Reply
      11-20-2012, 07:39 PM   #309
jd5353
Drives: 2003 z4
2003 bmw z4  [5.00]
Cool 20"s
jd5353 is offline   Reply With Quote
      11-20-2012, 11:42 PM   #310
v3.2mc
Not a New Member
v3.2mc's Avatar
^ here is the non-///m wheel spec page.
interesting design on the hood btw... does it have significance?
v3.2mc is offline   United_States
      12-07-2012, 04:24 AM   #311
Ibinco
Ibinco's Avatar
Drives: BMW Z4M Coupe
Looking to fit the 270M 18" wheels under my Z4MC.
Specs are ET 20 8Jx18 allround...its a square winter setup.Tyres 235/40/18
Has any1 ever done it and will it rub ?
Ibinco is offline   Netherlands
      01-09-2013, 11:22 PM   #312
v3.2mc
Not a New Member
v3.2mc's Avatar
you'll need a lot of negative camber up front to combat the offset. rears are fine.
      01-12-2013, 12:20 AM   #313
Daemonblitz
Commander
Daemonblitz's Avatar
Drives: Imola/Imola Z4MC
2006 Z4M Coupe  [4.27]
For an 18 9.5" ET35 up front - not really worried about outer clearance.
However for inner clearance will it NEED a spacer to clear the strut ?
Daemonblitz is offline   Romania
      01-12-2013, 09:04 AM   #314
v3.2mc
Not a New Member
v3.2mc's Avatar
as long as you're not using the shim kit and stay with 255's or less, you should be fine without a spacer.
my experience comes from a non-forum friend running 9.0" et40 with 265's which comes REALLY close to the strut tower. your setup would be 1mm closer to the strut.
      01-12-2013, 09:48 AM   #315
dorifto88
Drives: 88 Nissan Pathfinder
I have a 9.5 +35 on the front and needed a spacer to clear the strut (I have coiloversuspension)
dorifto88 is offline   Reply With Quote
      01-21-2013, 05:40 PM   #316
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
Had a question, will 245/40/18 Michelin Pilot sport cups on 18x9.5 et35's fit under the fronts with regular suspension and the pins pulled? I am thinking yes?????
Lone Star Chapter BMWCCA HPDE Event Chair & BMWCCA driving Instructor, Street Survival Instructor
"Racing is important to men who do it well, Racing is.... life, anything that happens before or after is just waiting." - Steve McQueen (Le Mans)
TexasZed4MC is offline   United_States
      01-22-2013, 02:32 PM   #317
TexasZed4MC
Little help here guys???
      01-22-2013, 08:52 PM   #318
drbvac
drbvac's Avatar
Drives: 2006 BMW M COUPE
this any help
https://docs.google.com/spreadsheet/...WeUg1b2c#gid=0
2006 M COUPE - one of 38 Imola Red produced for NA that year, ESS 455 Supercharger
drbvac is offline   Canada
      03-17-2013, 07:37 PM   #319
Shipkiller
Shipkiller's Avatar
Drives: 2008 Z4MC & 2003 Z4 Roadster
I need to ask a question about wheel fitment.
I have a chance for a set of track wheels for $300 for the set. They are coming off an 04 Roadster but are NOT the stock wheels. The size is the F=18/8.5 ET 38 and R=18/9.0 ET 38.
I am currently running somewhat stock suspension (Bilsten Dampers, stock springs) with stock wheels, tire size are F=235/R40 18 (-2.5' camber) and R=265/R35 18 (-2.0' camber) with a 10mm spacer. No rubbing.
I calculate that the new front wheels will will tighten up -8mm and the rears will stick out by +4mm.
I am not a wheel gruru so I am asking the question. Can anyone foresee any issues?
Shipkiller is offline   United_States
      04-01-2013, 01:52 AM   #320
Hamoudie
Drives: E39; 06 M coupe ; X5 4.4
Has anyone tried putting in the front 19 x 9 ? Would an offset around 38
work ? I just need to know if it would fit.. If it rubs I can live with it.
Hamoudie is offline   Canada
      04-13-2013, 12:59 AM   #321
604skyline
Drives: 2008 M Coupe
looking for some help,
will these work or is the offset way too aggressive?
http://www.m3post.com/forums/showthread.php?t=827134
604skyline is offline   Reply With Quote
      04-13-2013, 03:10 AM   #322
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
it is a VERY agressive setup, with camber plates proper alignment and a tire setup thats not too wide, it can work.
look at this Z
Originally Posted by The Shoe View Post
Volk TE37SL's
18" Matte Black Edition
Front 18x9.5 ET22
Rear 18x10.5 ET22
Pilot Supersports
Front 245/40/18
Rear 275/35/18
Lowered on H&R Coilovers & Turner Rear Camber Arms
2007 BSM Z4M Coupe - 19" BBS LMs
i2ichal2dZ4M is offline   Reply With Quote
      04-13-2013, 09:58 AM   #323
604skyline
look at this Z
thanks for the reply, I am on stock suspension as of now, but am getting the ohlins group buy coilovers once they are available.
will they work on stock as is?
      04-14-2013, 02:53 PM   #324
i2ichal2dZ4M
Nope, you wont clear front fenders I believe. I'm on stock suspension, with Turner camber washers/spacers and I barely clear running
18x9.5 +35 (w/5mm spacer so technically +30) (-2.5 camber with washers)
18x9.5 +35 (w/10mm spacer nso technically +25 (maxed out OEM -1.8 camber)
      04-14-2013, 02:55 PM   #325
i2ichal2dZ4M
you may want to PM this memeber on how daily driving details. notice he was running 225 up front.
http://www.zpost.com/forums/showthre...ghlight=te37sl
      04-17-2013, 02:37 PM   #326
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [3.83]
I was set on ordering 18x8.5 and 18x9.5 Apex ARC-8's, but the backs are not in stock. My tires in the meantime, are nearly gone.
Could I fit the planned 245/35-18 and 265/35-18 Super Sport rubber for the ARC-8's onto the stock wheels till the ARC-8's arrive?
nmulax is offline   United_States
      04-17-2013, 11:30 PM   #327
i2ichal2dZ4M
245 on fronts is little too wide, rear is fine they will fit though front wont have full contact patch.
      05-03-2013, 11:02 AM   #328
M Theory
Drives: E46 M3
Hey guys will I have any issues running 18x11 +45 in the rear? Based on the 10.5 +22 posts, looks like I'll be fine, fender wise. What I'm wondering though is if it will be rubbing on anything on the inside with that width and high offset. Thanks in advance!
M Theory is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
