      03-11-2020, 02:00 PM   #111
W///
W///'s Avatar
7532
Drives: F82GTS, E36/E92M3, Z4M
Originally Posted by 3002 tii View Post
Will snap more photos in few weeks, need to sort out some braking issues but picked up new EC-7's from the group buy few months ago. Perfect fitment, functional and pleasing to eye. No spacers!
18x9 et30 and 18x10 et22
Michelin Cup 2's in 245/40 and 265/35
Slightly lowered on GC school kit with -2.5 (f) and -2.0 (r)
I may try 255/275 if I later step down to a sticky street but happy with this fitment so far.
Wow, gotta compliment you on this car. It looks the business, especially with the hardtop!
Didn't have to roll the rear did you?
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      03-11-2020, 02:28 PM   #112
3002 tii
3002 tii's Avatar
2305
Nope 265 is pretty conservative. But then again I’m not slammed neither so hard helps...
Follow for latest mods
      03-12-2020, 09:39 AM   #113
W///
W///'s Avatar
7532
That's great. I think your ride height is also spot on. Big fan of the way this car looks! I'll definitely keep this in mind.
Current:
3002 tii2304.50
      08-05-2020, 02:38 PM   #114
Expert@ApexWheels
Expert@ApexWheels's Avatar
3595
Drives: M3
Z4M coupe on Race Silver EC-7s
Big thanks to Dino for sending in these shots of this super clean Z4M coupe!
APEX wheel specs:
  • Front: 18x9.5 ET35s Race Silver EC-7s with 255/35/18 tires
  • Rear: 18X10 ET25 Race Silver with 265/35/18 tires
Suspension:
  • Bilstein PSS10 coilovers
      11-25-2020, 02:43 PM   #115
Expert@ApexWheels
3595
Drives: M3
Checkout our customer Josh's beautiful 2006 Imola Red Z4M with APEX 18" ARC-8 wheels.
APEX Wheel Specs:
Front: 18×8.5 ET38 ARC-8 in Hyper Black
  • 15mm spacer
  • 225/45 Bridgsetone Potenza s-04 pole positions
Rear: 18×10 ET25 ARC-8 in Hyper Black
  • 255/40 Bridgsetone Potenza s-04 pole positions
Owner's Instagram
      12-05-2020, 10:16 PM   #116
F360C
Drives: E86 S54
Thought I would make a contribution to this thread.... both cars are on the same spec wheels. 9.5' et 35 front and 10' et 25 rears with with square 275/35/18 tires.
Untitled by Adam McGregor, on Flickr
IMG_5008 by Adam McGregor, on Flickr
IMG_5096 by Adam McGregor, on Flickr
IMG_5090 by Adam McGregor, on Flickr
_DSC1555 by Adam McGregor, on Flickr
_DSC0913 by Adam McGregor, on Flickr
IMG_1959 by Adam McGregor, on Flickr
IMG_2497 by Adam McGregor, on Flickr
_DSC1924 by Adam McGregor, on Flickr
07 Z4 M Coupe AW/IR
wdb4762.50
W///7532.00
      12-21-2020, 06:22 PM   #117
lafuerza
Drives: 2007 Z4M Coupe
F360C,
Love the look. Want to go square setup for canyon/track use. I like 275/35/18 setup you have. What suspension setup do you have. Any fender rolling, etc. Does it rub on street?
2007 Z4M Coupe. KW3, Stoptech ST60/ST40, SSK, AKG Bushings, 4:10 Diff, ARP Wing, ARP Splitter, MFR Splitter Underpanel.
      12-31-2020, 06:51 PM   #118
Expert@ApexWheels
3595
Drives: M3
ARC-8s always look good on a Z4M Coupe, especially when its Satin Black on Interlagos Blue!
APEX Wheel Fitment Specs:
  • Front: 18x9" ET35 APEX ARC-8 in Satin Black with 255/35-18 Michelin PSS tires
  • Rear: 18x10" ET25 APEX ARC-8 in Satin Black with 265/35-18 Michelin PSS tires
      01-12-2021, 06:58 PM   #119
Expert@ApexWheels
3595
Drives: M3
Post pics of your Z4s with APEX wheels if you've got them! Both Z4 coupes and roadsters alike look best with a set of APEX wheels!
  • Front: 18x9.5" ET35 ARC-8 in Satin Black with 255/35-18 Hankook RS3 tires
  • Rear: 18x10" ET25 ARC-8 in Satin Black with 374/35-18 Hankook RS3 tires
-Ian
      01-16-2021, 08:49 AM   #120
F360C
Drives: E86 S54
Originally Posted by lafuerza View Post
F360C,
Thank you sir!
