      08-19-2012, 01:31 PM   #1
arobyte
Drives: 2006 BMW Z4 M Roadster
Z4M rough idle, loss of power, stuttering & sounds like a diesel VIDEO
Had my z4m sitting for about 5 months and in starting it and charging the battery, it ran fine for about 10 mins. It idled fine and suddenly started jerking. The idle was very rough and there was a rattling sound. The rattling I later discovered was the transmission as they can be clunky on the Z4M. But the rough idle and huge loss of power and stuttering of the exhaust I don't know. Have drained the fuel and replaced with new*clean fuel and same thing. On revving, there is a stuttering sound from the exhaust. There is no real*audible hissing that might suggest a vacuum leak. I had read the codes and it said misfire on multiple cylinders.
Upon more research, I'm leaning towards bad coils but will 1 or 2 coils cause all cylinders to misfire?
      08-19-2012, 03:00 PM   #2
Beedub
i winced as you revved that sick engine :-(
sounds like a bad coil....
      08-19-2012, 03:06 PM   #3
Drives: M2 Comp
^this
      08-19-2012, 05:15 PM   #4
arobyte
I know the revving would cringe a lot of people. But to get the most info out there wanted to show both idle and higher revs.
Car has 60k kms and unless bmw change coils as regular maintenance, I don't remember ever changing any.
Thanks.
Up for more suggestions.
      08-19-2012, 05:21 PM   #5
zimmer
zimmer's Avatar
Drives: 2007 Z4MC
2007 BMW Z4 M  [2.00]
rough idle
i had the same problem it cost 700 dollars, what they did was replaced the breather valve its simple to do the part is 150 dollars it right at the top of engine they hit me for 3 hours labor which was bull shit
      08-19-2012, 06:10 PM   #6
arobyte
So it could be that too then.
Will one dead coil cause such a rough idle?
      08-19-2012, 07:29 PM   #7
Kgolf31
Kgolf31's Avatar
464
Drives: 2007 Z4MC, 2012 128i
Blown Coil.
What do you think the car would do when 5 out of 6 cylinders are firing?
Weight distribution gets thrown off...yada yada yada.
If you knew you were low on oil would you rev the engine? Probably not. The same is here, don't rev it.
      08-19-2012, 09:17 PM   #8
zimmer
zimmer's Avatar
Drives: 2007 Z4MC
There are rude people on this site, do your self a favor and have the dealer look at it have it towed and fixed by pros. it could be a cheap fix or a expensive fix just be prepared with your wallet. Thats the price we pay for these animalistic cars
      08-19-2012, 09:18 PM   #9
zimmer
zimmer's Avatar
Drives: 2007 Z4MC
anither thing mabey your valves need to be adjusted and thats about 3000 dollars at BMW
      08-19-2012, 09:40 PM   #10
elerner61
elerner61's Avatar
159
Drives: '07 Z4M Roadster
I've been thinking, since coils are pretty cheap at about $30 each and pretty easy to install, why no replace all of them at about the 35K miles mark? Having one go "not on my schedule" would be a pain in the ass whenever it happened.
What does the general consensus think? Why would this be a bad idea?
      08-19-2012, 10:04 PM   #11
chickdr
Drives: 2006 M Roadster
Not at all. I have seen posts about folks who carry a spare coil just in case it happens out on the road.
      08-19-2012, 10:32 PM   #12
Mueller944s2
Drives: '90 Porsche 941, Z4 Roadster
Ours was firing on 5, just a rough idle. Did you put stable in the gas? If you didn't you may have nasty gas in there, even if you drained it. On my Porsche the other day I had a rough idle and it kept dying. I would try to rev it and it wouldnt go then all of a sudden surge upward. I held the rpms up and eventually whatever was in there blew through. There's my two cents
      08-19-2012, 11:43 PM   #13
arobyte
Thanks for your advice. I wish it were that simple. The car is in west Africa now where getting a dealer is hard and trIal and error expensive. So I'd rather have as much info as possible before going in to see one.
      08-20-2012, 06:43 AM   #14
chickdr
Wow- I would not want to have a car like this in that region of the world!
      08-20-2012, 08:08 AM   #15
Drives: M2 Comp
buy a code reader to help diagnose the issue.
could save you a lot of guessing & they aren't expensive.
      08-20-2012, 09:11 AM   #16
arobyte
This region of the world is not what you might think. There are a lot more than what national geographic shows.
      08-20-2012, 09:16 AM   #17
arobyte
I'll buy one. The car had just been so trouble free I got comfortable I guess.
      08-21-2012, 11:14 AM   #18
chickdr
Based on your previous post it doesn't sound comparable to US or Canadian standards....
      08-21-2012, 03:55 PM   #19
arobyte
That'll be a discussion for a different thread.
Mechanic said it's three of the six coils that went bad.
Will swap them out and update.
      08-21-2012, 05:32 PM   #20
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
2006 Z4MC - #LL93158
      08-21-2012, 06:01 PM   #21
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E39M5
2008 BMW M3  [0.00]
You're killin' me ovah here ...
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Coby Alcantara | StrongStrut STB
      08-21-2012, 07:14 PM   #22
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Some here will take offense to this...
