12-25-2013, 10:04 AM | #1 |
Rep 53
Engine works unstably only in Idle speed ?
The engine of My 2008 e85 z4 works unstably only in idle speed of D or R. It was going well in other situation. The speed will drop only a second and become normal again.(I have changed spark plug and fuel filter already but it did not work) Has someone met the same situation and can give me some advice?Thank s a lot!!
12-25-2013, 02:42 PM | #2 |
M = Midlife Crisis
66
Rep 2,006
Throttle position sensor
2006 Z4MC - #LL93158
01-02-2014, 10:59 AM | #3 |
6 of Diamonds (ret)
82
Rep 566
Could be a leaky vacuum hose or cracked up CCV system. Had similar symptoms at idle (along with going though a bit more oil than usual and Cel's pointing towards O2 sensors, bad coils & worn rings) in my 03 330i.
Turned out to be just the CCV. Not alot of fun to replace but immediate difference.
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
01-05-2014, 05:43 AM | #4 | |
Rep 53
01-05-2014, 06:54 PM | #5 |
Rep 251
Hello amigos,
for the past year or so, I noticed that when cruising between 3k RPMs down to 2.5K RPMs back to 3K X3 = the SES light shows up. The car keeps running normal. It clears it self after 6 or 8 cycles but as soon as I start cruising in those #s.... that freaken light comes on. Once in a while the RPMs will drop at idle and the car will shake a little > but once I start going.... the car drives fine. Every time I check for codes I get the ones on the picture below. I just order a $220 O2 sensor and I hope that solves the problem. I guess I should check the CCV? How do you check the Throttle Position Sensor and what should I look for? OP > didn't mean to take over, but it sounds like we have the same problem Cheers !!! |
01-05-2014, 08:23 PM | #6 | |
6 of Diamonds (ret)
82
Rep 566
O2 sensor is last thing I would test/replace I would check: 1. Air Intake filter dirty? 2. Disconnect/ reconnect MAF sensor looking for change in idle. If idle gets worse when disconnected then MAF probably okay 3. Is the rubber intake boot intact, no cracks? 4. Test each coil - while engine is running disconnect/reconnect each one individually. No idle change while disconnected means coil possibly bad. 5. Are there any vacuum leaks, broken/disconnected vacuum hoses? 6. Is the CCV system intact? Cold weather and time will cause cracks. if so this causes a lack of vacuum that can cause poor idle, excessive oil burn, fouled plugs, etc Good luck Bruce Last edited by BruceJ; 01-05-2014 at 08:30 PM.. |
01-05-2014, 08:45 PM | #7 | |
6 of Diamonds (ret)
82
Rep 566
Good Luck Bruce
2007 Z4Si(gone)
01-05-2014, 08:54 PM | #8 | |
Rep 251
Thanks Bruce... you threw me off by your /// M bumper. I had this problem before and after my valves/shims were checked. For now, Let's hope the new O2 fixes what the car is telling is wrong... if not, then I have a feeling that is vanos related. Thank you much sir! |
01-06-2014, 12:30 AM | #9 |
636
Rep 3,124
cel = Check Engine Light
also called ses = Service Engine Soon 2C93 is Exhaust Gas Temp Sensor Plausibility. 2FDA is Crank Case Ventilation, System Check. Inspect your wiring to make sure nothing got fried by the headers and take off the head-cover cover and make sure no wires are pinched.
01-06-2014, 10:13 PM | #10 | |
Rep 53
:c
01-06-2014, 10:29 PM | #12 | |
Rep 53
01-06-2014, 10:36 PM | #13 | |
Rep 53
01-07-2014, 08:00 PM | #14 | |
6 of Diamonds (ret)
82
Rep 566
http://www.realoem.com/bmw/showparts...37&hg=11&fg=15 Good Luck
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav Last edited by BruceJ; 01-07-2014 at 08:10 PM.. |
