      01-01-2014, 02:02 PM   #23
Gt4
Gt4's Avatar
Drives: 2006 E46 M3 Estoril blue 6mt
Originally Posted by Cybmx View Post
What if I modify the base to make it nonadjustable and solid? Does your mirror vibrate badly since day one?
Yes they had always vibrate.
Also, the lenses are so small you won't see anything
      01-01-2014, 06:10 PM   #24
Cybmx
Drives: 06 Z4MR
That's so sad to hear
I was watching some F1 videos earlier, and their mirrors are just as small if not smaller, and they are so stable, no vibrate at all..
      01-01-2014, 11:58 PM   #25
StickMon
StickMon's Avatar
Drives: 2006 MR
They have carbon fiber stalks, and they probably spent over $100k in R&D to get the shape of the stalks and the lay-up of the weave just right.
I just took a look at the APRs on their web site.
Looks like there may be a lot of flex in the panel that mounts them to the car.
      01-02-2014, 10:34 AM   #26
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
all weights are in lbs...
battery (80Ah AGM) = 51.00
exhaust section 2 (USA) = 16.81
rear shock = 4.09
rear spring = 5.19
front sway bar = 14.08
front sway link = 0.77 / ea.
rear sway bar = 6.84
rear sway link = 0.18 / ea.
flywheel = 25.04
pressure plate = 11.55
clutch disc = 2.39
///m hood = 24.2
stock side skirt = 4.53 / ea.
aero side skirt = 5.47 / ea.
stock ///m front cover = 11.90
aero front cover = 11.88
stock ///m rear cover = 11.91
xenon headlamp (minus bulbs and cntl units) = 5.65 / ea
rear LCI taillamp = 1.72 / ea.
front fender = 10.01 / ea.
headliner = 9.90
long block (w/ crank, rods, pistons, flywheel, complete head, vanos, pan, valve cover, water pump, and t-stat) = 322.30
transmission = 97.90
differential = 81.62
steering rack = 14.61
front subframe = 16.72
front spindle = 9.46 / ea.
front lower cntl arm = 5.83 / ea.
rear subframe = 30.29
rear knuckle = 22.09 / ea.
rear lower cntl arm = 5.52 / ea.
rear trailing arm = 2.79 / ea.
gas tank = 19.80
fuel pump = 2.00
fuel filter = 0.84
      01-02-2014, 11:46 AM   #27
v3.2mc
Not a New Member
v3.2mc's Avatar
complete driveshaft assy = 18.06
      01-02-2014, 03:16 PM   #28
v3.2mc
Not a New Member
v3.2mc's Avatar
rear hatch interior panels (all) = 4.31
dash (bare) = 19.76
aluminum trim (all) = 4.50
wood trim (all) = 4.24
carbon leather trim (all) = 3.88
center console (bare) = 3.41
rear console "cubby" = 2.71
carpet (cabin) = 24.11
carpet (trunk) = 4.67
rear theft blind (coupe only) = 7.70
trunk paneling (all) = 6.80
bulkhead paneling (behind seats, all) = 8.32
      01-02-2014, 03:20 PM   #29
v3.2mc
Not a New Member
v3.2mc's Avatar
all in-cabin interior sound deadening panels = 8.03
(dash, trans tunnel, roof, doors, rear wheels)
      01-02-2014, 04:54 PM   #30
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
@v3.2mc Great data!!
........ where are you finding all this info?
      01-02-2014, 05:26 PM   #31
v3.2mc
Not a New Member
v3.2mc's Avatar
i have a registered copy of ETK.
if you have a copy, you may be able to see this data for yourself by selecting the "i" on the far left of the part description frame.
weight is shown in kilos...
      01-02-2014, 05:41 PM   #32
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Great!!!!!!! Thanks
      01-02-2014, 08:11 PM   #33
Gt4
Gt4's Avatar
bumper beams?
      01-02-2014, 08:48 PM   #34
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ would love to know that as well.
Ideal pieces to be done in composite. Reducing mass at both extremities would be fantastic!
      01-02-2014, 10:36 PM   #35
v3.2mc
Not a New Member
v3.2mc's Avatar
front reinforcement bar = 9.35
front re*bar deformation frame = 5.62 / ea.
rear reinforcement bar = 23.54
rear re*bar shock = 5.63 / ea.
      01-02-2014, 10:43 PM   #36
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I've removed the rear reinforcement bar before , and that thing is a beast
      01-03-2014, 09:02 AM   #37
v3.2mc
Not a New Member
v3.2mc's Avatar
e86 body-in-white = 586.30
e85 body-in-white = 585.20
my thought on the similarity between the weights of the e85 and the e86 is that the diagram for the e85 is so terrible there *must* be detail missing that would provide a hint as to why it is nearly as heavy as the coupe.
