      07-16-2020, 02:59 PM   #1
jhall1957
Drives: SE 46
Best track tire/wheel combo
After 15 years of wheel to wheel racing(SE30 and SE46) Ive sold my race car and will be tracking for liesure my 2007 Z4MC which has big brakes, coilovers, fixed seats and harnesses and roll bar.
Currently it have Apex wheels with 265/40-18 rubber up front and 275/35-18 in the back. Looking for first hand experience with different "R' rated tires.
Garage; 2020 Raptor, 2011 1M, 2017 M2 PE, 2006 Z4 MC, 2007 Z4 MC, 2001 Spec E46, 2007 GT3
      08-02-2020, 09:13 PM   #2
CTMP4me
Drives: '08 Z4MC, '71 240Z with S54
For dry track days - Trofeo R. On Z4MC platform, I start with 26-28 psi cold, get them to 32 psi hot and keep them there, 33-34+ psi and they get squirmy and slide easily. If you drive at time attack pace, you can kill a set of tires in an afternoon, but they can also last multiple weekends if you aren't driving with excessive slip angle or drifting. I only street drive them to and from track, they do fine at street speeds in the rain, but wet braking at track isn't great.
Yokohama AO52 is supposed to be the new hot "200TW but not really" tire - similar grip to Trofeo R, less sketchy in the wet, and it's on my radar unless I get another set of cheap Trofeos.
      08-04-2020, 03:01 PM   #3
jhall1957
Drives: SE 46
Are these "R" rated race tires?
      08-04-2020, 05:59 PM   #4
Barryb97
Drives: 2006 M coupe
Lot of the guys I track with run the Toyo R888R and like them. I run Hankook RS-4 they are just sticky summer tires not R compound.
      08-04-2020, 09:35 PM   #5
eggman51
Contributing mostly to subscribe to learn where this goes...
I am using Pilot Sport 4S. These seems like great road / track tires.
I am thinking about running Cup 2 tires next year. I would do this with a dedicated set of track wheels, though I would still need to drive to and from the tracks.
      08-04-2020, 09:40 PM   #6
jhall1957
Drives: SE 46
Well, I'm
Coming from Spec E46 on Toyo's and will likely run Hoosiers. Was just curious what experience was here.
After fender flares we are planning on 285's on 18s. Should have wild "stick" especially with some aero!
      08-05-2020, 08:55 AM   #7
jns_e85
jns_e85's Avatar
75
Drives: '05 X3 2.5i, '06 z4M, '17 M2
I have enjoyed RE-71s as a dual purpose autocross/track tire, especially since you can flip them to extend their life.
For R-Comp tires, a good friend runs the Maxxis RC-1 on his Z3M coupe for track. He said they are on par with Nt-01 and 888R in terms of grip, with the difference being the RC-1 have the shaved tire grip of the others immediately because they are smooth.
Not as sticky as hoo hoos of course, but they sure as shit last forever. Bonus is they are CHEAP too, and if your an SCCA member they provide a 10% discount as well (talking UNDER $900 shipped for SCCA members for a set of 265/35/18s).
I'm very strongly considering them for next year myself
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
      08-05-2020, 09:30 AM   #8
jhall1957
Drives: SE 46
Running NT-01's now and they are a good option. Like you said, going for even more grip with Hoosiers.
Enjoy
      08-06-2020, 06:09 AM   #9
Michael9218
Michael9218's Avatar
602
Drives: 2007 Z4 M Coupe
Best bang for the buck is the venerable Hankook Z214 dot slick. I run 275 square. Requires a bit of trimming to run in the front.
      08-07-2020, 12:19 AM   #10
dre99gsx
Drives: 1994 Toyota Supra
I do 9-10 hpde events a year on R888R (295/265), you'll like those tires. They last me about 30-36 heat cycles with slow drop off in grip, work well in cold and hot weather, (36F up to 100F), and they are inexpensive. I run them at 25-26psi cold to 32psi hot. Not as fast as slicks, but great R-compound choice. Go Toyo RR if you want even more grip, but stiffer sidewall, may be sweet spot for you before going full slick.
If you're not doing competition, any reason to run slicks other than lap records?
NT-01s and other Rs are comparable, it will come down to availability and tire size that you want in the end imho.
      08-07-2020, 10:15 AM   #11
jhall1957
Drives: SE 46
I e been driving RR's on SE46 for years and thought about R888's. Running NT-01's now but maybe I push them too hard as they get "greasy".
