03-14-2022, 06:16 PM | #1 |
Rep 72
OEM CSL Wheel Settings
I recently purchased OEM CSL wheels for my Z4M Coupe. I often hear about obtaining a CSL alignment, but I've had trouble finding proper documentation of what exactly that is.
Which tire size and tire pressures are recommended with this wheel/tire combo? Do I use air pressures on the door, or should I use those of an actual CSL? If yes, what are those values? Where can I find the documented standard for setting up my vehicle with CSL alignment? Where/how can I get such an alignment performed, assuming the stock z4m coupe alignment settings are considered 'out of spec'. I have stock suspension. Thanks in advance. |
03-14-2022, 07:16 PM | #2 |
Rep 2,882
Drives: Anything
If all you're changing is wheels/tires, then you should just follow the Z4M alignment and tire pressure. Then adjust as it fit your usage. The e85/e86 suspension setup, track width, etc., are different from the CSL (e46 based), so you shouldn't try to duplicate the CSL alignment with just tires/wheels change.
03-14-2022, 08:08 PM | #3 |
Rep 208
Drives: 08 Z4 M Coupe
+1 for stick with the stock Z4M alignment and make slight modifications from there if needed. I suspect the only thing you might need to change is camber, but even then it would depend on how you use the car. More camber up front if you live on the track. Maybe 0.5 degrees less if you're mainly driving on the street.
'08 Z4M Coupe | Space Grey/Imola Red Extended/Carbon Leather | Eventuri Intake | Strömung Exhaust | Strong Strut Front/Rear Braces | 19" E46 M3 ZCP Wheels
