09-02-2017, 12:01 PM | #23 | |
Rep 223
e: and yeah, I've said "well, that escalated quickly" to myself more than once in the past few months. |
09-04-2017, 10:43 PM | #25 |
Rep 223
Hahaha, crap.
I finally had some time to work on the project today. Realized after turning the intake cam 360* that I hadn't put shims in. Pulled the intake cam, cleaned up a few marred buckets () making heavy use of a stack of neodymium magnets, got shims installed on the intake side, and managed to get shims into the exhaust side without pulling that cam. Only two exhaust shim buckets needed cleaning up at least. Re-installed the intake cam, got everything torqued, and was out of time. View post on imgur.com I didn't want to bag the head again so I dropped the valve cover on as a dust cover. It's so badly warped that I can rock it corner-to-corner. Like a 4mm gap. View post on imgur.com Guess I found that oil leak I'd been chasing... |
Taskmaster2469.00 |
09-05-2017, 06:20 AM | #26 |
dances with roads
4757
Rep 4,100
Hmmm. I wonder if that's what is going on with the Moupe I just got. The prior owner was obviously skilled and had done the valves himself at 60K, and yet there is seepage at the gasket. Hmmmm. I'll have to keep that in mind when I do the VANOS this winter.
09-05-2017, 08:56 AM | #28 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Your post about the rod bearings has me a bit worried. I'm doing vanos work now, and plan to do rod bearings in the very near future. I do know about the ARP bolts, and some have recommended against using them due to the amount of force needed to seat them properly. I was speaking to an indy last week that said he replaced bearings on an M3 (S54) with the treated OEM bearings and ARP bolts, and the M3 lost the engine at the track within a year of replacing the bearings.
Is proper rod bearing replacement something only a race shop can perform? I was planning on using stock bolts, but leaning toward the treated OEM bearings. Salty
09-05-2017, 07:14 PM | #29 |
dances with roads
4757
Rep 4,100
I'm not sure if I'm more worried or if I need to reach for the salt shaker. The reason car companies go to the expensive length of splitting conn rod big ends that way is that it makes it pretty much impossible to assemble them INcorrectly. Now here's this guy saying the opposite.
09-05-2017, 09:18 PM | #30 | ||||
Rep 223
His explanation makes sense to me, and a couple of other S54 / S65 race engine builders on the web agree**. I think it all comes down to risk management and engine goals. I want my build to be supported by my engine builder, he believes that this is the correct approach for real safety, and the difference in cost simply isn't enough for me to worry about it overall. It's worth noting that Andrew Lang's data on ARP bolts causing the big end to oval is based on a model - it may be correct, but a lot of people's experience of the OEM -> ARP rod bolt transition is that the top / bottom bearing wear on the rod big end disappears with their engines after switching to ARP bolts. Bottom line: YMMV. :shrug: * I didn't ask to see it, so this is effectively me assuming that the plural of "anecdote" is "data" ** Something, something, opinions and assholes, something, something |
09-06-2017, 06:26 PM | #31 |
Rep 870
Matt, thanks for taking the time to provide the additional info. Really appreciate it. Can't wait to see where your build is going next.
Salty
09-25-2017, 01:53 PM | #32 | |
Rep 223
Weekend update: initial valve clearance set on the bench. Took longer than I'd hoped, but I got a reasonable result: View post on imgur.com I wasn't happy with intake 5B but left it just in case I didn't have enough of any specific shim size. (Note the empty slot in the shim kit in the first photo... ) But with a target of 0.25mm lash for both intake and exhaust, being inside -0.013mm/+0.029mm ignoring 5B (and still inside -0.021mm/+0.029mm including it - basically +/-11%) I feel like I did alright. I was planning to err on the side of loose, because I don't want to burn a valve; after talking to Minos at Achilles today, I'll be re-shimming the loose (~.279mm) valves to be slightly tight. The 0.04mm increments on the BMW shims is irritating but Minos' advice is that leaving more lash makes the shims more prone to jumping out of the buckets due to the more aggressive cam profile and the stronger springs, and that .22mm (but of course as close to the .25mm spec as possible) is fine for the Schrick 288/280 cam setup. Going down one shim size for each of the valves currently lashed to .279mm should make them all ~.239mm, which should be fine. Some things I learned yesterday: (1) The used valve cover I bought rocks on the head exactly like the other one did. I am officially afraid that there's something wrong with the top of my head. (2) I totally, totally forgot about the fact that the cams aren't currently connected the timing chain. Valve-valve contact between all four #1 valves. Little surface marks but no real damage as far as I can tell, but that sucked so hard. Scared the living hell out of me. (3) Using a cheap set of digital calipers sucks for this (I noted +/-0.02mm variance in measured shim thickness, which led to a lot of hunting around for the correct substitute shim... ugh). Ordered a good "absolute origin"-based set last night and hope they make the lash setting easier when I install the head... which is actually my next task. I'll document the cam removal / installation procedure I'm using when I assemble the short block, also, since it seems to work well (fingers crossed) and is safer than the current how-tos without buying the BMW tool that wouldn't work with aftermarket springs / cams anyway. |
09-26-2017, 03:01 AM | #33 |
Down Under!!
1624
Rep 4,296
top notch Matt, good shit right there man.
i have an oem valve cover lying around you can borrow if you like.
Powered by |
09-26-2017, 09:54 AM | #35 | |
Rep 264
Pissed I ran to the dealer and bought an OEM gasket, and wouldn't you know it, no more leaks!
wdb4756.50 |
09-26-2017, 11:23 AM | #36 | ||
Rep 223
Right now it is And for the street... probably ruined. Quote:
Well, then. I guess I'll pitch the pair of Reinz VCGs I have in the garage and buy some OEM ones... but not until I've tried just once more since it should be much easier to get this done properly with the engine on a stand. Fun related fact: a buddy did a bit of back-of-napkin math on the 7 ft-lbs / 10 N-m torque spec for the valve cover nuts, and determined that it generates around 14k pounds of clamping force, which is something like 75-90% of the yield strength of mild steel... That doesn't take into account the fact that the gaskets are under the nuts, of course. But still. |
09-29-2017, 09:22 PM | #37 |
Rep 211
Drives: 2007 BMW Z4M Coupe
Not sure where's the "ruin" in the main thread. Well done, Sir. Subscribed. Keep'em coming
11-07-2017, 03:01 PM | #39 |
Rep 223
Small progress this weekend: took video of the cam removal with clamps process, and installed the ARP head studs. Upcoming weekend will be head install, cam install, and maybe initial mechanical timing. I'm going to take video of as much of this part of the process as possible, since there's just not a lot of good video out there for working on S54s.
So here are some photos of at least one new thing: View post on imgur.com View post on imgur.com ...love those JE pistons. |
11-07-2017, 04:06 PM | #40 |
Rep 5,329
NICE, those pistons are wow!!
11-08-2017, 11:14 AM | #43 |
Rennfahrer
50
Rep 200
You, good sir- deserve an award for this.
Current- Jerez Black E92 M3 | Arctic Silver E36 M3/4/5 | Monaco Blue E90 325xi Past- AW Z4-M roadster| JB Z4-3.0si | '98 Accord V6 coupe |