Retiring from racing but still have my Z4MC which is getting more racy. Just what grip that is more then I'm willing to push.
      08-07-2020, 05:22 PM   #12
thielepr
Drives: 06 Z4M, 11 M3, 17 230i
Kind of hijacking but I was to make basically the same post. Looking for a square set of 18”. What’s the widest tire on stock suspension?
I’m thinking a 18x8.5 should be good enough for a 235 tire front on a 40 offset but then it would be a waste to run a 235 on the back.
      08-08-2020, 10:16 PM   #13
dptmachine
Life, Liberty and the Pursuit of Motion
dptmachine's Avatar
Drives: 2007 BMW Z4 M3 Coupe
RS-4 are 2 to 3 seconds slower than NT-01, but you get a lot more use. R888R found to last marginally longer than NT 01 with same lap times. Side note, I lent my buddy the Rs4s for track day on his F80 M3 and he said they were crap with the heavier car. Square 275s at the time.
      08-17-2020, 07:37 PM   #14
CTMP4me
None of these are race tires, they're all street legal, have super short tread life, but are still reasonably usable on street in rain. Until it's an actual race slick / race rain tire, as far as I can tell the 200 and lower treadwear rating tires are pure OEM marketing / autocross rule arbitrage - eg the Cup2R that has 4-5 hero laps and then turns into a normal Cup2 or RE71R that wears as if it's <50 TW.
Another tire to consider if you're consider R888R - Nankang AR1. No personal experience yet, but lots of rave reviews on the web / from regular trackrats.
      08-17-2020, 07:42 PM   #15
CTMP4me
More round-shouldered tires like RE71R in 245 fits in the front on stock suspension (RS4 ended up rubbing in same size and aspect). If you're spending the money on a square setup, I'd at least consider getting front camber plates so you can run 2-3 degrees of camber - can fit 255 upfront for a proper square setup + make the tires last longer on track.
wdb5021.00
      09-09-2020, 02:18 PM   #16
CSM3
CSM3's Avatar
Drives: E86 Z4M, F80 M3CS
Another option to consider are the Goodyear Eagle Supercar 3R. I believe they were OE for the Camaro ZL1s.
Insane amounts of grip, best lap would be after warmup lap +- 2 laps before they start slowing down. However it's super consistent after.
Did 4X 20-30 min sessions at Club Motorsports in Tamworth NH, and another full open lapping day at Palmer CW. Rotated the wheels left to right in between tracks. Tires were a beast and maintained grip throughout, even when it got to about 92 degrees ambient temp. The car was performing so well with these tires that I almost completed an hour session with 2 five minute pit ins to adjust my LapTimer.
The fronts were completely corded after Palmer, but you could only tell by looking at them. The rears could probably do with one more day. Also these tires definitely look like they can do with more camber. I am currently at -3.2 fronts.
wdb5021.00
      09-21-2020, 01:34 PM   #17
Beedub
those wheels
      09-21-2020, 10:50 PM   #18
CTMP4me
What sizes are you running and are these tracks known for being hard on tires? I have the same outer edge wear issue with Trofeos and -3.2 camber. That's some quality tire use
      09-22-2020, 12:05 AM   #19
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Try the nankang ar1 or ad052.
They beat re71 and rrr hands down.
Will also last about one day more.
First day they are as grippy if not faster as Pirelli scrubs.
Instagram: ariusen26
Youtube: Track vids
      09-22-2020, 11:41 AM   #20
CSM3
CSM3's Avatar
those wheels
Haha, thanks. HRE R43s.
The Goodyear I ran 265/35 and 275/35. But I just replaced the set with Trofeo Rs in 265/35 square. I have to say. Running the tires back to back. The trofeos are less communicative through the wheel, but do squeal to warn you when at the limits. Overall I wouldn't get trofeos again, they are too hard. Wear seems to be better.
Yes those tracks can be brutal.
      10-19-2020, 05:28 PM   #21
jmillet
jmillet's Avatar
70
Thumbs up TOYO R888
I've gone through several sets of Toyo R888s mounted on E46 M3 wheels. Recently switched to the Bridgestone R71R with good results.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      10-20-2020, 08:19 PM   #22
dre99gsx
Interesting, I can go a whole HPDE 'season' 10 events on one set of R888R and still have some tread left front and rear. How are you guys killing/cording tires in just one event? I must be driving like a old woman!
