07-01-2014, 09:14 PM | #1 |
Rep 19
Extending Axles
Does anybody know how to or is it even possible to extend your axles? I'm trying to extend it because I'm trying to run a lot of camber to make my wheels tuck but when I added so much camber my axel popped out so I had to run less camber. Any help will be appreciate it. Thanks guys
07-02-2014, 10:34 AM | #4 |
Rep 2,564
Is this for a track experiment or are you doing it for a look? Sounds extreme.
07-02-2014, 04:40 PM | #5 |
Retrograde
18
Rep 390
He's bagged and looking to do so for looks.
07-03-2014, 02:47 AM | #6 |
707
I'm guessing -12 is a typo? The greatest negative camber I've seen rear here is a bit overview-3. Front maybe -4. I know this is for an airbag suspension, but at -12 static (if that's not a typo) I'd think you'd be just running on the inner tire sidewall! But I'll admit I know nothing of the air bag scene.
07-03-2014, 04:46 PM | #10 | |
Ammar
73
Rep 406
2018 F150 Platinum - Black/Black - Leveled on 34's - DD |
07-04-2014, 10:34 PM | #11 |
Rep 12,570
07-05-2014, 05:47 AM | #13 |
1624
Rep 4,296
Mechanically, how does this work? If you continue the axels through, your looking at a 30-40 degree angle at the spline input.. Maybe you don t want to extend the axels, but wanna put a cv-joint on each side that would also give you the illusion of the extended axel and you won't need new bearings/seals every 500 miles :-)
07-05-2014, 10:20 AM | #14 | |
Rep 19
07-05-2014, 11:16 AM | #17 | |
Rep 19
07-05-2014, 02:53 PM | #18 |
Ammar
73
Rep 406
There's a tiny gap between the hood and the bumper. Screws under the hood can adjust that.
07-07-2014, 12:34 AM | #21 |
Rep 1,992
