      01-07-2013, 12:44 PM   #1
SwissArmy
Why so serious?
SwissArmy's Avatar
Drives: BMW Z4; BMW X5; BMW 733
Stubby project help
UPDATE: I ended up breaking the antenna off by wiggling it about. Turns out the previous owner did glue it in. Surprisingly, my AM and FM work flawlessly. So I just sealed it with plastic seal to prevent water from going in. It looks great without ANY aerial at all to be honest.
Original Post:
Hey guys!
I have purchased a 2.4" stubby from eBay. It is compatible of course.
For the past few weeks (on and off), I have been trying to unscrew my aerial/antenna. It is definitely stuck. I know there are many threads about it, but I really cannot get it off for the life of me. I have tried WD-40. And I've tried vice grips. I am trying to salvage the OEM antenna (not sure why yet). With the vice grips, the rubber outer layer spins and then springs back to place. Any tighter and I will cut through the rubber.
Has the previous owner glued the aerial/antenna in permanently?
I've tried going in from the trunk/boot with a T25 screwdriver, but all my drivers are long. And, I am not sure what I will achieve by doing this. I will have the base out, but then what?
Help!
Thanks!
      01-07-2013, 08:44 PM   #2
3point0
3point0's Avatar
Drives: 2005 z4 3.0
2006 Audi S4 Avant  [0.00]
2005 BMW Z4  [5.67]
mine was pretty stuck too. I wiggled it back and forth a bunch of times (about 5 mins in total) in all direction before i was able to spin it at all. Hope that helps,
2005 Z4 3.0 steptronic | TiSilver on Black | sport & premium package | 108s | Msport seats | wind deflector
OMP strut bar | blacked out emblems | de-french-fried | sound gen | DIY aux input | custom speedo logos | stubby antenna | polished exhaust tips
      01-08-2013, 08:28 AM   #3
SwissArmy
Why so serious?
SwissArmy's Avatar
Will try that today Thanks for the tip!
Any more tips from my fellow zPosters?
      01-08-2013, 10:11 AM   #4
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
make sure you dont bend the bolt part by wiggling. If all fails you can shorten the original antenna by taking the cap off and cutting the whip a bit and screwing the cap on again. Homemade stubby at no cost
The Raspinator
      01-08-2013, 10:35 AM   #5
SwissArmy
Why so serious?
SwissArmy's Avatar
Never thought of that.
Any cons behind this? I will update this thread when I do it tonight.
      01-08-2013, 11:39 AM   #6
SCHMOUPE
SCHMOUPE's Avatar
unless you are an avid listener of AM radio, you will not notice the slightest difference. The FM antenna is located underneath the bumper
The Raspinator
      01-08-2013, 12:02 PM   #7
SwissArmy
Why so serious?
SwissArmy's Avatar
Ah, I mostly listen to AM (the news) or to my ipod connected via the ipod connector.
I will try the wiggle technique when I get home (currently at work), if I still cant' budge it, I will snip it.
Any photos of a snipped aerial? I have a very strange image in my head and I need re-assuring.
      01-08-2013, 07:29 PM   #8
SCHMOUPE
SCHMOUPE's Avatar
you're in luck:
http://www.zpost.com/forums/showthre...=stubby&page=6
The Raspinator
      01-14-2013, 07:58 AM   #9
SwissArmy
Why so serious?
SwissArmy's Avatar
Update OP with pic
      01-14-2013, 09:14 AM   #10
ssummers
Drives: 2005 Z4 3.0
Looks good.
Now stop advertising for Parkview BMW and rip that plate frame off...
      01-14-2013, 10:20 AM   #11
SwissArmy
Why so serious?
SwissArmy's Avatar
Originally Posted by ssummers View Post
Looks good.
LOL! I'm at work, and this cracked me up.
Good point, I will be ordering a couple of plates (maybe custom?) or no frame at all?.
