08-05-2015, 04:03 AM | #1 |
Down Under!!
1624
Rep 4,296
2C31?
O2 sensor..
what would be the tell tale signs of this? i am asking as my car runs beautifully smooth atm… only strange thing I've noted in the last few weeks is the increase in oil temp, roughly sitting about 115degrees.. where as the centre is 100 on mine… possibly related? 2C31 lambda probe front catalyst, trimm control print out of the falt codes.. //////////////////////////////////////////////////////////////////// // BMW Trouble Code list // // ECU Type : Siemens DME MSS70 // Vehicle Manufacturer Ecu Hardware Number : 783 // Vehicle Manufacturer Ecu Software Number : 783 // Hardware Reference Number : 0049R20 // Vehicle Identification Number : WBSDU91097 // Ecu Manufacturing Date : 19.05. // // 1) 2C31 No Fault Code description found ! ////////////////////////////////////////////////////////////////////
Powered by |
08-05-2015, 11:34 PM | #2 | |
636
Rep 3,124
I've been meaning to have a peep at the oil cooler, but I wanted to do it at night when the Sun's not in my eyes. Then every night I get a couple of beers in me and forget. Just had a look and, sure enough, every other hole has a little pebble in it. Souvenirs from the Mojave. Guess I'll be pulling the bumper cover this weekend so I can flush it from behind. You may want to check yours. Brotha from anotha desert.
08-08-2015, 11:06 PM | #3 |
Down Under!!
1624
Rep 4,296
Thanks Stick, ill surely do that mate, front bumper coming off over the next few weeks with the CSL intake install.. ill change oil too, failing that, the O2 sensor, and failing that ill turn the brake cooling slots on the front bumper into split/dual oil cooler slots.
but yeah , fingers crossed its just crap in the oil cooler fins.. and flushing from behind is a great idea mate, thanks.. lol thanks man, yeah gotta love the desert.. but ill take about 20degress C less than what it was yesterday.
Powered by |
08-10-2015, 11:15 AM | #4 | |
Rep 904
08-11-2015, 12:16 AM | #5 |
636
Rep 3,124
I actually live in the Valley, but work in the desert 3-4 times a month.
I wouldn't want to live there. Too cold in the winter!!
08-21-2015, 09:29 PM | #6 |
Down Under!!
1624
Rep 4,296
lol come on, you know you'd love to live in the desert
still waiting for those 2 or 3 sub 40 days.. gotta be soon now
Powered by |
08-22-2015, 11:15 AM | #7 |
Down Under!!
1624
Rep 4,296
just looking at the option guys, if it is 2C31, which O2 sensor is it? anyone got a part number?
just had a further look, on the N54, this behaviour leads you to this.. 2C31 - Lambda probe in front of catalytic converter, trimming control Typically caused by the wrong O2 sensors in the wrong downpipe or a major exhaust leak. Grey wire loom goes to the back pipe, black wire loom goes to the front pipe. is it possible ive got a exhaust leak?
Powered by Last edited by Vanne; 08-22-2015 at 11:22 AM.. |
08-24-2015, 11:25 PM | #8 |
636
Rep 3,124
My Peake Research booklet says:
"2C31 PreCat O2 sensor trim control, Bank 1" So that's pre-cat cylinders 1-3. Here's what I bought off Amazon: Bosch 15168 Oxygen Sensor Banks 1 and 2 use the same sensor. For sake of completeness: Post-cat Bank 1: Bosch 15138 Oxygen Sensor Post-cat Bank 2: Bosch 13951 Oxygen Sensor
09-06-2015, 10:34 PM | #9 |
Down Under!!
1624
Rep 4,296
Stick, pre cat is this one right, but I think you guys have your pre cats else where..
I wonder, like the egt fiasco I had last year if the sensors for this are also different with euro spec to usa spec. http://www.realoem.com/bmw/enUS/show...diagId=18_0658
Powered by |
09-07-2015, 09:13 AM | #10 |
Rep 11,669
I believe euro sensors have longer leads on them because of the location.
Other than that I think the sensors are the same. Sensors are definitely a maintenance item as our cars age.
09-08-2015, 02:27 AM | #11 |
Down Under!!
1624
Rep 4,296
thanks, much appreciated.. i am gonna leave the diagnostics to my imdi, while he has the car apart anyways, and he will order the bosh part thats required.. little bit peeved that the egg plug was actually different between the US and Euro-trash counterpart.
Powered by |
09-10-2015, 11:27 AM | #12 |
636
Rep 3,124
Whoops. Forgot you had euro spec.
