm about to find out if it's the rotors or me that fucked up last time.
11-07-2008, 06:45 PM | #20 |
My favorite sign.
169
Rep 4,333
But you changed the pads and not the rotors...
11-08-2008, 05:32 AM | #21 | |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
Do you know that the ones for the 01- e46 M3 are suitable for our cars? |
11-08-2008, 11:20 AM | #22 |
Rep 100
actually after further research the rotors I posted are not available for the Z4M due to the size difference. The PFC rotors are for the oem M3 not the M3 CSL/ZCP which is the same setup for the Z4M
