      05-29-2013, 07:44 AM   #309
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
No NVH, and they make shifting a dream. I would do this before AS SSK for shifting problems. I have both, so I can't tell you which is better. Both definitely make shifting crisp and precise.
      05-29-2013, 03:11 PM   #310
beta
Drives: 2006 M Roadster
I'm surprised more people haven't done this mod, it's one of my top 3.
      05-29-2013, 03:37 PM   #311
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^WHS
I ranks right up there for sure.
      05-30-2013, 12:21 PM   #312
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Ordered!
      05-30-2013, 07:49 PM   #313
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by Blind32 View Post
Ordered!
You're going to love this mod!
      05-30-2013, 11:30 PM   #314
Blind32
Blind32's Avatar
Drives: '07 Z4MC
I can't wait! It's like Christmas with me ordering all these parts... I need to stop spoiling myself!
      05-31-2013, 12:19 PM   #315
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
After owning the car for 3+ years, I finally got my act together and removed the CDV and changed tranny fluid to Redline. What a drastic change so far! Next step is Rogue tranny mounts and these puppies will be ordered later this summer.
The Raspinator
      05-31-2013, 02:29 PM   #316
DanFromTucson
Drives: Z4 M Coupe
Installing these does require removing the aluminum reinforcement plate right?
      05-31-2013, 02:50 PM   #317
beta
Do the engine mounts before the tranny mounts. Transmission mounts make a tiny difference, engine mounts transform the car. Just my 2c.
      05-31-2013, 03:08 PM   #318
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
I assume you talking about engine mount brackets. No, you just loosen the engine mount bracket bolts. The allows you to wiggle the engine mount out.
+1
I changed my tranny mount first but this caused my engine mount bracket bolt cracked. You can if you know your bolts are replaced. If it hasn't been replace, you can replace it when you install engine mount.
      05-31-2013, 03:46 PM   #319
SCHMOUPE
SCHMOUPE's Avatar
+1
Very interesting. My bolts were replaced long time ago (probably 5-6 years ago) by previous owner. I am interested in hearing if majority out of folks feel the same way about engine mounts vs tranny mounts.
The Raspinator
      05-31-2013, 07:58 PM   #320
bignosejim
bignosejim's Avatar
Originally Posted by Beedub View Post
ok ZUB.... and everyone.... ive got some nice info on these, had a detailed conversation with phil...
now what was interesting was the conversation about the stock Tranny mounts.... Well.... all the guys that have swapped this out may want to look away.... not only does Vibra-tech say these are an incredibly well designed piece, he also said they are hugely stiff!!!! it will take serious testing to better those mounts, everything from the shape to the construction is top notch and a design Dream.... That comes from the scientists At vibratech....
That's what the VB guys said about our tranny mounts (taken from post #84). So I would definitely do the motor mounts first and forgo the transmission mounts for now. Almost wishing I hadn't thrown away my stock mounts...
      05-31-2013, 08:09 PM   #321
seank
enthusiast
seank's Avatar
48
And what engine mounts are being paired with this tranny mount?
In my experience (s14), it is very important to do engine and tranny mounts together. The engine is what does the most moving, which is transferred to the tranny.
      05-31-2013, 08:18 PM   #322
bignosejim
bignosejim's Avatar
I've got VB road motor mounts and RE Tranny mounts. Did the tranny mounts about 2 months before the motor mounts.
      05-31-2013, 11:43 PM   #323
johanness
Drives: 2008 Z4MC
You'll be fine. Plus the RE ones are stiffer than OE - yes they are
      06-01-2013, 01:24 AM   #324
beta
You should really read the thread.
Have you seen finegan's Transmission Mount Master List?
Read finnegan's transmission thread. Then come back here and read this thread. Notice that every person that installed these engine mounts has very enthusiastically recommended them.
      06-01-2013, 08:45 AM   #325
DanFromTucson
Drives: Z4 M Coupe
[QUOTE=RobMCoupe;14085325]I assume you talking about engine mount brackets. No, you just loosen the engine mount bracket bolts. The allows you to wiggle the engine mount out.
I'm referring to the big aluminum plate under the engine. Part #1 in this pic: http://www.realoem.com/bmw/showparts...57&hg=51&fg=80
Does that have to come off?
      06-01-2013, 09:39 AM   #326
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
[QUOTE=DanFromTucson;14088542]
No it doesn't.
The underside nut is accessible beside the plate & through the control arm.
You will need socket extensions and a universal joint.
      11-25-2013, 10:29 AM   #327
bjbstewart
bjbstewart's Avatar
Drives: 2007 BMW Z4MC
Vibra Tech install notes:
Got my Vibra Tech's installed over the weekend. Thought I'd share a few things I did to make the job a bit easier. First, I made a jig for jacking up the engine. Just a piece of 2x4 with a 3/8" deep half circle cut out to accommodate the oil screen on the bottom of the oil pan. This made for a more distributed weight across the bottom of the pan.
Second, I was frustrated with how the engine doesn't jack up evenly. I could get enough out of the bottle jack to do the drivers side, but not enough to get the passenger side mount. What I did was to use a common cargo strap over the driver side engine mount, limiting its movement. This then transferred the "up" to the passenger side, allowing me to do that motor mount quite easily
Note - be sure to loosen or remove your strut brace before jacking up the engine :-)
p.s. sorry for the picts being out of order, but you get the idea.
[SIGPIC][/SIGPIC]
      11-26-2013, 10:13 AM   #328
Gallardo Rosso
Just a thought...
Installing one road going mount on the right side and a competition unit on the left side of the engine. The engine mount positions are different. One is cantilevered more than the other. One bears the weight of the engine more directly (more idle characteristics) the other mount controls torque (drivetrain movements).
Why should two mounts doing different jobs have the same durometer? Having two different spring rate/damping characteristics may even damp a broader spectrum of vibration. At a minimum it should split the difference in NVH between sets.
Hybrid Vibra Mount conversion would look cool in you mod list too.
      11-26-2013, 10:21 AM   #329
mtrhed
mtrhed's Avatar
13
Drives: 06 AW Z4MR/w211 e63 AMG/325XiT
Go for it!
I have the Competition mounts and get some added NVH just at idle. It only happens at a very narrow rpm range and not all the time. Would be interested to see if a hybrid setup would be the best of both worlds!
06 Alpinweiss Z4M R
Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake
      11-26-2013, 11:01 AM   #330
Beedub
also have the comp units.... after trying both, the road units are more than optimal.... the race units are great if your a track monster and want the least engine movment possible....
