05-07-2014, 01:54 AM | #1 |
Rookie
33
Rep 379
Coding Coupe DSP settings to Roadster DSP settings
This is intended to be a working document. I will need you guys to run through it and let me know where you get stuck. Please post questions and comments and I will update the first post if anything is omitted.
Disclaimer: I provide these instructions to the DIYer, but assume no responsibility for the outcome of your actions. Purpose: Code your E86 DSP system to E85 settings. Generally, people believe the M Coupe DSP to suck and the M Roadster DSP to be acceptable. I certainly concur coming from a convertible to a coupe. I could not believe how bad the Z4MC stereo sounded. After coding as per these instructions, I feel that the stereo is good enough for me. Instructions : 1. Buy cable from E-bay (K+DCAN) Interface. Make sure pins 7 & 8 are shorted. If not, solder them together (I had to do this). 2. Get INPA files. Google is your friend. 3. Follow installation instructions EXACTLY: -Watch this Youtube: -Install software -Windows USB Settings w/ 1ms Latency -USB Drivers (wasn't necessary for Win 7 Pro) 3a. Run Dcan tools DOS program to set the mode of the cable. (File attached) 4. Run INPA, play around a little bit. 5. Install English file for NCS Expert (File attached) 6. Install Revtor profile. (File attached - YOU MUST rename extension to .PFL) 7. Follow this Youtube video by Kris Lindquist (we will not be needing NCS Dummy since we already have the file necessary to complete the coding.): 7a. Make sure the file you create is really .MAN and not .MAN.TXT (Windows 7 show extension). 8. Read DSP module trace from your car using NCSexpert, and save it as another name. (This step is to backup your factory settings in case something goes wrong during the coding.) 9. Download E85 coded file, and rename to .MAN (File attached) 10. Upload/program E86 with E85 coded file 11. Done
2003 Z4 2.5i
2013 FR-S 1990 911 C2 1983 Wife Last edited by donoman; 05-07-2014 at 04:49 PM.. |
05-07-2014, 04:42 PM | #2 |
Rep 2,546
Great writeup. I'm glad you were able to make use of the "E86 DSP_E85.C02 FSW_PSW coded to E85.TRC.txt" file I edited. I read in the file from my 2007 E86, edited all the values I thought should be changed from E86 to E85 and saved it. I don't know if it ended up identical to a factory coded E85 car. If would be great if someone could post a factory coded E85 DSP file so we could compare the one I edited to see if the 2 files are the same.
Also the DSP module version I have is a C02. I don't know if they used different model DSPs in these cars. If you don't have the same model module, I would not use the file in this post since I don't know what would happen to your DSP. |
05-07-2014, 04:49 PM | #3 | |
Rookie
33
Rep 379
By the way, I have a 2006 MCoupe and it worked on my system. As long as the user downloads his original trace first, and saves a backup, there should be no worries. Thanks for the feedback. Now we need someone to try this on their own so we can see if the write-up is effective.
2003 Z4 2.5i
2013 FR-S 1990 911 C2 1983 Wife |
05-07-2014, 05:17 PM | #4 | |
Rep 2,546
08-14-2014, 06:51 PM | #5 |
Rep 45
Figured I should drop this in here, too. This is my trace file with ONLY the 55 filterbaenke changed. To me, this sounds better than what pungo has provided, but sound is subjective. Try both and see which one you like better
08-24-2014, 08:06 AM | #6 |
Rep 400
I changed my dsp module as above and HOLY COW!! What a difference. That was the best 5 minutes I've spent on my car period. Thanks to everyone for the effort put in to this. BTW my dsp module was also version C02 (2007 M Coupe). I ended up just changing my original file through NCSdummy and recoding the module.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500 |
08-26-2014, 03:16 PM | #8 |
636
Rep 3,124
Does anybody know if this can be done with Rheingold?
I installed Rheingold and got as far reading the VIN. Been too hot and too many other things to play with.
08-27-2014, 09:54 AM | #9 |
Rep 400
Rheingold only does diagnostics, at least the windows version. You can also download ista to do programming (in vmware). I kept my old versions of INPA and NCS. I just renamed my old ediabas folder to ediabas 6.4.7. then whenever I use the old programs I rename the ediabas that Rheingold uses to ediabas 7.3.10 and rename version 6.4.7 to just ediabas. Those old programs are still insanely easy to use and my old laptop doesn't have enough disc space to try out the new ista program.
09-20-2014, 05:52 PM | #10 | |
Rep 2,546
10-16-2014, 10:42 PM | #11 |
Rookie
33
Rep 379
I'm wondering why, even with the E85 coding (Pungo's) the sound is still more muddy than my damn non-M z4 2.5i roadster!!! (BMW Business CD) GAHHHH
2003 Z4 2.5i
Tags |
inpa ncsexpert coding dsp |
