      06-06-2017, 06:30 PM   #111
Infam0us1
Infam0us1's Avatar
Drives: 335i
nice job ! just did an n54 single turbo swap
      07-31-2017, 11:10 AM   #112
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
Saw your car at Bimmerfest East, badass build!
Which rear diffuser setup did you have? Loved it. Looked like it might have been taken from another application and applied to the Z4?
-Matt
| Z4M Build Thread | @violetnites | flickr |
      07-31-2017, 11:16 AM   #113
dre99gsx
Drives: 1994 Toyota Supra
Thank you! I'm running the E89 carbon fiber diffuser, custom fitted to the bumper.
      07-31-2017, 11:21 AM   #114
GuidoK
#buildnotbought
GuidoK's Avatar
11118
Drives: Z4 3.0i ESS TS2+
too bad all pics are gone in this thread (photobucket host.....)
      07-31-2017, 12:23 PM   #115
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Ah yeah, looks perfect!
As GuidoK said, all the photobucket pics are down. Try hosting on Flickr!
-Matt
      07-31-2017, 01:24 PM   #116
dre99gsx
All fixed! I own/run http://www.benchraces.com and just hosted them all there.
Some other photos:
      07-31-2017, 03:50 PM   #117
The HACK
The HACK's Avatar
1821
Love the TRD sticker...
      08-02-2017, 09:51 PM   #118
dre99gsx
Forgot to add these - brake cooling ducts
      08-08-2017, 08:15 AM   #119
nadaclue
Drives: Urban Green 2003 3.0
Any info on this one? I'm curious about the electronics and any clearance issues on the turbo side.
      08-28-2017, 05:18 PM   #120
dre99gsx
Finally got a chance to dyno the track queen:
22psi. Been driving on this tune for a few months now, including all my HPDE events. I think the transmission is holding pretty well so far (including the rest of the driveline as well).
I was planning to start the dyno at 3krpm as I do all my dyno sessions, but I mistakenly would hit the dynojet button 'after' I had already stepped on the gas. On this car, it starts revving out fairly quickly.
Do I plan to up the boost and make more power? Nope... I have the other beast for that.
NickyC17683.00
wdb4762.50
Azeka1285.50
GuidoK11118.00
Taskmaster2470.00
      08-29-2017, 10:21 AM   #121
mattfwalters
mattfwalters's Avatar
Drives: 06 Z4MC (Sepang/Sepang/insane)
Holy cats that dyno plot
This is a mad build, and I love it. What's next? How do you find the car at the track with that much power?
      08-29-2017, 11:11 AM   #122
dre99gsx
It's a great fat power curve, but corner exits are my struggle. I only have 10% throttle, maybe 30%, and then 100%. I have a very narrow window to ease on the power without the turbo wanting to spool, thus, I have to wait until I'm absolutely straight before going over 30% throttle.
The fix? Get traction control working on my AEM. Will be testing this out next month at NJMP.
compare to the VF570 Supercharger on these S54s:
As long as the chassis/drivetrain can continue to hold this power, I think it will be a testament to the hardware's capability (remember: stock z4m tranny, stock driveshaft, stock rear diff (no LSD), and z4m-swapped rear axles). I haven't seen anyone run this much power on this drivetrain, perhaps I'm the first.
I'll keep pushing it until it breaks, but honestly, I could turn the boost down and still enjoy this thing Not going above this level for the foreseeable future.
      08-29-2017, 02:04 PM   #123
mattfwalters
The best handling mods I made to my car - lots less power, but - were going to square wheel setup, 700lb-in rear coils, and deleting the rear sway. If you're running a bar in the rear, try disconnecting it before your next track session. If your springs are stiff enough, you'll find that the car doesn't need the extra spring rate from the swaybar, and you'll have a bunch more grip coming out of corners because the bar won't be trying to lift the inside rear wheel. Deleting the bar seems counterintuitive but it made a huge difference (like 4s per lap on a two minute track) for me. I still have DSC because of the stock ECU, of course - if you can get the AEM to modulate torque (presumably through boost reduction) when slip is detected, that with the rear suspension changes should help a lot.
      08-29-2017, 02:16 PM   #124
dre99gsx
The AEM will kill a cylinder randomly rather than close throttle, which will reduce torque but keep boost pressure up. Works real similar to the Racelogic system I use on my Supra, but still have to test if the AEM is "as good".
I did upgrade to 506lb front / 672lb rear springs. Keep in mind this is the 3.0si, which already has a weaker rear sway than the z4m. (22.5mm for the M, 19mm for the 3.0si w/Msuspension). Still, I'll consider detaching it. I also don't have the LSD, thus many variables here that are not typical from most M owners.
Thanks for the tip!
      08-29-2017, 02:38 PM   #125
mattfwalters
I did upgrade to 506lb front / 762lb rear springs. Keep in mind this is the 3.0si, which already has a weaker rear sway than the z4m. (22.5mm for the M, 19mm for the 3.0si w/Msuspension). Still, I'll consider detaching it. I also don't have the LSD, thus many variables here that are not typical from most M owners.
Thanks for the tip!
My pleasure! Precious little information on the net about tracking these fun little beasts.
You're totally right that the open diff will definitely behave differently than the LSD, but at the end of the day (or just past the apex, I suppose), if you have more traction because both tires are able to maintain contact with the track, you'll get more drive out of the corner with any diff. The LSD will help maintain traction at higher throttle openings because it'll distribute the torque better - the open diff will want to spin up the inside tire, as you know - but LSD == open as long as you aren't spinning the tires.
      11-21-2017, 03:06 PM   #126
dre99gsx
Updates:
I use and abuse the car!
GuidoK11118.00
StickMon636.00
wdb4762.50
Arsonism158.00
      11-21-2017, 03:20 PM   #127
GuidoK
#buildnotbought
GuidoK's Avatar
11118
Wow, thats some acceleration on full boost.
      01-24-2018, 02:26 AM   #128
Machine monkey
Machine monkey's Avatar
Drives: 03 3.0 blue z4 (hopfully soon
dre99gsx Let me shake your hand sir bloody well done.
I joined hear to read this and comment on it. The video was posted on a U.K. Z4 forum and I am very impressed. Having done a 1uz swap into a friend’s mk4 supra engine swaps can be a PITA. The old 1jz is sat doing nothing in our workshop........
It really is a great build I must read through it again. To fully understand how your controlling everything. I guess it a standalone ECU? I am sure the answer is in the thread somewhere.
Well done great car
      02-22-2018, 12:30 PM   #129
dorksturhh
Pilot
dorksturhh's Avatar
Drives: z4m coupe
just saw the video on youtube, sick build
      03-08-2018, 10:09 PM   #130
E86Z
Drives: 3.0si
http://www.benchraces.com/img/z4buil...226_120537.jpg
What were the specs on these wheels?
      03-09-2018, 07:50 AM   #131
dre99gsx
18x9.5 et35 w/275 size tires
      03-18-2018, 02:17 PM   #132
nvturbo
nvturbo's Avatar
Drives: 2006 BMW 330i
found a YouTube video of you commenting about your build. Mad props to you and your dedication to make this build happen.
