View Poll Results: DKF section 1 kit - 100 or 300 cell CATs ?????
definitely 100 cell CAT 5 17.86%
definitely 300 cell CAT 14 50.00%
100 cell prefered but would consider 300 cell 5 17.86%
300 cell prefered but would consider 100 cell 4 14.29%
Voters: 28. You may not vote on this poll
      03-09-2013, 04:58 PM   #1
Drives: M2 Comp
DKF Section 1 GB kit - whats your pleasure 300cell or 100cell CATs
I'm definitely in the market to do something about my section 1.
I have headers going on soon and don't want to modify the OE section 1.
To that end I knew DKF is working hard to get a section kit out soon, so I got a hold of Doug and had a long discussion on what the guys would prefer that are interested in a new section 1.
The basic differences and goals for each are pretty obvious.
100 cell = better performance, more rasp, emissions sniff test..... questionable.
300 cell = less performance, less rasp, better chance of passing the sniff test and less chance of a CEL light.
For me I'm definitely in the 300cell camp and would not consider a 100 cell option.
Talking to Doug, he's trying to get the best deal for us and is negotiating with his vendors.
Its important that he knows the split in who wants 100 & who wants 300
This info will really help to get things rolling guys, so if you're thinking out a DKF section 1 kit, please chime in.
& cast your vote in the pole so that we can track what is needed
Please add you thoughts about your choice as it might help others decide.
Lets get his party started
TIA
UPDATE.......
      03-09-2013, 05:26 PM   #2
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
300 cell cats all the way. I'm ready...
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      03-09-2013, 06:19 PM   #3
Drives: M2 Comp
Cast your vote in the pole so we can pass the info to DKF.
      03-09-2013, 06:24 PM   #4
ajw45
Drives: Z4M Coupe
Any idea what the current OEM cell count is?
      03-09-2013, 06:35 PM   #5
bmwschnell
bmwschnell's Avatar
Drives: '07 Z4M coupe; '22 Ford Raptor
Pretty sure our secondary cats are 200. I also think the euro cats are 200. I was planning on getting the 300 count from dkf, but now I'm not sure. It seems like 200 count cats would be optimal.
      03-09-2013, 06:53 PM   #6
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
2006 Z4MC - #LL93158
      03-09-2013, 07:47 PM   #7
Drives: M2 Comp
Don't forget, that if you drop the header CATS, you will still be running fewer total cells.
The two main things for me is minimizing rasp & running w/o CEL Light
Some don't mind the rasp sound , so 100 may be what they want.
      03-09-2013, 09:42 PM   #8
johanness
Drives: 2008 Z4MC
I think it was recently established beyond a doubt (with photos of exposed cats under the heat shield) that the Euro Sec 1 cats are almost TWICE the size of ours.
Less material = better flow/ more power, which is precisely why I feel relocating our secondary O2's & EGT sensor is preferred over buying a used set of Euro Sec 1's.
However DKF's 100cell option would be a step up from that. That gets my vote
      03-10-2013, 05:20 PM   #9
IDLE TIME
IDLE TIME's Avatar
Drives: still searching
Hey guys we really need this information. Please state you opinion 100 or 300 cell cats
Thank you.
      03-10-2013, 05:29 PM   #10
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
I would prefer not adding a tune to support the Fabspeed VAC Headers; if 100, 200 or 300 cell cats allow for the performance gains and no codes I'm in
      03-12-2013, 04:57 AM   #11
Drives: M2 Comp
Finding the results so far to be very interesting.
Nobody has voted "100 cell only"
      03-12-2013, 06:17 AM   #12
Beedub
for me it has to be the 100 cell option, the SS section 1 uses 100 cell and they are passing the emisions test over here in the UK so..... not bad, but ideally doug id like your other option that allows me to swap between the decat and catted sections!! this would be my ideal!!!
      03-12-2013, 06:47 AM   #13
Drives: M2 Comp
What would you do with the secondary sensors when running CAT-less"????
Would you be running CAT-less normally & just put CAT section back to pass emissions?
      03-12-2013, 01:33 PM   #14
Beedub
ian the DKF Decat section has the bungs in place, bear in mind on my s/C tune i can turn these off readily but for neatness purposes have them inplace :-)
during emissio test i simply load my cat'd tune up and put the cat sections in place!! job done!! For us FI guys i can't ignore the decat gains!, were talking 15/20+Whp proven......
      03-12-2013, 02:10 PM   #15
IDLE TIME
IDLE TIME's Avatar
Byron. Don't want to miss lead you the resonators do Not have o2 bungs in them they never did. There was not enough room (OAL ) to put them. In the bypass pipes are the only other option that have the o2 bungs.
      03-12-2013, 03:18 PM   #16
Beedub
i no ;-) i sed de-cat section not resonator ;-) i dont care about it being obnoxiously loud!! just want performance!!!!!!!!!!
      03-17-2013, 12:38 PM   #17
IDLE TIME
IDLE TIME's Avatar
Bump
      03-17-2013, 01:45 PM   #18
Drives: M2 Comp
I'm surprised that 300cell is leading the way.
I thought it would be closer to 50/50
      03-18-2013, 12:40 AM   #19
IDLE TIME
IDLE TIME's Avatar
Bump
Really need your input. Kit should be done by end of month group buy starting shortly. Please sound off 100 or 300
      03-18-2013, 07:02 PM   #20
Drives: M2 Comp
That's great news Doug!
...so far it looks like 2:1 split 300:100
      03-18-2013, 07:49 PM   #21
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
I don't have a horse in the race since I've got a total Euro setup. However, if I were in the market, I'd have to go for the 300 cell. I really can't see 100 cell passing smog in CA with a Euro header setup. I will say this would be a great option, since hacking up the stock cats isn't for everyone (and if not done correctly, is costly), and the Euro Cat solution is big $$$.
Of course, take my input with a grain of salt since again I'm not a potential buyer. I did not vote as I did not want to invalidate the poll.
      03-18-2013, 09:46 PM   #22
Mirko
Mirko's Avatar
Depending on the price I would be in for this. After you tested and passed Ian
My preference would 300 cell.
