      05-26-2021, 08:57 AM   #1
brownah
Drives: Z4M Coupe
Wanted Z4MC Suspension
Hi everyone,
I'm on the lookout for an OEM complete suspension for a Z4M Coupe.
It's got to be complete, with top mounts etc. because I've purchased a B12 kit which is just the bare shocks and springs.
Located in UK but if anyone is willing to post I'm open to that too.
Thanks!
      05-26-2021, 11:25 AM   #2
Drives: M2 Comp
why not transfer your existing top mounts etc.?
      05-26-2021, 12:16 PM   #3
brownah
Drives: Z4M Coupe
The car is on BC coilovers which need refurbishment.
Unfortunately didn't come with original suspension!
Thought I should take the opportunity to refresh the suspension
      05-27-2021, 06:28 PM   #4
brownah
Drives: Z4M Coupe
Bump - still need this!
      05-28-2021, 09:30 AM   #5
Calichase
Drives: '07 s/c'd Z4MC '08 e82 '02 m3
ive got a set, but shipping may be rough.
PM me
      05-28-2021, 11:24 AM   #6
brownah
Drives: Z4M Coupe
PM me
Done
      06-03-2021, 06:25 PM   #7
brownah
Drives: Z4M Coupe
Bump! Still looking 😭
      06-22-2021, 06:49 AM   #8
brownah
Drives: Z4M Coupe
Bump! Anyone got what I need?
      06-22-2021, 12:17 PM   #9
Reborn_
Drives: 2007 BMW Z4MC
I do, but with 50k on mine, I don't feel right about selling it to you. Add international shipping, you're better off buying new struts (and the other components are cheap). I bought everything to pair with my b12 kit as well. Here's the parts list:
FRONT:
No. Description Qty Part Number
1 Guide support 2 31308040203
3 Articulated disk 2 31332282679
5 Upper spring pocket w/axial cage bearing 2 31331090612
6 Support 2 31332283038
7 Spring pad upper 2 31331091233
9 Additional shock absorber, front 2 31307836823
11 Spring pad lower 2 31331096664
I DIDN'T NEED:
2 Self-locking collar nut 6 31316769731
4 Self-locking hex nut 2 31106779396
8 Front coil spring 2 31307838835
10 Rubber boot 2 31331093344
REAR:
3 Protection tube 2 33521136283
4 Auxiliary shock absorber, rear 2 33507838832
5 Plate 2 33526762325
9 Plate 2 33526788999
11 Spring pad lower 2 33531094518
13 Spring pad 2 33531136385
I DIDN'T NEED:
1 Shock absorber, rear 2 33507838645
-- Self-locking hex nut 2 33526773882
-- Hex bolt 2 7119900402
2 Hex bolt 2 7119900402
8 Self-locking collar nut 4 7119905374
10 Self-locking hex nut 2 33526773882
12 Barrel spring rear 2 33507836827
6 Guide support 2 33526779670
7 Washer-gasket 2 33526772864
I opted for Rogue Engineering Rear Shock Mounts, so if you are not going that route, you may need a few components for the rear that I did not.
If you really want my used parts, let me know what exactly you want, and I'll sell them to you for dirt cheap, but again, with international shipping, I doubt it'll make sense vs. buying new from one of the typical players.
      07-14-2021, 01:59 AM   #10
rueyme
Drives: red z4
Message me if you still need these. I have a set in my storage if you need.
