04-02-2012, 09:52 PM | #23 |
Rep 637
OP - Is it too much to ask for a list of the special tools you purchased? Would be great to know what you thought were the necessary items - there is a lot of back-and-forth on what is truly needed and what is recommended by BMW - or just nice to have...
Nice wheelin' BTW!
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
04-03-2012, 12:24 AM | #24 |
///M-fanatic
193
Rep 3,885
I'll answer on OP's behalf (since we're friends). Here is a screen shot of the order he put in. If you go through it, you'll find the tools he ordered.
04-03-2012, 01:14 AM | #25 | |
Rep 266
All BMW special parts you see on the list are a MUST for Z4M. If I recalled correct... 11-34-0-031-525 Set of Small Adjust - Shim kit 83-30-0-493-743 Magnetic Lifter - shim picker 83-30-0-493-749 Template - Camshaft timing tool 83-30-0-493-429 Tester - Black box tool/VANOS switching unit 83-30-0-491-148 adapter lead - connecting black box directly to your battery terminals 83-30-0-493-430 Connector - air compressor connector to your VANOS You can't remove VANOS unit without black box, adapter lead, and connector. Unlike E46 M3, Z4M has a crossbar right in front of VANOS. The black box tool + air compressor extend the VANOS pistons allowing you to disconnect VANOS from the helical gears, then retract VANOS pistons for easier removal in such tight space. You will also need a BMW TDC locking pin (I got my from ebay $12, it was too long but I use dremel to cut it shorter. 07+ uses a slightly smaller locking pin. Putting the engine at exactly TDC is very important, I wouldn't suggest making your own TDC locking pin.
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual 2006 BMW 330i 6spd manual - gone Last edited by runnerx; 04-03-2012 at 10:28 AM.. |
04-04-2012, 12:11 PM | #26 |
Rep 637
runnerx, mfanatic325 - thanks a bunch! Very useful info to have. Good thing is that you could probably resell these tools down the road if one was certain they wouldn't be needed again.
I've been wondering for a long time about what were the truly necessary tools for doing this job specifically on a Z4M. I had an M3 for a while and when I owned it was when I became aware of this problem. The job on a M3 is actually substantially different, as you mentioned, because that front cross member is miles further away than it is in the Z4, relatively speaking. Way more DIY info is available based on the M3 but overlooking this little detail would result in massive frustration doing this job on a Z4M.
