      09-05-2013, 06:26 PM   #1
the dink
Drives: 2005 Z4
Help with wheel selection
I am going to buy some aftermarket wheels. I would like something as close to stock as far as fitment, NO spacers and stuff. Looking for a good wheel that some of you might have tried and like. 2005 z4 17" wheel. Does anyone know what backspacing and offset, and width I need so I can narrow down my search. Thanks for the help!
      09-05-2013, 10:18 PM   #2
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
Here is my setup and specs. http://www.zpost.com/forums/showthread.php?t=819312
      09-06-2013, 07:13 AM   #3
the dink
Drives: 2005 Z4
Looks great and I like the wheel studs. Did the factory center caps fit right in those wheels?
      09-13-2013, 11:00 AM   #4
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
Not really. They were a bit of a pain to fit. Supposedly they are a snap in place thing, but mine for whatever reason, had to be modified to fit. Maybe someone knows something I don't, but I had to take them apart, remove the outside ring's mounts and then glue the ring back down. Otherwise, it was binding and wouldn't go down flush. And then, I had to put tape on the tabs that hold it to the wheel so they didn't just fall off. I'm thinking I did something wrong, but I did order the part based on what I got from APEXs tech support, so, who knows. In hindsight, I would have just used the APEX inserts and called it good.
      09-14-2013, 03:35 PM   #5
BMWZ42.2I
BMWZ42.2I's Avatar
New Zealand
Drives: BMW Z4 2.2I
Have you thought about getting a Msport wheels instead?
