      12-02-2012, 07:03 AM   #1
exdos
England
Drives: Z3 M Coupe(S54) and Z4 M Coupe
Datalogging
I've been looking through some datalogging recordings that I made a while back from my Z4MC from the ECU via the OBDII socket. The datalogger will record any of the PIDs (Parameter IDs) that the ECU will divulge. The Z4MC will simultaneously yield both Airflow Rate from the MAF but also Airflow Rate from a MAP as shown in the graph below. I am confused! Does the Z4MC have a MAP sensor and if so what is the part number and where is it situated? If not, I wonder what the datalogger is recording?
      12-06-2012, 02:16 PM   #2
exdos
England
77 views and no response. Does nobody know the answer to this question?
      12-06-2012, 03:01 PM   #3
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
I'm not an expert on this, but from a few searches 'round the web, looks like we don't have a MAP on the S54. MAF, yes.
      12-06-2012, 03:23 PM   #4
Rated M Roadster
Rated M Roadster's Avatar
37
Drives: F10 M5
Just a MAF: http://www.shipkiller.com/Air_Induction.html
CURRENT ll F10 M5
SOLD ll E70 X5M
SOLD ll Z4MR VF570
      12-06-2012, 04:31 PM   #5
exdos
England
I was 99.9% sure that there's no MAP sensor on the Z4M. So what exactly is the datalogger reading from the Z4MC's ECU as "Airflow from MAP"? Other BMWs with S54 engines don't yield as much information from their ECUs and there's is no "Airflow from MAP" available on them.
As my graph shows, the plot from the MAP is similar to that from the MAF, but smoother (as if regulated) so it appears as if it must, in some way, be related to the airflow, but exactly what I'd like to find out?
      12-06-2012, 05:46 PM   #6
Finnegan
Finnegan's Avatar
You'd have to ask the scanner development/support team what channel they are reading. Know of no other way to answer this, sorry.
      12-06-2012, 05:54 PM   #7
exdos
England
Thanks! I think that's the way to go. I'll post the reply when i get it.
