04-06-2019, 03:33 PM | #1 |
Nathan
Rep 10
Tapping/Click on Startup
Hi people,
I was wondering if anyone has experienced the same issue as me. Firstly, this issue happens very randomly. its does not happen 10/10 times I start my car. it happens maybe about 3/10 times. It mostly happens when my car has been sat for a while or overnight. When I start my car up, it starts making a tap/click/tick sound for around 10-15 seconds and it completely disappears. what can it possibly be? Vanos? Lifters? Injectors? |
04-06-2019, 04:09 PM | #2 |
dances with roads
4773
Rep 4,102
If it's an N52 it could be the hydraulic lifters. There was a recall for it I believe. I'm not 100% certain but I think they tended to bleed down if they sat for a while, and you'd get a tapping sound for a few seconds on startup until they pumped up again.
04-07-2019, 01:55 AM | #3 |
your average JAMF
3196
Rep 4,116
Not an N52 based on his info under his username.
'21 M2 Comp
'19 Golf R |
04-10-2019, 09:38 AM | #5 |
1821
Rep 5,337
What oil is in the engine?
04-10-2019, 02:35 PM | #6 |
Rep 623
Is the sound coming from the sound system? When my audio cable is connected with nothing on the other end it makes a sound like somone tapping on a live microphone. Is that the sound?
Steve |
04-16-2019, 09:20 AM | #9 |
1821
Rep 5,337
There could be a thousand different causes, almost all of which can’t be resolved by description alone.
Here are a few higher possibility causes. Low oil. Improper weight oil. VANOS pump. If you don’t want to chase wild goose, I’d start with changing the oil now to a BMW LL01 approved, 0W-30 or 5W-30 weight synthetic and see if it gets better or eliminate the problem entirely. If not, take it to a local mechanic (your location suggest you’re no more than a 15 minute drive from a few really good BMW Indies), see if he can reproduce it and locate the sound with a boroscope.
04-16-2019, 11:34 AM | #10 |
Rep 682
As The Hack said get that oil outa there. I have that motor in my E46 330i and its quieter and smoother than S54! Maybe some sludge in the valvetrain? How many miles on motor?
04-17-2019, 02:10 PM | #12 |
Rep 330
Do you park on a hill? I had a ticking sound when the vehicle was left for a few days on a hill and the conclusion I came to was oil drained out the engine and it took some minutes to get it pumped back once I started the car.
the stable:
2003 BMW Z4 3.0i 2020 Mitsubishi Outlander SE 2021 Jeep Gladiator Rubicon |
04-25-2019, 08:34 PM | #13 |
Nathan
Rep 10
04-26-2019, 10:32 AM | #14 |
1821
Rep 5,337
If I can tell you sight unseen based on your description, I wouldn’t be here posting. I’d be on a private island sipping pina coladas surrounded by hot 20 year olds frolicking nakedly through the crystal clear water.
Because I would have the power of foresight and be able to guess the winning number of each Lotto draw. Take it to a local, trustworthy mechanic if you want a real resolution on the issue, rather than listen to teh interweb speculation is probably the best advice I can give you. No matter how smart some of us sound, we’re just a bunch of unqualified keyboard monkeys.
Tags |
noise, start, tap, tick |
