      01-24-2024, 09:45 PM   #2905
maupineda
Drives: E86 Z4MC
Does it give an error? Do you need to code out bulb diagnostic?
      01-24-2024, 09:56 PM   #2906
2305
No error, no coding needed. IIRC, the only ones that give error codes from the headlight are 2-3 bulbs that are part of the yolk (yellow strip).
You just need to drill 1 tiny hole so you can get the nubs out.
      01-27-2024, 11:08 AM   #2907
maupineda
Drives: E86 Z4MC
Revised Karb OE Style box
AK72286.00
      01-27-2024, 03:07 PM   #2908
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Attachment 3373886
Man...do I ever wish that I wasn't in California
      01-28-2024, 08:53 AM   #2909
deemo319
deemo319's Avatar
Drives: BMW
Originally Posted by 3002 tii View Post
Got bored and decided to try another set of DRL bulbs. I think this as bright as you can get without installing AE rings. I
I do wish it was a tad less blue (more white) but it’s still way better than stock imo. Plus it only cost me $10
I wouldn’t mind a set. Where did you get them?
      01-28-2024, 08:57 AM   #2910
2305
https://www.amazon.com/dp/B078XPBMTZ?
      01-28-2024, 08:58 AM   #2911
deemo319
deemo319's Avatar
Drives: BMW
Thank you sir. You always have something new to upgrade your car with well thought out descriptions and very good pictures. Much appreciated.
      01-28-2024, 03:00 PM   #2912
07ImolaRot
07ImolaRot's Avatar
Drives: 07 Z4M, 05 M3, 13 M3
do it ! easy swap every other year
2007 Imola Red Z4M
2005 Phoenix Yellow M3 6MT
2013 Interlagos Blue M3 6MT ZCP CF roof
      01-29-2024, 10:54 AM   #2913
spielnicht
Petrolhead
spielnicht's Avatar
445
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Wheels are back from powder coating. I'm so happy with the way they turned out (Super Chrome Plus for the barrels, BMW Silver for the faces). New OEM center caps and stem valve covers. Car was also polished (3 step process) and ceramic coated while in the garage waiting for the wheels to be put back on.
Also got a set of Bumperplugs since I can't stand front license plates. She's now covered up in the garage until spring.
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
3798j11707.00
Steeler2430.00
MVRS4.50
3002 tii2304.50
DEG68.50
      01-30-2024, 03:47 PM   #2914
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
2022 BMW X3 M40i  [10.00]
2011 BMW 135i  [10.00]
2007 BMW Z4M Coupe  [10.00]
1991 BMW 318is  [10.00]
Are there any improvements over the 2023 design other than the now factory mounted (previously factory supplied) flange improvement? Did you pair it with a Rogue Engineering silicone Intake Boot?
      02-06-2024, 01:31 PM   #2915
Beecher
Drives: MB E400, BMW Z4, Lotus S240
I bought my Z4 this week, does that count?
3798j11707.00
86Zed937.50
HTM10157.00
wdb4773.00
      02-06-2024, 11:04 PM   #2916
2305
Don’t have CSL box but I did pick up a RE elbow myself that I plan to pair with an Eventuri intake. Just been lazy and waiting for temps to warm up a little to so the install.
      02-07-2024, 11:35 AM   #2917
Huz-Z
Huz-Z's Avatar
Car looks amazing and the restored wheels look brand new. Lovely!!
      03-10-2024, 12:53 AM   #2918
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
GruppeM ram air intake
MVRS4.50
      03-11-2024, 02:42 PM   #2919
2305
Finally installed a mirror mount for my Uniden RD. I have to say this product is awesome. Tons of adjustability and very secure. And at $20 something it’s great value considering Blendmount goes for $100+
I can confirm this fits the E85/6, F10, F25 and F15 models. For the Z, the spacing is tight but the key is to position the rear view mirror to your liking first, and then secure/tighten the screws.
Pretty sure seller sells attachments for other brands like Escort and Valentine. But I was able to use this for both my Uniden R4 and R7.
      03-12-2024, 05:40 PM   #2920
homebrw
homebrw's Avatar
Drives: 06 Z4 MR, 22 Mustang GT PP1
Looks good and thanks for the link. Looking for something for my R5. How did you wire it? My Z4MR doesn't have the auto dimming mirror.
Chris
      03-12-2024, 10:17 PM   #2921
2305
Chris
Bought one of those wire kits that has RJ on one end and power & ground on the other (with small fuse in between). And then simply plugged the power & ground directly into the mirror connector.
Even though you don’t have auto dimming, you should still check to see if you have the wire behind the plastic trim. Takes 2 seconds to check and there’s good chance the car was pre-wired for it. Else I would just run it across headliner and go directly to fuse box.
There’s dozens of threads on Bimmerpost but something like this.
FWIW I may actually have a spare wire kit. Happy to send to you if you cover shipping.
      03-13-2024, 06:48 AM   #2922
homebrw
homebrw's Avatar
Thanks for the reply and tip to check for power. Very kind offer on the wire. I'll send you a PM. Chris
      03-20-2024, 07:52 PM   #2923
cbpip
cbpip's Avatar
175
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [0.00]
Rear diffuser, Designed after the Fancywide version, but shorter fin height to make it streetable.
MVRS4.50
      03-21-2024, 07:45 AM   #2924
tomjonesBT33
tomjonesBT33's Avatar
Drives: 2006 Z4 M Roadster
New starter for my Z4M. It went out last week after solenoid stuck in the engaged position. With motor running it smoked the starter coils. Never had one fail this way before.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic
2012 X5 M - Monte Carlo Blue Metallic
2017 X1 xDrive28i - Alpine White
      03-21-2024, 10:59 AM   #2925
Huz-Z
Huz-Z's Avatar
Looks like nobody else spotted this!
Allow me to say congrats on the new car and welcome!
      03-21-2024, 11:00 AM   #2926
Huz-Z
Huz-Z's Avatar
Does that little modification to fit these bulbs mean you can’t go back to OEM bulbs?
