      04-19-2013, 10:49 AM   #1
bassrebel
The Lazy one...
Drives: 16 C300 4Matic
Carver DSP Amp got wet... how screwed am I?
Hey Guys,
Last week a gallon of water I had on my trunk opened and all the water fell on the amp, now it's not working...
Could there be any fix to it, or would I have to buy a new one?
Thanks
Follow me on Instragram @bassrebel
2014 BMW x1 x3.5i 2016 Benz C300 4Matic
      04-19-2013, 11:09 AM   #2
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Check realoem or penskeparts, it is pricy.
      04-19-2013, 01:57 PM   #3
Jroc
Drives: Mcoupe
See if any other cars use the same amp, you might have to get it recoded. Hopefully it's just the unit and you didn't fry any wires
      04-19-2013, 03:15 PM   #4
bassrebel
The Lazy one...
At least I checked and didn't see any fuses blown, so hopefully it wasn't that bad.
Does anyone know which amps can I re-code to be able to use it on my car?
      04-19-2013, 03:17 PM   #5
bassrebel
The Lazy one...
BTW I have an offer for a RedStar DSP... does anyone know if it's compatible?
      04-20-2013, 07:53 AM   #6
ssummers
Drives: 2005 Z4 3.0
Now would be a good time to replace that crappy stock system....
http://www.zpost.com/forums/showthread.php?t=784148
      04-20-2013, 10:56 AM   #7
Jroc
Drives: Mcoupe
Check xoutpost for any amp questions, those guys are bmw audio gurus
      04-20-2013, 11:13 AM   #8
ZStig
instagram 997turbotom
286
Drives: Interlagos Z4MR
I killed mine with a gallon of paint in the old Z. its dead. Time to check ebay..
      04-21-2013, 09:20 PM   #9
gtMc
gtMc's Avatar
21
Drives: '08 MC
'03 e39 m sport  [0.00]
'08 mc  [0.00]
Try an x3 amp. Pretty sure its the same part number as the e85 - e86 amp. Def need to get it recorded tho. Its not a cheap amp. Hopefully someone can sell you a used one.
      04-22-2013, 12:21 AM   #10
TestShoot
I1, I won
TestShoot's Avatar
Drives: E71 M, E60 535i
I gave up and am in phase two of my upgrade. Right now I have the AVX77 JVC headunit, and I am shopping for speakers.
+-============[tSc]==============-+
http://www.TestShoot.com
      04-24-2013, 05:40 AM   #11
bassrebel
The Lazy one...
Dies that mean that I can use a different amp (different part number, still from a z4) and get it recoded?
      04-24-2013, 10:02 PM   #12
gtMc
gtMc's Avatar
21
Drives: '08 MC
'08 mc  [0.00]
Kind of.... iirc, there are 2 part numbers that were use in the z4. It should be the same part number in the x3. Double check them on real oem, or check the thread on amp coding experimental help, we posted them in there.
But if you get the same part number out of an x3, that matches the z4, then you can just recode that to the z4 and you are in great shape.
      04-25-2013, 06:17 AM   #13
gtMc
gtMc's Avatar
21
Drives: '08 MC
'08 mc  [0.00]
searched this AM on the other thread and found this excerpt with part number in one of my old posts:
My wife has an E83... . . . ....and according to what I've read, one of the 2 model numbers for the amp we have in the e85/e86 (65129125751) is also used in the E83
and found this from the other Amp coding thread from MheavNC:
Got my amp replaced with the updated part # 65129138102.. (replaced #65129125751) These amps work with E83/E85/E86 models with top hi fi systems.. Once the new amp is installed, it has to be coded to your car.. This tells the amp if you have navigation/non navigation and if it is for the X3 or Z4..
      04-29-2013, 06:10 AM   #14
bassrebel
The Lazy one...
Great info, thanks!!!
