Originally Posted by bfm01
Hi, I've only had my 2006 Z4M Coupe for a couple weeks now. It has 68,000 miles and it's difficult to shift into first from rest and then second. The other gears are no trouble. I make sure the clutch is all the way in but still. It's not a crunch but more like something is in the way? Not sure if this is common or if there could be an adjustment made. Thoughts? Thanks!
Do you know if the transmission fluid has been changed? If not, that will definitely help. Royal Purple Synchromax is a member favorite. I'm running Redline D4. Both make the transmission shifting much smoother, but the Redline seems to breakdown over time. I have two years on my current fluid, and it's beginning to get a little notchy again. I'm going with Royal Purple when I change it out at Inspection II.
Also, a weighted shift knob had a very noticeable improvement for me. I used the lighted weighted shift knob from an M5 (F10), and cut and glued the leather boot onto the Z4 plastic retaining "hoop."
http://www.zpost.com/forums/showthread.php?t=1422560
Salty