      01-03-2014, 09:13 AM   #38
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
lol not to sound like a douche, but that E85 diagram is as if it were drawn up on a Monday or a Friday of the workweek
Definitely not on par with the E86's diagram heheh
      01-03-2014, 09:23 AM   #39
v3.2mc
Not a New Member
v3.2mc's Avatar
... during octoberfest maybe?
      01-03-2014, 12:59 PM   #40
v3.2mc
Not a New Member
v3.2mc's Avatar
main wiring harness = 47.96
door wiring harness = 0.77 / ea.
front headlamp harness = 1.98 / ea.
rear lamp harness (all) = 4.84
seat harness = 0.48 / ea.
battery sbk = 1.56
pos batt cable = 2.42
neg batt cable = 0.44
headlamp wash pump = 0.37
headlamp wash nozzle = 0.35 / ea.
headlamp wash hoses (all) = 0.81
a-pillar cover = 0.48 / ea.
b-pillar cover = 0.31 / ea.
c-pillar cover = 0.37 / ea.
floormats (both) = 3.52
      01-03-2014, 01:40 PM   #41
Twisted Six
Twisted Six's Avatar
Drives: Z4si-coupe
Originally Posted by dre99gsx View Post
I did some searching but couldn't find a concise Z4M weight reduction strategy thread. Seeing that many of you have removed stock components and actually weighed them, would you be willing to post component weights (as accurate as you can get)?
I'll be posting in here as I weigh various components on my end (I have scales and even do my own corner balancing for the ultimate weight comparisons). Here are some components which seem to be common for removal:
- Rear battery (?lb)
- Passenger Seat (Leather/Heated/Power) = 60 lb
- Driver Seat (Leather/Heated/Power) = 56 lb
- Passenger Door Card (incl. speaker) = 7.6lb
- Intake Air Plenum = 9.2 lb
- Stock Air Filter Box = 4.6 lb
- Exhaust Headers US (shorter) = 8.8 lb
- Exhaust Headers US (longer) = 9.6 lb
- Exhaust Headers EURO (shorter) = 4.6 lb
- Exhaust Headers EURO (longer) = 5.6 lb
- Exhaust Section 1 (US) = 19 lbs
- Exhaust Section 2 (US)
- Exhaust rear muffler = 22 lb ea.
- Rear wheel with tire and logo: 53.8 pound
- Rear Wheel: 9.0J x 18 EH2 IS30 25.88 lb
- Front wheel with tire and logo: 49.4 pound
- Front Wheel: 8.0J x 18 EH2 IS42 24.75 lb
- Front Shock complete assembly = 17 lbs
- Rear Shock and Spring
- Front Sway Bar and Endlink
- Rear Sway Bar and Endlink
- Front Caliper = 12.2 lb
- Front Rotor = 18.4 lb
- Rear Caliper = 7.4 lb
- Rear Rotor = 14.6 lb
- Rear Tools (Air compressor, canister, tow hook) = 5 lb
- Rear hatch cover mechanism = 7.5 lb
- Flywheel
- Aluminum Roof = 38 lb
- Rear Hatch (w/o glass) = 31.6 lb
- Rear Hatch Glass = 15.8 lb
- Door (Shell, Empty) = 30 lb, Everything but door card = 51.6 lb
- Rear Fender = 7 lb
- Hood
NAV and Audio:
04.8 lbs-Harness
01.0 lbs-misc brackets
04.2 lbs-2 Kick panel Speakers
14.2 lbs-2 Rear subwoofers
00.2 lbs-GPS antenna
09.0 lbs-Amps/amp brackets
03.4 lbs-4 mid range speakers
00.2 lbs-2 tweeters
03.6 lbs-GPS/DVD drive
02.4 lbs-Pop-up display
02.6 lbs-Head unit
(If I missed a thread which already covers the above, please link me!)
I just posted the front fender weights a few days ago in some thread, can't recall which or how much. Anyone have a link to share it or the weight I posted ?
Found it. Front fenders weighed in at 9.9lbs. on a premium scale.
AriuSen776.50
      12-03-2018, 07:08 PM   #42
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
aluminium roof 38 lbs?
pretty sure its not alu and that seems awfully heavy?? is that right?
Powered by
      12-04-2018, 09:15 PM   #43
dre99gsx
Drives: 1994 Toyota Supra
This list was put together a long long time ago, but numbers were taken from other threads on this forum. If anyone has changes/updates, easy to to.
      12-05-2018, 08:22 AM   #44
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Yeah its NOT 38 Lbs... NO WAY!!
No its steel. weighed mine today, its 9 KGS. (mine was 9.0, as it had been painted black) so total weight loss is 7KGS. plus or minus a few grams. Still a pretty darn good weight savings for up top.
White dot = fridge magnet.. def steel
Powered by
MOEDARE140.00
Azeka1285.50
