BMW 3-Series (E90 E92) Forum
Flickering LCI tail light
02-09-2013, 02:44 PM | #1 |
Rep 757
So I've got the flickering LCI tail light problem now and my car is 2 days out of warranty. Dealer won't fix it or give me a grace period so I've got to do something about it myself.
I'm wondering if all I have to do is replace the LED circuit board with a new one? I went online and found this: http://realoem.com/bmw/showparts.do?...74&hg=63&fg=20 I was wondering if part number 1 is the light (or circuit board) that needs to be replaced. I looked up some other threads but am not sure if one can simply take out the old circuit board and put a new one in. Does anyone have experience with swapping these out? Thanks, DD |
02-09-2013, 04:34 PM | #4 |
Bausman
64
Rep 1,817
02-09-2013, 07:57 PM | #6 |
Rep 269
02-09-2013, 08:09 PM | #7 |
Rep 757
02-09-2013, 11:39 PM | #8 |
Bausman
64
Rep 1,817
02-09-2013, 11:40 PM | #9 |
Bausman
64
Rep 1,817
02-10-2013, 11:29 PM | #10 |
Rep 2,638
there is a service bulletin and not limited to any country. My right light does this too. I have seen a diy where it is fixed with re touching soldering points. Under the service bulletin in the US they are supposed to change both lights.
02-10-2013, 11:55 PM | #11 |
Rep 277
Drives: '11 E90 N52 6MT
Yep, I had my drivers side lamp go out in the second month I owned my car (bought new) and the dealer tried to tell me bulbs weren't covered in warranty. I raised hell with my salesman who knew about the bulletin, they ended up replacing my entire housing, I later found out they fired the SA for being a total idiot.
02-11-2013, 01:33 AM | #12 | ||
Rep 1,093
Thanks.. |
02-11-2013, 07:48 AM | #13 |
Rep 186
This is a very common problem on e90 LCI tail lights...
As someone said, the problem is that the solders are very poor... so you have two options: 1- Change the tail light 2- Open it and re solder the leds. You can find here a good DIY: http://www.bmwfaq.com/f151/reparacio...ci-e90-658379/ It is in spanish but I thing the images are enough for understanding how to fix it. Kind regards!
Why don't do it by your self?
Retrofitting is always possible! |
