02-16-2018, 05:00 PM | #1434 |
Rep 870
Drives: 2006 BMW Z4M Roadster
I finally decided to join the herd and buy a Motive. Sometimes following the crowd is the right thing to do.
I bought a bag from Harbor Freight and organized a brake bag kindergarten style. Everything in one place. I used Ate Type 200, but check out Bosch brake fluid. It looks pretty good, too. I had a stuck caliper on our 330Ci, and I pushed it out by pumping the brakes. It started leaking a little, so I bought some Bosch locally until the Ate came in. For a little over $7 a liter, it was a bargain and has great specs. I bought it just to keep my MC from going dry, but I would run it if I hadn't already had the Ate coming. Salty
02-19-2018, 11:39 AM | #1436 |
Rep 195
Nice I've used the Motive for years without problems. My hoses eventually wore out and Motive replaced them all for me for free. If yours has the brass couplings in the hose I'd recommend taping them to prevent accidental paint damage. FWIW, I only use it to pressurize the reservoir, I don't put brake fluid in the canister. Too messy. Just make sure not to let the reservoir level get too low.
SaltyNC369.50 |
02-20-2018, 11:00 PM | #1437 |
Daily driver/Weekend mechanic
Rep 48
Drives: '06 Z4 3.0i Roadster
Body work
It's been a while since I bought anything for it. Had to remove the supercharger last September so that I could buy a pass for air care.
This week, I bought new bumper covers, front & rear and a new hood. Then please direct your attention to the front fender reflectors. |
3GFX722.50 |
02-21-2018, 02:45 AM | #1438 |
703
Rep 7,850
Bearings, motor mounts, front control arms / FCABs (lollipops were toast ~45k miles), diff bushings, RTABS/limiters (all the bushings!) transmission mounts, end links, new coilovers (Status Gruppe), exhaust hangers, alignment, all fluids. Figure it's good for another 10 years/50k miles!
02-21-2018, 01:05 PM | #1439 | |
Rep 870
Salty
02-22-2018, 03:52 AM | #1442 |
Rep 375
02-22-2018, 03:49 PM | #1443 |
Rep 431
Beautiful Seats!! ^^^
Prepping for 2018 Fun: Rod Bearings, Turner Aluminum Motor/Transmission Mount kit, Powerflex Bushings, Super Sprint Headers, H&R Sway Bar, Z4M_GT3 Reinforcement Plates, Turner Adj End Links, corner balance and alignment. More to come VERY soon!
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo Last edited by Azeka1; 02-22-2018 at 04:19 PM.. |
02-22-2018, 07:10 PM | #1444 | |
703
Rep 7,850
3GFX722.50 |
02-22-2018, 07:49 PM | #1445 |
Rep 431
Looks like we’re going through similar updates this month! Will keep you posted on how they work out
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo |
3GFX722.50 |
02-23-2018, 07:35 PM | #1446 |
Rep 83
Wheels
02-23-2018, 07:47 PM | #1447 |
Rep 870
Those solid mounts look cool. I bet those will dislodge kidney stones.
Salty
StickMon636.00 |
02-23-2018, 10:33 PM | #1448 |
Rep 528
Drives: E86 Z4MC; E92 M3
Picked up a 1:18 scale E86 off eBay, the goal is to recreate my car as best as I can.
Excuse the crappy camera phone picture.
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
02-24-2018, 03:27 PM | #1449 |
salty cowboys fan
6159
Rep 3,408
New toolbox, not bad for $600. Sure beats paying $8k for a snapon
02-26-2018, 05:30 PM | #1450 |
salty cowboys fan
6159
Rep 3,408
Guy on eBay used this once for 30 minutes, $200 cheaper than new 1/2”, 1300 lb-ft breakaway torque! Also picked up a 3/8”
02-27-2018, 10:05 PM | #1452 |
Rep 431
SaltyNC Finnegan I picked up the car today and my initial impressions on the solid motor and transmission mounts are as follows:
- Cranking the car definitely gives off more vibrations - No real noticeable difference in idle vibrations - Some additional dashboard vibrations between 1,500 and 2,500 RPM - Major improvement in overall responsiveness and steering sensitivity Overall, this is definitely not as bad as folks make it out to be and I am very pleased with the outcome. I would not recommend it for a daily driver; however, for a weekend/street/track car, this is bearable. The increased performance certainly outweighs the additional NVH noted above. Hope this helps! E36/E46/Z3/Z4 Turner Solid Aluminum Motor and Transmission Mount Kit https://www.turnermotorsport.com/p-1...ion-mount-kit/ Last edited by Azeka1; 02-28-2018 at 09:55 AM.. |
