03-25-2014, 02:31 PM | #24 |
Rep 882
I believe I've kept you (and the Moupe) waiting too long for the Schnitzers. Well, I'm finally done installing the coilovers and the wheels. I will post better pics once it's in traffic again, don't mind the background!
The coilovers are set just shy of an inch (2 cm) from the lowest setting, I'll drive for a little bit with this height and see if it settles more and then adjust and do a wheel alignment. Cash well spent if you ask me! |
03-25-2014, 03:43 PM | #26 |
Rep 882
Thanks! I think it might need to go lower, but as I said I'll wait and see if it settles a bit. No spacers used so it tucks a little up front. To the eye it looks like a lot of camber up front, but I could go wider both front and rear (5-10 mm).
