Reply
      04-30-2012, 06:14 PM   #1
Eddy@ApexRaceParts
Drives: E30 M3, E34 540i/6, Cooper S
Post Official: APEX EC-7 wheel thread
APEX is proud to introduce its new EC-7 wheel. This new wheel addresses the concerns of more and more racers and track day enthusiasts: long term durability, fit and performance. With the increase of faster and heavier cars being used in racing, HPDEs, and spirited driving, the EC-7 was designed and engineered to handle extreme abuse on track and street, offer a wide range of direct fitments, while producing a lightweight wheel. The new features offered make the EC-7 the perfect compliment to the APEX ARC-8.
Anthracite Finish Profile 3
An optimized car setup begins with the perfect wheel fitment. Without the perfect offsets, maximum tire widths and the potential of your car are always compromised. With this in mind, the EC-7 has three unique face profiles ranging from shallow to deep concavity resulting in 13 unique 18″ sizes. This wide range of fitments allows for vehicle-specific caliper clearance, offsets, and tire widths, creating the most optimal setup possible.
Available Sizes and Weights:
18x8.5" ET45 - 19.55lbs
18x8.5" ET35 - 20.10lbs
18x9.0" ET42 - 20.75lbs
18x9.0" ET31 - 21.25lbs
18x9.5" ET58 - 20.65lbs
18x9.5" ET43 - 21.55lbs
18x9.5" ET35 - 21.70lbs
18x9.5" ET22 - 21.75lbs
18x10" ET43 - 21.70lbs
18x10" ET33 - 22.50lbs
18x10" ET25 - 22.45lbs
18x10.5" ET27 - 22.50lbs
18x11" ET25 - 23.35lbs
Available Finishes
Race Silver
Anthracite
Satin Black
The EC-7 adds 7 new BMW sizes not available in the ARC-8 design. The 3 face profiles offer maximum concavity and reduced weight. This avoids the common adaptation of a single face profile for unintended fitments or dependency on spacers.
The EC-7′s spoke profile has been designed with a curve to provide additional caliper clearance. It can clear a BBK spacer free on applications where the ARC-8 could not. A significant improvement to the EC-7 is the increased barrel clearance that now allows for the 18″ version of this wheel to properly clear the Brembo 380mm BBK. A detailed list of which wheels can clear which brake kits will be made available.
Anthracite Finish Profile 2
Anthracite Finish profile 1
Just like the rest of the APEX wheel line, the EC-7 is once again produced using the Flow-Forming technique. Flow-forming, which has also been called “roll forging” or “spin forging”, produces a barrel with similar strength to that of a fully forged wheel. This significantly reduces weight in the barrel, which has the greatest impact on rotational mass. We’ve produced an even stronger wheel by combining the strength of the lightweight barrel with a more robust face design. The EC-7 welcomes endurance racing and potholes.
Designed for BMW applications, the EC-7 accepts TPMS sensors, factory lug bolts or stud conversion kits, and OEM roundel center caps. All wheels come with APEX center caps.
The EC-7 prototypes have arrived and we will be test fitting on numerous applications (fitment photos to come). After VIA crush testing and certification the expected arrival date for the first batch is July.
Satin Black Finish Profile 3
Satin Black Finish Profile 2
Satin Black Finish Profile 1
Race Silver Finish Profile 3
Race Silver Finish Profile 2
Race Silver Finish Profile 1
This thread will be used as a technical discussion for the fitment of these wheels.
Eddy@ApexRaceParts is offline
      04-30-2012, 06:14 PM   #2
Eddy@ApexRaceParts
reserved for additional fitment details
Eddy@ApexRaceParts is offline   Reply With Quote
      04-30-2012, 06:27 PM   #3
Daemonblitz
Commander
Daemonblitz's Avatar
Drives: Imola/Imola Z4MC
2006 Z4M Coupe  [4.27]
In to find out if the 9.5" ET 43 with a 245/40-18 can clear the suspension components on the inside without the use of a spacer.
Daemonblitz is offline   Romania
      04-30-2012, 07:36 PM   #4
pokeybritches
pokeybritches's Avatar
Drives: G-Power Z4M, VF Z4 3.0i, ZJ
2003 BMW Z4 3.0i  [4.33]
2006 BMW Z4M  [0.00]
I will be buying a set as soon as they become available.
G-Power Z4M (April Install) and VF Engineering Z4 3.0i - too many mods to list
pokeybritches is offline   Afghanistan
      04-30-2012, 08:03 PM   #5
Blind32
Rennfahrer
Blind32's Avatar
Drives: '07 Z4MC
Send a message via AIM to Blind32 Send a message via Yahoo to Blind32
Bravo Apex! Great work! Can't wait to see them on a Z4M. Are any Z4Ms local to you that could do a photoshoot?
Blind32 is offline   United_States
      04-30-2012, 08:24 PM   #6
ZeD4Mr
Drives: MR
In for any other finishes? Hyper Black in particular...
ZeD4Mr is offline   Reply With Quote
      04-30-2012, 09:49 PM   #7
v3.2mc
Not a New Member
v3.2mc's Avatar
i'm very interested. subscribed!
v3.2mc is offline   United_States
      04-30-2012, 11:43 PM   #8
BIMMERGUY91
Drives: 2007 Sapphire Black Z4 M Coupe
cant wait for these to come out. What is the pricing going to be? Do you think the 18x9 +31 will fit up front with a 245/40/18 lowered on H&R's
07 Z4MC #1019/1815
BIMMERGUY91 is offline   Reply With Quote
      05-01-2012, 12:14 AM   #9
007MCoupe
007MCoupe's Avatar
Drives: das Bierwagen
2007 Z4 M Coupe  [0.00]
Yeah, pretty much know where my tax refund is going! :
Good job APEX!
