BMW 3-Series (E90 E92) Forum
Headlight Lens Crazing - Experiences?
02-13-2013, 10:19 PM | #1 |
Rep 2,638
Hi All,
Anyone experience crazing on their headlights? They are tiny little spider web cracks you can feel with a nail and see in the light. I just fitted Orion V4's and blacked out my LCI lights and saw this. I think it is acetone from when I was trying to get the adhesive off. Wondering if it is fixable. I had a shop try sanding with 1000 grit and it didn't work. Will try to go more aggressive and will have it clear coated at the body shop. I just want my lenses fixed. |
02-16-2013, 03:09 AM | #5 |
Rep 2,638
I saw what 1000 grit did and it did not remove it. I have asked them to go down to 400 grit to see what happens. Everything is blacked out and orion v4 rings are installed. now this......
02-16-2013, 08:24 AM | #6 |
Rep 799
Drives: 08 335 silverback
400 ...800...1200...1500...2000 and polish and seal they will be perfect, just reseal every 3 months and no clear needed and wwont risk it happening again
FBO...METH...BIG TWINS
02-16-2013, 12:09 PM | #7 |
Macgyver
208
Rep 942
I believe the acetone is the culprit. It can make the plastic cold and brittle. Acetone is really harsh and can get through gloves and enter your blood stream . Anyway, from what you described by sanding, it sounds like it spider cracked within the lens plastic. Clear coating may not help you. The way you can tell if it will is if you pour water over the lens after sanding and you do not see it anymore . If you still see it, the clear coat will not mask it.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
02-17-2013, 01:50 AM | #8 | ||
Rep 2,638
That's what I told them. Go down to 400 grit and work up. Seal with what? Isn't clear coat better. Quote:
I think the acetone did it. It was perfect before that. I will use the water method to verify. I wonder if lamin x will mask it. |
02-17-2013, 03:29 PM | #9 |
Rep 799
you can clear, but may not lay right unless you know what you are doing, and can peel in the future, like a vw or older benz, just use a synthetic paint sealant every 2-3 months, just apply, haze and wipe off, 15 minutes of work a year...lol and you wont have to worry about re doing them
02-18-2013, 02:13 AM | #10 | |
Rep 2,638
02-20-2013, 07:12 AM | #12 |
Rep 367
it is the acetone that did that, happened to me on my subaru years ago when I cleared the headlights. It is too harsh of a chemical for the lense and essentially eats through it. Your best bet is to find a used headlight and just swap out the lense.
02-21-2013, 03:09 AM | #13 |
Rep 2,638
yep. acetone did it. 320 grit still didn't fix it. I am just going to buy another set of housings. It's hard to find used lenses in good shape....so close yet so far.