I am running MCS and the blue car is running Ground Control. Tiny bit of fender rolling in the front and rear on both. Both are -3.3 front camber. My car runs a 5mm spacer in the front for strut and brake caliper clearance. With the EC7's and the GC suspension on the blue car you can get away without a spacer if you dont run the car super low. If you do run the 5mm spacer you can run the car a lot lower with the Ground control suspension vs the MCS.
The cars are both very stiff (750lbs front springs and 850lbs rears) so they dont rub a ton on the the street. Just a bit here and there with bit dips, off camber parking garage entrances, etc but its not terrible. A 265 front would def fit with out issue but I like the extra grip on track.
07 Z4 M Coupe AW/IR
      02-02-2021, 05:13 PM   #121
SunUpTopDown3
Backroad Warrior
SunUpTopDown3's Avatar
Drives: Z4MR
Z4MR Specs:
Front: 18x9.5" ET35 APEX ARC-8 in Satin Black with 255/35-18 Michelin PS4S tires
Rear: 18x10" ET25 APEX ARC-8 in Satin Black with 275/35-18 Michelin PS4S tires
987 Cayman Spec:
Anthracite SM-10 18" details unk
      02-04-2021, 06:21 PM   #122
Expert@ApexWheels
3595
Drives: M3
Originally Posted by SunUpTopDown3 View Post
Z4MR Specs:
987 Cayman Spec:
Awesome cars and great choice on wheels!
-Ian
      05-20-2021, 06:53 PM   #123
Expert@ApexWheels
3595
Drives: M3
Checkout this classy roadster rocking a staggered set of ARC-8 wheels in Hyper Silver Finish!
      11-04-2021, 07:27 AM   #124
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
APEX EC-7R Forged
APEX EC-7R Forged wheels
Front: 18x9" ET31 with 245/35-18
Rear: 18x10" ET25 with 275/35-18
Powered by
      11-06-2021, 12:55 AM   #125
Beedub
Originally Posted by AK72 View Post
APEX EC-7R Forger brushed clear
Front: 18x9" ET31 with 245/40-18
lovely setup.... would you expect this to rub alittle ?
currently running 18x8.5 et29 with 235/35-18 18x9.5 et23 265/30-18 on an r comp tyre. i can just and i mean just glance the front inner fender at maximum attack on a track, it doesn't rub through the fender given how light the contact is , im running an aggressive track geo with lots of neg camber.
i see these setups and they look amazing but i wonder can the car be driven properly without eating itself . what would you recommend , id love a set of forged 8rc.
also whats the lead times for the UK on the forged 8rc line in brushed clear.
      11-08-2021, 08:02 AM   #126
AK72
AK72's Avatar
with -2.5 camber on the front i have no Issues, no rubbing
Powered by
      11-10-2021, 05:59 PM   #127
Beedub
awesome feedback, im abt the order the new vs sprint line...
one last question.... what made you go brushed clear.... soooo tempted to choose this but just not sure... ????
also AK, can you confirm the rear is rub free? i cant imagine it being an issue.
      11-11-2021, 05:11 AM   #128
Beedub
ordered the New APEX Vs sprint series forged in brushed clear. cant wait man!
      11-11-2021, 09:58 PM   #129
dre99gsx
Drives: 1994 Toyota Supra
Perhaps I missed the memo, but I noticed not many SM-10 wheels sizes are available anymore for Z4 sizing. Are they discontinuing the series?
      01-12-2022, 12:11 PM   #130
Expert@ApexWheels
3595
Drives: M3
None of our SM-10s have been discontinued in any fitments that I'm aware of. Do you have a specific size and offset you're looking for?
-Tom
      08-16-2022, 03:58 PM   #131
Expert@ApexWheels
3595
Drives: M3
Paging BMW owners in the Bay area! If you're interested in free professional photos of your car on brand new APEX wheels, we are looking for volunteers for testfiitting and photoshoots! Volunteers will get copies of the photos, a discount on a future set of APEX wheels, and APEX goodies/swag.
If you are interested in volunteering, please complete our online webform here. Show us what you've got!
If you'd like to take an inside look at what the photoshoots involve, our good friend Blake made a video detailing the process of an 18" photoshoot on his F82 M4 recently:
Another look at the process of shooting an E46 race car with our Creative Director Yo!
      01-31-2023, 05:20 PM   #132
Expert@ApexWheels
3595
Drives: M3
A new Sprint™ Line design is coming soon.
We’re one week away from the reveal, are you ready?