RPI scoop///VB3///75mm wheel studs//////Stubby///GoMiniGo///GC front sway bar///AKG Engine Mounts///AKG Trans Mounts///SS brake lines
Harris Hill Road, LVMS, Ring...
007MCoupe is offline   Reply With Quote
      05-01-2012, 01:04 AM   #10
XMetal
XMetal's Avatar
Drives: '04 X5, '08 Z4MC
2008 BMW Z4MCoupe  [0.00]
2004 BMW X5  [0.00]
I'm thinking about running 245F/275R or 255F/285R rear. Assuming stock height and no fender modification, what's the best width and offset?
XMetal is offline   Reply With Quote
      05-01-2012, 01:35 AM   #11
Beedub
paintpro any advice here??
fitment id go for is the 18x8.5 +35 and concave 3 18x9.5 +22 or 18x10+25... for the rear which one do you guys think would the least chance of No rub, these sizes are relatively identical from what i can see with the lower offset on the 9.5" rim or the slightly higher on the 10" rim, am i right in thinking these are basically the same size??
Beedub is offline   United Kingdom
      05-01-2012, 11:25 AM   #12
gferil
gferil's Avatar
Drives: 06 Z4MC
In the bay area...there are at least 14 of us that I know about since we just had the meet a few weekends ago!
Seriously though, PaintPro, when these come out I would love to stop by and see the anthracite finish in person, I've been looking for a wheel and finish that goes well with the Silver Grey paint that is a bit on the darker side but not quite black.
Good job on the wheel, looks amazing from the pictures and I will most likely be ordering a set if the Anthracite finish is as nice in person as it looks on the pictures!
gferil is offline   Reply With Quote
      05-01-2012, 11:33 AM   #13
Eddy@ApexRaceParts
I'll follow up with questions ASAP.
I just updated the size list by adding 18x10" ET43 with weight info.
      05-01-2012, 05:43 PM   #14
Cal@Sonic MS
Cal@Sonic MS's Avatar
Drives: E39 M5 & E28 528e
Subscribed. Can't wait until I get my hands on a set of these. They will be my track setup for sure.
email : cal@sonicms.net | tel : 650.733.6506 | aim : calatsms
Facebook | Instagram @sonic_ms | YouTube
Cal@Sonic MS is offline   United_States
      05-09-2012, 11:06 AM   #15
BIMMERGUY91
updates? Still eager to see pricing? Is there going to be a group buy?
07 Z4MC #1019/1815
      05-12-2012, 02:48 PM   #16
mpm3
mpm3's Avatar
Drives: 2007 M coupe
2007 BMW M coupe  [5.00]
2011 BMW M3  [0.00]
im down i love them !
mpm3 is offline   United_States
      05-12-2012, 04:17 PM   #17
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
Yea, I thought I would never replace my OEM wheels, but looks like I am down for these as well........... 18×8.5″ ET35 and 18×9.5″ ET22, I am thinking. Ran these on the wheel offset calculator and the clearance improves on the backside by a millimeter or 2, and extends out 13mm more in front and 14mm more in back compared to stock. With 245/40 in front and 275/35 in the rear, will rubbing be an issue? I have seen a lot of guys here running the 12.5mm spacers with no issues, but I think I read of a guy running 15mm spacers that had some rubbing on a lowered car. Comments?
John
antennahead is offline   United_States
      05-12-2012, 09:26 PM   #18
BIMMERGUY91
18x9.5 et22 with a 275 will easily fit
07 Z4MC #1019/1815
      05-12-2012, 10:57 PM   #19
antennahead
Should be close to flush as well, yes?
      05-13-2012, 08:58 AM   #20
BIMMERGUY91
Definitely. And if you like hellaflush just add a spacer lol
07 Z4MC #1019/1815
      05-13-2012, 11:38 AM   #21
mfanatic325
///M-fanatic
mfanatic325's Avatar
Drives: '07 Z4MC, '04 325Ci
Send a message via AIM to mfanatic325
I went in to tesy fit for you guys, so the pix should be posted up soon =]
VF570 S/C|TIAL BOV|SetRabCooler|Brembo GT 6/4|TE37s|NT05s|3.91 Gearing|TCK D/A|RPi Induction|SS Race Mufflers/X-pipe|JVT Headers|AS SSK|Sparco Pro2000/6pt.Harness|MS FloorMounts|SE Custom Harness Bar|Tekarbon Angels|M-Tech Pedals|OE Strut Bar|RE RSMs|8000K D2S|CDV DEL|CF Roof Wrap|MB Grills|UUC TrannyMounts/ClutchStop|V1 Mount|P3C Gauge
mfanatic325 is online now   Taiwan
      05-13-2012, 11:47 AM   #22
XMetal
XMetal's Avatar
2004 BMW X5  [0.00]
Thank You If I'm not mistaken, aren't your fenders rolled?
Reply
Tags
18x10, 18x9, 18x9.5, apex, ec-7
Forum Jump
