09-19-2011, 10:27 PM | #1 |
Rep 1,543
Stud conversion with close end nuts.
Will the turner motorsport's 75mm stud conversion kits work with close end nuts? What's the length of the close end nuts to use for 75mm stud with no spacers as of now?
I found some are 26mm, 35mm, 40mm and 48mm. Anyone with 75mm stud use any of the above length open end nuts with installed picture? thanks, Last edited by ZeD4Mr; 09-19-2011 at 10:40 PM.. |
09-20-2011, 01:48 AM | #2 |
///M-fanatic
193
Rep 3,885
I remember putting in 38mm Gorilla studs, and use Spoon lug nuts, which are considered "extended". Not sure how long the Spoon lugs are exactly.
Anyhow, g'luck man I was of absolutely no help to you |
09-20-2011, 06:22 AM | #3 |
Rep 5,329
i use the turner 75mm with kics r26 composite nuts open ended..... such an awesome combo which not only makes life much easier, it looks awesome as well.....
the 75mm nuts WILL NOT work with a closed end nut as the top half is like a smooth donut end with a hex end..... just use an open ended nut much better in everyway!
09-20-2011, 09:49 AM | #4 |
Rep 1,543
Do you have a picture of them installed? Does the 75mm stick out of your R26 quite a bit, if so how much? If you can measure it, it'll help me a lot.
BBS set seems to use 80mm with close end nuts. I don't like the look of open end and I don't use spacer for all 3 of my wheel sets. thanks, |
09-20-2011, 09:51 AM | #5 |
Rep 5,329
when i get home ill post you some deailed pics, the rear stick out slightly... the fronts with a 12mm spacer are flush...
09-20-2011, 09:55 AM | #6 |
Rep 1,543
So I guess I can assume. 12mm spacer + 26mm nuts = 38mm flush. So 40mm+ closed end is the answer?
I'll wait for your detail picture then ... thanks Beedub, |
09-20-2011, 10:21 AM | #7 |
Rep 11,667
I agree with Beedub.
The Kics are great lug nuts. I'm using 90mm studs, so I use the R40 which are longer and hide the stud entirely. I love the floating seat on these as well; wheels torque down more evenly and don't damage the wheel nut seats.
09-20-2011, 01:28 PM | #8 | |
Rep 5,329
POW..... cant get any more than that......
09-20-2011, 04:25 PM | #10 |
Rep 5,329
lol they are AWESOME!!!! after a full day of driving with VT2 power on the track these things were rock solid..... the rotors went bright blue!!! They are the best brakes ive every experienced... ever...... the only braking system ive felt with as good feel was a 997 GT3 RS..... ;-)
09-21-2011, 02:20 AM | #13 |
Rep 1,543
Beedub,
Thanks for the detail pictures. It shows me what I think I can accomplish. 75mm is way too long for my purpose w/o spacers. 75mm - 12mm spacer = 63mm.. Seems like 30mm closed end will work with 60mm studs with room to spare. If I go with 60 mm, I can use 30mm closed or 26mm open for flush look...I'm now onto the hunt... What's a good 60mm stud set if anyone knows? Maybe this? http://www.ecstuning.com/Volkswagen-...II--2.0/ES202/ |
09-21-2011, 04:47 AM | #14 | |
Rep 5,329
09-21-2011, 06:43 AM | #15 | |
Rep 11,667
09-21-2011, 11:51 AM | #16 | |
Rep 1,543
From your pic, 64mm is exposed after stud installed into the hub. assuming Beedub using 12mm spacer is flush with 26mm nuts wheel mounting width = 75mm - 12mm - 26mm = 37mm 60mm stud - 37mm wheel = 23mm Should I conclude that 60mm H&R studs with Kics 35mm close end nut should fit with room to spare? How many turns do one need to safely secure a nuts to studs? Studs - http://www.ecstuning.com/Volkswagen-...II--2.0/ES202/ Nuts - http://www.evasivemotorsports.com/me...tegory_Code=L1 |
09-21-2011, 02:32 PM | #18 | |
Rep 11,667
The rotor hides part of the threadless shank in the middle.
09-21-2011, 02:50 PM | #19 |
Rep 5,329
+1
09-21-2011, 03:02 PM | #20 |
Rep 5,329
thanks, its taken me years to build this car up...... much much more coming soon ;-)
09-23-2011, 11:26 PM | #21 |
Rep 919
Drives: BMWs
Garage List 2008 E60 M5 6MT [0.00]
2019 G01 X3 sDrive30i [0.00] 2007 E86 M Coupe [0.00] 1997 E36 M3 [10.00] 2006 E53 X5 4.8is ( ... [0.00] 2006 E85 M Roadster ... [0.00] 2002 DINAN 5 (sold) [0.00] 2013 E89 Z4 sDrive3 ... [7.00] 2011 E92 M3 (sold) [0.00] 2001 E46 M3 (sold) [0.00] 2007 R56 Cooper S ( ... [0.00] 2002 996TT (sold) [10.00] 2009 E82 135i (sold) [9.00] 2006 E85 Z4 M (sold) [6.00] 2007 B7 A4 2.0T (re ... [0.00] 2003 E46 M3 (sold) [0.00] 2002 E46 325Ci (sold) [0.00] |
Help with BBS lugs!!
So I bought the BBS red lug kit and have been researching and contacting numerous vendors (even BBS USA themselves) to see what types of studs I need. Can't seem to get a for sure answer from anyone.
Does anyone know what I need in terms of the thread size and stud length?? I plan on running 10mm spacers in the rear. This is the kit I bought: Last edited by suprtran; 09-23-2011 at 11:46 PM.. |
09-24-2011, 05:21 AM | #22 |
Rep 5,329
wow those BBS nuts are gorgeous..... unfortuntly i cant help you with lengths, im sure the other guys will be in shortly to help you out :-)
