BMW 3-Series (E90 E92) Forum
Remove rear turbo RHD suggestions
01-29-2014, 08:57 PM | #1 |
Rep 3,189
I have removed the thermostat, water pump, front turbo.
After removing all the manifold nuts so the turbo is loose I have not figured out how this thing will come out. I do still have one coolant line hanging loose that I have to get off. Do you have any suggestions? I have just spoke to some one over the phone about lifting the engine but not in detail. |
01-29-2014, 09:09 PM | #2 | |
Rep 1,525
turbo
Call me 505 908 4916 |
01-29-2014, 09:50 PM | #5 |
Rep 1,525
turbo
I have soft rubber pads I put on my floor jack and lifted it a little you must remove the motor mount and also there is a either an oil line or coolant line that runs behind the heatshield you must remove most of the little torx head screws to remove the rear turbo
01-29-2014, 10:04 PM | #6 |
Rep 3,189
cheers
I have one screw off the heat shield, I have to go buy some rubber, I havn't removed the motor mount yet. I've spent around 20+ hours so far |
01-31-2014, 03:14 AM | #8 |
Rep 1,392
Its easy, you just have to relocate your steering wheel to the correct side! J/K. Glad to hear you got it out, let us know how the install goes
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
