05-13-2012, 02:24 AM | #1 |
Rep 194
CDV Quick Question
Hello,
I don't have warranty with my stealership and not worried about it.. Should I delete the CDV or install modified one?? Is it possible actually to just delete it? 2006 M Coupe E86 Thanks |
05-13-2012, 08:43 PM | #5 |
Rep 855
Just delete it. I did it while under warranty and they never even noticed
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
05-14-2012, 06:11 AM | #6 |
Rep 704
Drives: '08 MC
yes pretty sure you need to bleed it too. They def bled mine after they opened up the line for the CDV job.
06-03-2012, 01:25 AM | #8 |
636
Rep 3,124
I replaced mine with a modified one, because I was afraid the hose wouldn't easily reach.
Turns out it would have. I used a "hose squeezer" to keep the leakage to a minimum, and did a fast swap. Didn't lose any fluid except what was in the volume of the CDV. Just did a quick bleed to work that one bubble out. Much smoother shifts from 1st to 2nd, and less clutch wear. Definitely a "must do" mod. |
07-20-2012, 05:29 PM | #10 |
Rep 8
Not to high jack the thread, but typically how much would it cost to have an indi shop change the CDV for you? I'm I'm northern NJ and was quoted $300 to replace the CDV as well as change my diff and tran fluids. Which by the way I be providing Redline fluids.
07-20-2012, 06:06 PM | #11 | |
Rep 280
Seems a bit pricey. |
07-24-2012, 09:14 PM | #13 |
Rep 704
Drives: '08 MC
Had mine done along w a tranny mount swap at same time for about the same amount. In north Nj.
07-25-2012, 08:54 AM | #14 |
Rep 69
My Indie pulled my CDV off while he had the car on the hoist for something else...no extra charge for the 5 minutes it took him. Hardly worth trying to do it yourself when you can get it done for nothing.
